[pdal-commits] [PDAL/PDAL] c8b384: no longer refer to XML output #998
GitHub noreply at github.com
Thu Sep 24 08:11:36 PDT 2015
  Branch: refs/heads/gdal-hag
  Home:   https://github.com/PDAL/PDAL
  Commit: c8b384cf591d49f00109d6f086168bb489a4a7ec
      https://github.com/PDAL/PDAL/commit/c8b384cf591d49f00109d6f086168bb489a4a7ec
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-09-22 (Tue, 22 Sep 2015)
  Changed paths:
    M doc/tutorial/reading.rst
  Log Message:
  Commit: 95f92b51e7c6d83582afdb103442af9387ab51d4
      https://github.com/PDAL/PDAL/commit/95f92b51e7c6d83582afdb103442af9387ab51d4
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M doc/metadata.rst
  Log Message:
  Remove references to dead --xml option.
Close #998
  Commit: 52a14f979ee9a6576a2c3d469272b25a24bf8af7
      https://github.com/PDAL/PDAL/commit/52a14f979ee9a6576a2c3d469272b25a24bf8af7
  Changed paths:
    M doc/conf.py
    M doc/docs.rst
    M doc/stages/filters.ferry.rst
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.splitter.rst
    A doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    A doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_spec.rst
    M doc/vagrant.rst
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/gdal/CMakeLists.txt
    A io/gdal/GDALReader.cpp
    A io/gdal/GDALReader.hpp
    M io/ply/PlyReader.cpp
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M src/GDALUtils.cpp
    M src/StageFactory.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: bf5f9fe98f26adfb30c10aa55fdf5dadb845e6a5
      https://github.com/PDAL/PDAL/commit/bf5f9fe98f26adfb30c10aa55fdf5dadb845e6a5
  Changed paths:
    M plugins/pcl/filters/RadiusOutlierFilter.cpp
    M plugins/pcl/filters/StatisticalOutlierFilter.cpp
  Log Message:
  Fix compilation warning.
  Commit: 4021400d5597d7d96f2eec4f503eb3013c5cf113
      https://github.com/PDAL/PDAL/commit/4021400d5597d7d96f2eec4f503eb3013c5cf113
  Changed paths:
    M io/las/LasWriter.cpp
  Log Message:
  Formatting and comment fix.
  Commit: f36e858d9ccee23fe269d5944a42adc6192b3806
      https://github.com/PDAL/PDAL/commit/f36e858d9ccee23fe269d5944a42adc6192b3806
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-09-23 (Wed, 23 Sep 2015)
  Changed paths:
    M doc/stages/filters.statisticaloutlier.rst
  Log Message:
  Change statistical outlier defaults
  Commit: 48b0bc4ecf543f58d14ac749690769adfe86361a
      https://github.com/PDAL/PDAL/commit/48b0bc4ecf543f58d14ac749690769adfe86361a
  Changed paths:
    A doc/stages/filters.statisticaloutlier.img1.png
    A doc/stages/filters.statisticaloutlier.img2.png
  Log Message:
  Add screenshots for outlier removal
  Commit: 7f549edd73c583d7211ad19c6dee12675de5daa1
      https://github.com/PDAL/PDAL/commit/7f549edd73c583d7211ad19c6dee12675de5daa1
  Changed paths:
    M include/pdal/Kernel.hpp
    M include/pdal/Options.hpp
    M include/pdal/Stage.hpp
    M src/Options.cpp
  Log Message:
  Implement Options::remove and Stage::removeOptions
  Commit: b6660ef6f0cb727905aa0fbfa797a8c91db299ae
      https://github.com/PDAL/PDAL/commit/b6660ef6f0cb727905aa0fbfa797a8c91db299ae
  Changed paths:
    M src/Options.cpp
  Log Message:
  Remove by key to remove all matching elements
  Commit: 15c3d2eb2f2efc375984b9044271994be52ba865
      https://github.com/PDAL/PDAL/commit/15c3d2eb2f2efc375984b9044271994be52ba865
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M src/Options.cpp
  Log Message:
  Merge pull request #999 from PDAL/remove-options
  Commit: c445ab395b74d022a32f9f51bf37c1e7031f1f81
      https://github.com/PDAL/PDAL/commit/c445ab395b74d022a32f9f51bf37c1e7031f1f81
  Changed paths:
    M doc/metadata.rst
    M src/Options.cpp
  Log Message:
  Merge branch 'master' into gdal-hag
  Commit: f84ebb9b53e02d495f95cbac535896b5ee9200f0
      https://github.com/PDAL/PDAL/commit/f84ebb9b53e02d495f95cbac535896b5ee9200f0
  Changed paths:
    M src/Options.cpp
  Log Message:
  Commit: 83fac2aaeb4aba2ce98d262a94f3c223e18b4199
      https://github.com/PDAL/PDAL/commit/83fac2aaeb4aba2ce98d262a94f3c223e18b4199
  Changed paths:
    M doc/stages/readers.las.rst
    M include/pdal/Compression.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasUtils.hpp
    M io/las/LasWriter.hpp
    M scripts/ci/before_install.sh
    M scripts/ci/script.sh
    A test/data/las/autzen_trim.las
    A test/data/laz/autzen_trim.laz
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Support LazPerf for compression/decompression.
  Commit: 9ac61c3e02f461f639053c2561611cbb979936e7
      https://github.com/PDAL/PDAL/commit/9ac61c3e02f461f639053c2561611cbb979936e7
  Date:   2015-09-24 (Thu, 24 Sep 2015)
  Changed paths:
    A test/data/autzen/autzen-APMF.json
    R test/data/autzen/hag.xml
    A test/data/autzen/hag.xml.in
  Log Message:
  reorg HAG example
  Commit: f72d4323d95097f4bbc24fa6b56503660f14d146
      https://github.com/PDAL/PDAL/commit/f72d4323d95097f4bbc24fa6b56503660f14d146
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into gdal-hag
Compare: https://github.com/PDAL/PDAL/compare/299495cb566c...f72d4323d950
More information about the pdal-commits mailing list
