[pdal-commits] [PDAL/PDAL] 17a25d: CMAKE_SOURCE_DIR typo
GitHub noreply at github.com
Mon Sep 28 12:37:18 PDT 2015
  Branch: refs/heads/ilvis2-reader
  Home:   https://github.com/PDAL/PDAL
  Commit: 17a25d6a12acfa2b3c4954a6bf654b731f674361
      https://github.com/PDAL/PDAL/commit/17a25d6a12acfa2b3c4954a6bf654b731f674361
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-09-24 (Thu, 24 Sep 2015)
  Changed paths:
    M test/data/hole/crop.xml.in
  Log Message:
  Commit: f04a7f857084a3751362ab2bcc7ba31c8ab94cf1
      https://github.com/PDAL/PDAL/commit/f04a7f857084a3751362ab2bcc7ba31c8ab94cf1
  Date:   2015-09-28 (Mon, 28 Sep 2015)
  Changed paths:
    M cmake/geowave.cmake
    M cmake/jace.cmake
    M cmake/jni.cmake
    M cmake/modules/FindGeoWave.cmake
    M cmake/modules/FindJace.cmake
    M plugins/geowave/CMakeLists.txt
    M plugins/geowave/io/GeoWaveReader.cpp
    M plugins/geowave/io/GeoWaveReader.hpp
    M plugins/geowave/io/GeoWaveWriter.cpp
    M scripts/linux-install-scripts/geowave
    M scripts/linux-install-scripts/geowave.sh
    M scripts/linux-install-scripts/packages.sh
    M scripts/linux-install-scripts/pdal.sh
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 9f7be5e86fe19043ca6f5ca0115e460ed36a44fe
      https://github.com/PDAL/PDAL/commit/9f7be5e86fe19043ca6f5ca0115e460ed36a44fe
  Changed paths:
    A doc/stages/readers.ilvis2.metadata.png
    A doc/stages/readers.ilvis2.rst
    M io/CMakeLists.txt
    A io/ilvis2/CMakeLists.txt
    A io/ilvis2/Ilvis2Reader.cpp
    A io/ilvis2/Ilvis2Reader.hpp
    M src/StageFactory.cpp
    A test/data/ilvis2/ILVIS2_GL2009_0414_R1401_042504.TXT
    A test/data/ilvis2/ILVIS2_GL2009_0414_R1401_042504.TXT.xml
    A test/data/ilvis2/ilvis.xml
  Log Message:
  provide untested implementation of ILVIS2 ASCII reader #1004
Compare: https://github.com/PDAL/PDAL/compare/17a25d6a12ac^...9f7be5e86fe1
More information about the pdal-commits mailing list
