[pdal-commits] [PDAL/PDAL] 39b520: Add Euclidean Cluster Extraction
GitHub noreply at github.com
Thu Dec 29 10:15:52 PST 2016
  Branch: refs/heads/stage-application-json-object
  Home:   https://github.com/PDAL/PDAL
  Commit: 39b5202eef45e5f519da24262305ca3d3523178d
      https://github.com/PDAL/PDAL/commit/39b5202eef45e5f519da24262305ca3d3523178d
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-12-16 (Fri, 16 Dec 2016)
  Changed paths:
    A pdal/Segmentation.cpp
    A pdal/Segmentation.hpp
    M test/unit/CMakeLists.txt
    A test/unit/SegmentationTest.cpp
  Log Message:
  Commit: 6fdc7a63190aed31b1448ca8e470013a3db2b256
      https://github.com/PDAL/PDAL/commit/6fdc7a63190aed31b1448ca8e470013a3db2b256
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M pdal/Segmentation.cpp
  Log Message:
  include Segmentation.cpp for the PDAL_DLL decoration
  Commit: b8402895b2b62f365bfca3d29fa35723d0b63a2c
      https://github.com/PDAL/PDAL/commit/b8402895b2b62f365bfca3d29fa35723d0b63a2c
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #1449 from PDAL/extract-clusters
  Commit: 0f15893dcd828ba6a705706def6dcd51b6ad92fc
      https://github.com/PDAL/PDAL/commit/0f15893dcd828ba6a705706def6dcd51b6ad92fc
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-12-19 (Mon, 19 Dec 2016)
  Changed paths:
    M pdal/PointTable.cpp
    M pdal/PointTable.hpp
    M test/unit/PointTableTest.cpp
  Log Message:
  Provide ordered SRSes in PointTable.
  Commit: ce543be54f7d4cc6605e09e20ae89cbf5ecf17b9
      https://github.com/PDAL/PDAL/commit/ce543be54f7d4cc6605e09e20ae89cbf5ecf17b9
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: c9e2f72058698b4c4857ba457f55f23f0fff9528
      https://github.com/PDAL/PDAL/commit/c9e2f72058698b4c4857ba457f55f23f0fff9528
  Date:   2016-12-20 (Tue, 20 Dec 2016)
  Changed paths:
    M doc/stages/filters.pmf.rst
  Log Message:
  filters.pmf notes
  Commit: ac9ce6c1c5b88be16e6372d68b411bf64296ed1e
      https://github.com/PDAL/PDAL/commit/ac9ce6c1c5b88be16e6372d68b411bf64296ed1e
  Changed paths:
    A doc/stages/filters.groupby.rst
    A filters/GroupByFilter.cpp
    A filters/GroupByFilter.hpp
    M pdal/StageFactory.cpp
    A test/unit/filters/GroupByFilterTest.cpp
  Log Message:
  Add a filter to split an incoming PointView by data in a given dimension
  Commit: 2eed92256aa48d989ca871888e72a2d5e8a076b7
      https://github.com/PDAL/PDAL/commit/2eed92256aa48d989ca871888e72a2d5e8a076b7
  Date:   2016-12-21 (Wed, 21 Dec 2016)
  Changed paths:
    A doc/stages/filters.cluster.rst
    A filters/ClusterFilter.cpp
    A filters/ClusterFilter.hpp
  Log Message:
  Add filter that writes cluster IDs to a new dimension
  Commit: ee9062fb48d11baad3b8f0543dce6d214a179fff
      https://github.com/PDAL/PDAL/commit/ee9062fb48d11baad3b8f0543dce6d214a179fff
  Changed paths:
    M doc/stages/filters.cluster.rst
  Log Message:
  Add options to cluster docs
  Commit: eee70cb5d49f05cc25618e20016a05b872247356
      https://github.com/PDAL/PDAL/commit/eee70cb5d49f05cc25618e20016a05b872247356
  Changed paths:
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
  Log Message:
  Formatting.
  Commit: b8b6f76ba113b9aad9a66c5796e262fda3ceeef4
      https://github.com/PDAL/PDAL/commit/b8b6f76ba113b9aad9a66c5796e262fda3ceeef4
  Changed paths:
  Log Message:
  Merge pull request #1454 from PDAL/groupby
  Commit: f4942fcb68a166e3f6a95347a7d24d68d4d29997
      https://github.com/PDAL/PDAL/commit/f4942fcb68a166e3f6a95347a7d24d68d4d29997
  Changed paths:
  Log Message:
  Merge pull request #1455 from PDAL/label-clusters
Label clusters
  Commit: 52b7a02ef0ebc7e8cb911e86926604d87cb2efc3
      https://github.com/PDAL/PDAL/commit/52b7a02ef0ebc7e8cb911e86926604d87cb2efc3
  Changed paths:
    A doc/stages/filters.locatemax.rst
    A filters/LocateMaxFilter.cpp
    A filters/LocateMaxFilter.hpp
    A test/unit/filters/LocateMaxFilterTest.cpp
  Log Message:
  Add filter to locate max value in a given dimension
If many points share the max value, this simply gives you the first one.
  Commit: 67fed24a05707c230a5c8b5f6b43ccf631787d44
      https://github.com/PDAL/PDAL/commit/67fed24a05707c230a5c8b5f6b43ccf631787d44
  Changed paths:
    A doc/stages/filters.locate.rst
    R doc/stages/filters.locatemax.rst
    A filters/LocateFilter.cpp
    A filters/LocateFilter.hpp
    R filters/LocateMaxFilter.cpp
    R filters/LocateMaxFilter.hpp
    A test/unit/filters/LocateFilterTest.cpp
    R test/unit/filters/LocateMaxFilterTest.cpp
  Log Message:
  Locate filter can now locate min or max value
  Commit: c0491d2c64f8a9ad76d35d34352e06d7ba01e588
      https://github.com/PDAL/PDAL/commit/c0491d2c64f8a9ad76d35d34352e06d7ba01e588
  Changed paths:
    M doc/stages/filters.locate.rst
  Log Message:
  Typo in filters.locate docs
  Commit: 71b0b6c570083e168c161b96abfe9d220bfb08e5
      https://github.com/PDAL/PDAL/commit/71b0b6c570083e168c161b96abfe9d220bfb08e5
  Changed paths:
  Log Message:
  Merge pull request #1453 from PDAL/locatemax
  Commit: 666927259b8fd0874b5ac0889b3ff8f6e6aefabb
      https://github.com/PDAL/PDAL/commit/666927259b8fd0874b5ac0889b3ff8f6e6aefabb
  Changed paths:
  Log Message:
  Commit: 7125f772af1024e1896cb31ad8144400fbef66c0
      https://github.com/PDAL/PDAL/commit/7125f772af1024e1896cb31ad8144400fbef66c0
  Date:   2016-12-23 (Fri, 23 Dec 2016)
  Changed paths:
    M io/GeotiffSupport.cpp
    M io/GeotiffSupport.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
  Log Message:
  Simplify geotiff conversions.
  Commit: 30b7274b1e8951c6379c0cd0f647de025fba73ee
      https://github.com/PDAL/PDAL/commit/30b7274b1e8951c6379c0cd0f647de025fba73ee
  Changed paths:
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M kernels/PipelineKernel.cpp
    M kernels/PipelineKernel.hpp
    M pdal/FlexWriter.hpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Provide hook for SRS changes during streaming.
Make sure we only call ready() and done() once for each stage in streaming mode.
Add streaming support to pipeline kernel.
  Commit: 58cf622f6caa5b82cba14fd86d567b4676b08d17
      https://github.com/PDAL/PDAL/commit/58cf622f6caa5b82cba14fd86d567b4676b08d17
  Date:   2016-12-29 (Thu, 29 Dec 2016)
  Changed paths:
    A doc/images/foss4g-2017.png
    M doc/index.rst
  Log Message:
  add foss4g2017 link to front page
  Commit: b97a3c7d9979f388f9038662a96393226979e213
      https://github.com/PDAL/PDAL/commit/b97a3c7d9979f388f9038662a96393226979e213
  Changed paths:
    M doc/index.rst
    M io/LasHeader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into stage-application-json-object
  Commit: dea4dfbe5294a5a6f568e3d797eeb30d7c042e3d
      https://github.com/PDAL/PDAL/commit/dea4dfbe5294a5a6f568e3d797eeb30d7c042e3d
  Changed paths:
    M doc/pipeline.rst
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
  Log Message:
  rename 'application' to 'userData'
Compare: https://github.com/PDAL/PDAL/compare/ecfd80816407...dea4dfbe5294
More information about the pdal-commits mailing list
