[pdal-commits] [PDAL/PDAL] 959dc0: a bunch of documentation tweaks related to getting...
GitHub noreply at github.com
Tue Feb 23 07:05:39 PST 2016
  Branch: refs/heads/merge-issues-with-tests
  Home:   https://github.com/PDAL/PDAL
  Commit: 959dc0145ca4d55805aa20bc6d0eca28fd67a26b
      https://github.com/PDAL/PDAL/commit/959dc0145ca4d55805aa20bc6d0eca28fd67a26b
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-02-19 (Fri, 19 Feb 2016)
  Changed paths:
    M doc/compilation/unix.rst
    M doc/compilation/windows.rst
    M doc/conf.py
    M doc/contributors.rst
    M doc/docbuild/Dockerfile
    M doc/index.rst
    A doc/pdal.style
    M doc/stages/filters.dartsample.rst
    M doc/stages/filters.statisticaloutlier.rst
    M doc/stages/index.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.qfit.rst
    M doc/tutorial/dart-throwing.rst
    M doc/tutorial/docker.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/writing-filter.rst
    R doc/vagrant.rst
  Log Message:
  a bunch of documentation tweaks related to getting rst2pdf output working -- not quite done yet
  Commit: a97409ab39ab05e4f234226269257ffa0822b1be
      https://github.com/PDAL/PDAL/commit/a97409ab39ab05e4f234226269257ffa0822b1be
  Changed paths:
    M include/pdal/FlexWriter.hpp
    M include/pdal/Options.hpp
    M include/pdal/Writer.hpp
    M io/bpf/BpfHeader.cpp
    M io/derivative/DerivativeWriter.cpp
    M io/derivative/DerivativeWriter.hpp
    M io/las/LasReader.cpp
    M plugins/pcl/CMakeLists.txt
    M src/Writer.cpp
    M src/util/FileUtils.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/apps/pc2pcTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into hobu-docs-rollup
  Commit: e1f0190fc69437e1e2ffe95ae9877a2f087f0a60
      https://github.com/PDAL/PDAL/commit/e1f0190fc69437e1e2ffe95ae9877a2f087f0a60
  Date:   2016-02-23 (Tue, 23 Feb 2016)
  Changed paths:
    M doc/conf.py
    M doc/index.rst
    A doc/pdal.style
    R doc/vagrant.rst
  Log Message:
  Merge pull request #1144 from PDAL/hobu-docs-rollup
  Commit: a8d3ea840546f993c59e4a6fa4f9b60b356fea94
      https://github.com/PDAL/PDAL/commit/a8d3ea840546f993c59e4a6fa4f9b60b356fea94
  Changed paths:
  Log Message:
  make windows 2012 happy
  Commit: ddfd1ba82fcc4394584bd1c631b7e1b5665dbc38
      https://github.com/PDAL/PDAL/commit/ddfd1ba82fcc4394584bd1c631b7e1b5665dbc38
  Changed paths:
    M appveyor.yml
  Log Message:
  update slack notification channel as described by https://www.appveyor.com/updates/2016/01/31
  Commit: ef083240236e04b7d60a25cbaf8040af45821486
      https://github.com/PDAL/PDAL/commit/ef083240236e04b7d60a25cbaf8040af45821486
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M include/pdal/Kernel.hpp
    M include/pdal/KernelSupport.hpp
    M include/pdal/Stage.hpp
    R include/pdal/UserCallback.hpp
    M io/sbet/SbetWriter.cpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M src/CMakeLists.txt
    M src/KernelSupport.cpp
    M src/Stage.cpp
    M src/Writer.cpp
    M test/unit/CMakeLists.txt
    R test/unit/UserCallbackTest.cpp
  Log Message:
  Remove heartbeat support.
  Commit: 016a23182daaa038b58cf8a3c2645d95bce207de
      https://github.com/PDAL/PDAL/commit/016a23182daaa038b58cf8a3c2645d95bce207de
  Changed paths:
    M src/Stage.cpp
    M test/unit/io/las/LasReaderTest.cpp
  Log Message:
  Add Stage documentation.
  Commit: 44f2002e1dc796062e76da060aeaa137635b867e
      https://github.com/PDAL/PDAL/commit/44f2002e1dc796062e76da060aeaa137635b867e
  Changed paths:
    M appveyor.yml
    M doc/conf.py
    M doc/index.rst
    A doc/pdal.style
    R doc/vagrant.rst
    M src/Stage.cpp
    M src/Writer.cpp
  Log Message:
  Merge branch 'master' into merge-issues-with-tests
Compare: https://github.com/PDAL/PDAL/compare/1c1b4b2fb23a...44f2002e1dc7
More information about the pdal-commits mailing list
