[pdal-commits] [PDAL/PDAL] efa248: Replace pseudo-scoped-enums with actual scoped enu...
GitHub noreply at github.com
Tue Jul 5 14:13:45 PDT 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: efa24855cf2bc72b86ee4d418b549ef5aec60b10
      https://github.com/PDAL/PDAL/commit/efa24855cf2bc72b86ee4d418b549ef5aec60b10
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-07-05 (Tue, 05 Jul 2016)
  Changed paths:
    M dimbuilder/DimBuilder.cpp
    M dimbuilder/DimBuilder.hpp
    M doc/tutorial/overview.rst
    M examples/writing-filter/MyFilter.cpp
    M examples/writing-filter/MyFilter.hpp
    M examples/writing-writer/MyWriter.cpp
    M examples/writing-writer/MyWriter.hpp
    M filters/approximatecoplanar/ApproximateCoplanarFilter.hpp
    M filters/attribute/AttributeFilter.hpp
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/eigenvalues/EigenvaluesFilter.hpp
    M filters/estimaterank/EstimateRankFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/normal/NormalFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/sort/SortFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M include/pdal/Compression.hpp
    M include/pdal/DbReader.hpp
    M include/pdal/DbWriter.hpp
    M include/pdal/DimDetail.hpp
    M include/pdal/DimType.hpp
    M include/pdal/DimUtil.hpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/KDIndex.hpp
    M include/pdal/Log.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/PointContainer.hpp
    M include/pdal/PointLayout.hpp
    M include/pdal/PointRef.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/PointView.hpp
    M include/pdal/PointViewIter.hpp
    M include/pdal/XMLSchema.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plang/Environment.hpp
    M include/pdal/plang/Invocation.hpp
    M include/pdal/util/Utils.hpp
    M io/bpf/BpfHeader.hpp
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfWriter.cpp
    M io/gdal/GDALReader.cpp
    M io/gdal/GDALReader.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/las/LasHeader.cpp
    M io/las/LasReader.cpp
    M io/las/LasUtils.cpp
    M io/las/LasUtils.hpp
    M io/las/LasWriter.cpp
    M io/ply/PlyReader.cpp
    M io/ply/PlyReader.hpp
    M io/ply/PlyWriter.cpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetWriter.cpp
    M io/text/TextReader.cpp
    M io/text/TextWriter.cpp
    M io/tindex/TIndexReader.cpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M plugins/geowave/io/GeoWaveWriter.hpp
    M plugins/greyhound/io/Exchanges.cpp
    M plugins/greyhound/io/Exchanges.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/pcl/PCLConversions.hpp
    M plugins/pcl/filters/DartSampleFilter.cpp
    M plugins/pcl/filters/GreedyProjectionFilter.cpp
    M plugins/pcl/filters/GridProjectionFilter.cpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    M plugins/pcl/filters/PCLBlock.cpp
    M plugins/pcl/filters/PoissonFilter.cpp
    M plugins/pcl/filters/RadiusOutlierFilter.cpp
    M plugins/pcl/filters/StatisticalOutlierFilter.cpp
    M plugins/pcl/filters/VoxelGridFilter.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M plugins/rxp/io/RxpPointcloud.cpp
    M plugins/rxp/io/RxpPointcloud.hpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M scripts/docker/Dockerfile
    M src/DbReader.cpp
    M src/DbWriter.cpp
    M src/GDALUtils.cpp
    M src/Log.cpp
    M src/PointLayout.cpp
    M src/PointTable.cpp
    M src/PointView.cpp
    M src/Stage.cpp
    M src/XMLSchema.cpp
    M src/plang/Array.cpp
    M src/plang/BufferedInvocation.cpp
    M src/plang/Environment.cpp
    M src/plang/Invocation.cpp
    M test/unit/CompressionTest.cpp
    M test/unit/PointContextTest.cpp
    M test/unit/PointTableTest.cpp
    M test/unit/PointViewTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/io/gdal/GDALReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  Replace pseudo-scoped-enums with actual scoped enums, getting rid of the
need for '::Enum' in type names and disallowing implicit conversion to native.
  Commit: 84381f623cea495a903093b8c1a2eed65065b231
      https://github.com/PDAL/PDAL/commit/84381f623cea495a903093b8c1a2eed65065b231
  Changed paths:
    M doc/stages/writers.p2g.rst
    M plugins/p2g/io/P2gWriter.cpp
    M src/Dimension.json
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/c613eecee3a1...84381f623cea
More information about the pdal-commits mailing list
