[pdal-commits] [PDAL/PDAL] 6b33a2: put back Dockerfile
GitHub noreply at github.com
Fri Jul 29 07:14:16 PDT 2016
  Branch: refs/heads/greyhound-updates
  Home:   https://github.com/PDAL/PDAL
  Commit: 6b33a20ab5a445fe02f877ff60c63fef7eb2f6e1
      https://github.com/PDAL/PDAL/commit/6b33a20ab5a445fe02f877ff60c63fef7eb2f6e1
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-07-17 (Sun, 17 Jul 2016)
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  put back Dockerfile
  Commit: 3c57de4f715a5f831a5674fc0c696a7a3dde3c69
      https://github.com/PDAL/PDAL/commit/3c57de4f715a5f831a5674fc0c696a7a3dde3c69
  Date:   2016-07-18 (Mon, 18 Jul 2016)
  Changed paths:
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/greyhound/test/GreyhoundReaderTest.cpp
  Log Message:
  greyhound reader with no splitting
  Commit: 3b19061854dc25f4bca9d60cef2043a277c826bc
      https://github.com/PDAL/PDAL/commit/3b19061854dc25f4bca9d60cef2043a277c826bc
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-07-19 (Tue, 19 Jul 2016)
  Changed paths:
    M include/pdal/PluginManager.hpp
    M src/PluginManager.cpp
  Log Message:
  Consolidate plugin path handling.
Add plugin loading logging.
  Commit: d5acb7ea19fcb333a5cc8b0cd43723776e89460d
      https://github.com/PDAL/PDAL/commit/d5acb7ea19fcb333a5cc8b0cd43723776e89460d
  Changed paths:
    M doc/stages/writers.p2g.rst
    M filters/crop/CropFilter.cpp
    M src/PipelineManager.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: d9db6bee1f381cb9e99617b925c07e4c87f9a43f
      https://github.com/PDAL/PDAL/commit/d9db6bee1f381cb9e99617b925c07e4c87f9a43f
  Date:   2016-07-20 (Wed, 20 Jul 2016)
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into greyhound-updates
  Commit: 734a4f81a828f63c20a839d92cb3780700c01e74
      https://github.com/PDAL/PDAL/commit/734a4f81a828f63c20a839d92cb3780700c01e74
  Changed paths:
  Log Message:
  more greyhound churn
  Commit: 6373b3c813eef4d53ea37890d889255221ce3357
      https://github.com/PDAL/PDAL/commit/6373b3c813eef4d53ea37890d889255221ce3357
  Changed paths:
    M plugins/p2g/io/P2gWriter.cpp
  Log Message:
  Ensure extension doesn't get embedded in filename.
  Commit: 2ebf6a9fd6648a0c790096838435cedcd4b5b9f3
      https://github.com/PDAL/PDAL/commit/2ebf6a9fd6648a0c790096838435cedcd4b5b9f3
  Date:   2016-07-22 (Fri, 22 Jul 2016)
  Changed paths:
    M plugins/hexbin/filters/HexBin.cpp
  Log Message:
  another kind of density computation
  Commit: 6f4fbd3120b6f5e9c060a48e6bc718866ca558b5
      https://github.com/PDAL/PDAL/commit/6f4fbd3120b6f5e9c060a48e6bc718866ca558b5
  Changed paths:
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
  Log Message:
  Use PDALUtils to open LAS files.
  Commit: e8bbae34e8f0f11b74d2fe3c112a2d98cd010184
      https://github.com/PDAL/PDAL/commit/e8bbae34e8f0f11b74d2fe3c112a2d98cd010184
  Changed paths:
  Log Message:
  Commit: 8c46d09148ad6e2646089e3114b0ef82097e6d5f
      https://github.com/PDAL/PDAL/commit/8c46d09148ad6e2646089e3114b0ef82097e6d5f
  Author: Connor Manning <connor at hobu.co>
  Date:   2016-07-25 (Mon, 25 Jul 2016)
  Changed paths:
  Log Message:
  Re-add dockerfile contents to install PDAL/PRC.
  Commit: 4d3aac5420f5081576631c30962d408260cca682
      https://github.com/PDAL/PDAL/commit/4d3aac5420f5081576631c30962d408260cca682
  Date:   2016-07-27 (Wed, 27 Jul 2016)
  Changed paths:
    M src/Kernel.cpp
    M test/unit/KernelTest.cpp
  Log Message:
  Throw an error if a stage option is provided without a value.
  Commit: e0a47569e1d00f5876850a7a13e50491e55b6614
      https://github.com/PDAL/PDAL/commit/e0a47569e1d00f5876850a7a13e50491e55b6614
  Date:   2016-07-29 (Fri, 29 Jul 2016)
  Changed paths:
  Log Message:
  more greyhound
  Commit: ab89c88d32f5331fa021e58044266e898d4f7a0d
      https://github.com/PDAL/PDAL/commit/ab89c88d32f5331fa021e58044266e898d4f7a0d
  Changed paths:
    M src/Kernel.cpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/a47f36f0b004...ab89c88d32f5
More information about the pdal-commits mailing list
