[pdal-commits] [PDAL/PDAL] 9bbf0d: Separating and refactoring JSON tests
GitHub noreply at github.com
Wed Mar 2 10:31:01 PST 2016
  Branch: refs/heads/json-pipeline
  Home:   https://github.com/PDAL/PDAL
  Commit: 9bbf0d22e60f310c56ad46d2bbead354aa3f7f4a
      https://github.com/PDAL/PDAL/commit/9bbf0d22e60f310c56ad46d2bbead354aa3f7f4a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-03-01 (Tue, 01 Mar 2016)
  Changed paths:
    A test/data/autzen/autzen-interpolate.json.in
    A test/data/autzen/autzen-surface.tif.min.tif
    A test/data/autzen/hag.json.in
    A test/data/autzen/hag.py.in
    M test/data/bpf/bpf2nitf.json.in
    A test/data/qfit/conversion.json.in
    M test/unit/CMakeLists.txt
    M test/unit/apps/pcpipelineTest.cpp
    A test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Commit: 5cc8e009970f3e3b540344b0f648764bc801a362
      https://github.com/PDAL/PDAL/commit/5cc8e009970f3e3b540344b0f648764bc801a362
  Date:   2016-03-02 (Wed, 02 Mar 2016)
  Changed paths:
    M test/data/filters/colorize.json.in
    M test/data/filters/decimate.json.in
  Log Message:
  Use smaller file for colorization test, remove colorization from decimation test
  Commit: 513e8c1812e940f1ed71d29688096ecb6de97441
      https://github.com/PDAL/PDAL/commit/513e8c1812e940f1ed71d29688096ecb6de97441
  Changed paths:
    R test/data/io/p2g-writer.json.in
    A test/data/pipeline/crop.json.in
    R test/data/pipeline/drop_color.json.in
    A test/data/pipeline/p2g-writer.json.in
    R test/data/pipeline/pipeline_interpolate.json.in
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Begin moving and renaming tests
  Commit: 1c75c5153c3e5ea82570ea9a0d59324d5311840d
      https://github.com/PDAL/PDAL/commit/1c75c5153c3e5ea82570ea9a0d59324d5311840d
  Changed paths:
    R include/pdal/PipelineReaderJSON.hpp
    R include/pdal/PipelineReaderXML.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M src/CMakeLists.txt
    M src/PipelineManager.cpp
    M src/PipelineReaderJSON.cpp
    A src/PipelineReaderJSON.hpp
    M src/PipelineReaderXML.cpp
    A src/PipelineReaderXML.hpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/json-pipeline' into json-pipeline
  Commit: 4c90b1a057e2c09b3bb421c8d497ca3da6bbdd22
      https://github.com/PDAL/PDAL/commit/4c90b1a057e2c09b3bb421c8d497ca3da6bbdd22
  Changed paths:
    R test/data/autzen/hag.json.in
    R test/data/bpf/bpf.json.in
    R test/data/bpf/bpf2nitf.json.in
    R test/data/filters/attribute.json.in
    R test/data/filters/chip.json.in
    R test/data/filters/chipper.json.in
    R test/data/filters/colorize-multi.json.in
    R test/data/filters/colorize.json.in
    R test/data/filters/crop_wkt.json.in
    R test/data/filters/crop_wkt_2d.json.in
    R test/data/filters/crop_wkt_2d_classification.json.in
    R test/data/filters/decimate.json.in
    R test/data/filters/ferry.json.in
    R test/data/filters/hexbin-info.json.in
    R test/data/filters/hexbin.json.in
    R test/data/filters/merge.json.in
    R test/data/filters/range_classification.json.in
    R test/data/filters/range_z.json.in
    R test/data/filters/range_z_classification.json.in
    R test/data/filters/reproject.json.in
    R test/data/filters/sort.json.in
    R test/data/filters/splitter.json.in
    R test/data/filters/stats.json.in
    R test/data/hole/crop.json.in
    R test/data/io/text-writer-csv.json.in
    R test/data/io/text-writer-geojson.json.in
    R test/data/io/text-writer-space-delimited.json.in
    R test/data/nitf/chipper.json.in
    R test/data/nitf/conversion.json.in
    R test/data/nitf/las2nitf.json.in
    R test/data/nitf/write_laz.json.in
    R test/data/nitf/write_options.json.in
    A test/data/pipeline/attribute.json.in
    A test/data/pipeline/bpf2las.json.in
    A test/data/pipeline/bpf2nitf.json.in
    A test/data/pipeline/chipper.json.in
    A test/data/pipeline/colorize-multi.json.in
    A test/data/pipeline/colorize.json.in
    A test/data/pipeline/crop-hole.json.in
    A test/data/pipeline/crop-stats.json.in
    A test/data/pipeline/crop_wkt.json.in
    A test/data/pipeline/crop_wkt_2d.json.in
    A test/data/pipeline/crop_wkt_2d_classification.json.in
    A test/data/pipeline/decimate.json.in
    A test/data/pipeline/ferry-reproject.json.in
    A test/data/pipeline/from-module.json.in
    A test/data/pipeline/hexbin-info.json.in
    A test/data/pipeline/hexbin.json.in
    A test/data/pipeline/las2csv.json.in
    A test/data/pipeline/las2geojson.json.in
    A test/data/pipeline/las2nitf-2.json.in
    A test/data/pipeline/las2nitf-crop-with-options.json.in
    A test/data/pipeline/las2nitf.json.in
    A test/data/pipeline/las2space-delimited.json.in
    A test/data/pipeline/merge.json.in
    A test/data/pipeline/metadata_reader.json.in
    A test/data/pipeline/metadata_writer.json.in
    A test/data/pipeline/mississippi.json.in
    A test/data/pipeline/mississippi_reverse.json.in
    A test/data/pipeline/nitf-chipper.json.in
    A test/data/pipeline/nitf2las.json.in
    R test/data/pipeline/pipeline_metadata_reader.json.in
    R test/data/pipeline/pipeline_metadata_writer.json.in
    R test/data/pipeline/pipeline_mississippi.json.in
    R test/data/pipeline/pipeline_mississippi_reverse.json.in
    R test/data/pipeline/pipeline_multioptions.json.in
    R test/data/pipeline/pipeline_read.json.in
    R test/data/pipeline/pipeline_read_notype.json.in
    R test/data/pipeline/pipeline_write.json.in
    R test/data/pipeline/pipeline_write2.json.in
    A test/data/pipeline/predicate-embed.json.in
    A test/data/pipeline/predicate-keep-ground-and-unclass.json.in
    A test/data/pipeline/predicate-keep-last-return.json.in
    A test/data/pipeline/predicate-keep-specified-returns.json.in
    A test/data/pipeline/programmable-hag.json.in
    A test/data/pipeline/programmable-update-y-dims.json.in
    A test/data/pipeline/qfit2las.json.in
    A test/data/pipeline/range_classification.json.in
    A test/data/pipeline/range_z.json.in
    A test/data/pipeline/range_z_classification.json.in
    A test/data/pipeline/reproject.json.in
    A test/data/pipeline/sbet2txt.json.in
    A test/data/pipeline/sort.json.in
    A test/data/pipeline/splitter.json.in
    A test/data/pipeline/stats.json.in
    R test/data/plang/from-module.json.in
    R test/data/plang/predicate-embed.json.in
    R test/data/plang/predicate-keep-ground-and-unclass.json.in
    R test/data/plang/predicate-keep-last-return.json.in
    R test/data/plang/predicate-keep-specified-returns.json.in
    R test/data/plang/programmable-update-y-dims.json.in
    R test/data/qfit/conversion.json.in
    R test/data/sbet/pipeline.json.in
  Log Message:
  Test updates
* Moving the JSON pipeline tests all to test/data/pipeline
* Grouping tests by those available in the base PDAL and those available via plugins
* Renaming pipelines to be a little more desriptive
* Deleting some pipelines that appeared to be redundant
  Commit: 6d7668d69fe35aecf6f4cbe48d6fae5a70c80801
      https://github.com/PDAL/PDAL/commit/6d7668d69fe35aecf6f4cbe48d6fae5a70c80801
  Changed paths:
  Log Message:
  Missed a comma. Build JSON tests always (when WITH_APPS=ON)
Compare: https://github.com/PDAL/PDAL/compare/de3cd1a89a19...6d7668d69fe3
More information about the pdal-commits mailing list
