[pdal-commits] [PDAL/PDAL] 9e5620: Simplify some logic with no behavior change.
GitHub noreply at github.com
Wed Mar 2 12:48:47 PST 2016
  Branch: refs/heads/json-pipeline
  Home:   https://github.com/PDAL/PDAL
  Commit: 9e56202563e61b074c9232a21ce3d66739be84aa
      https://github.com/PDAL/PDAL/commit/9e56202563e61b074c9232a21ce3d66739be84aa
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-03-02 (Wed, 02 Mar 2016)
  Changed paths:
    M src/PipelineReaderJSON.cpp
  Log Message:
  Commit: 74e182c1e0078261070ad856652ae7e71893702f
      https://github.com/PDAL/PDAL/commit/74e182c1e0078261070ad856652ae7e71893702f
  Changed paths:
    A test/data/autzen/autzen-interpolate.json.in
    A test/data/autzen/autzen-surface.tif.min.tif
    A test/data/autzen/hag.py.in
    R test/data/bpf/bpf.json.in
    R test/data/bpf/bpf2nitf.json.in
    R test/data/filters/attribute.json.in
    R test/data/filters/chip.json.in
    R test/data/filters/chipper.json.in
    R test/data/filters/colorize-multi.json.in
    R test/data/filters/colorize.json.in
    R test/data/filters/crop_wkt.json.in
    R test/data/filters/crop_wkt_2d.json.in
    R test/data/filters/crop_wkt_2d_classification.json.in
    R test/data/filters/decimate.json.in
    R test/data/filters/hexbin-info.json.in
    R test/data/filters/hexbin.json.in
    R test/data/filters/range_classification.json.in
    R test/data/filters/range_z.json.in
    R test/data/filters/range_z_classification.json.in
    R test/data/filters/reproject.json.in
    R test/data/filters/splitter.json.in
    R test/data/filters/stats.json.in
    R test/data/hole/crop.json.in
    R test/data/io/p2g-writer.json.in
    R test/data/io/text-writer-csv.json.in
    R test/data/io/text-writer-geojson.json.in
    R test/data/io/text-writer-space-delimited.json.in
    R test/data/nitf/conversion.json.in
    R test/data/nitf/las2nitf.json.in
    R test/data/nitf/write_laz.json.in
    R test/data/nitf/write_options.json.in
    A test/data/pipeline/attribute.json.in
    A test/data/pipeline/bpf2las.json.in
    A test/data/pipeline/bpf2nitf.json.in
    A test/data/pipeline/chipper.json.in
    A test/data/pipeline/colorize-multi.json.in
    A test/data/pipeline/colorize.json.in
    A test/data/pipeline/crop-hole.json.in
    A test/data/pipeline/crop-stats.json.in
    A test/data/pipeline/crop.json.in
    A test/data/pipeline/crop_wkt.json.in
    A test/data/pipeline/crop_wkt_2d.json.in
    A test/data/pipeline/crop_wkt_2d_classification.json.in
    A test/data/pipeline/decimate.json.in
    R test/data/pipeline/drop_color.json.in
    A test/data/pipeline/ferry-reproject.json.in
    A test/data/pipeline/from-module.json.in
    A test/data/pipeline/hexbin-info.json.in
    A test/data/pipeline/hexbin.json.in
    A test/data/pipeline/las2csv.json.in
    A test/data/pipeline/las2geojson.json.in
    A test/data/pipeline/las2nitf-2.json.in
    A test/data/pipeline/las2nitf-crop-with-options.json.in
    A test/data/pipeline/las2nitf.json.in
    A test/data/pipeline/las2space-delimited.json.in
    A test/data/pipeline/merge.json.in
    A test/data/pipeline/metadata_reader.json.in
    A test/data/pipeline/metadata_writer.json.in
    A test/data/pipeline/mississippi.json.in
    A test/data/pipeline/mississippi_reverse.json.in
    A test/data/pipeline/nitf-chipper.json.in
    A test/data/pipeline/nitf2las.json.in
    A test/data/pipeline/p2g-writer.json.in
    R test/data/pipeline/pipeline_interpolate.json.in
    R test/data/pipeline/pipeline_metadata_reader.json.in
    R test/data/pipeline/pipeline_metadata_writer.json.in
    R test/data/pipeline/pipeline_mississippi.json.in
    R test/data/pipeline/pipeline_mississippi_reverse.json.in
    R test/data/pipeline/pipeline_multioptions.json.in
    R test/data/pipeline/pipeline_read.json.in
    R test/data/pipeline/pipeline_read_notype.json.in
    R test/data/pipeline/pipeline_write.json.in
    R test/data/pipeline/pipeline_write2.json.in
    A test/data/pipeline/predicate-embed.json.in
    A test/data/pipeline/predicate-keep-ground-and-unclass.json.in
    A test/data/pipeline/predicate-keep-last-return.json.in
    A test/data/pipeline/predicate-keep-specified-returns.json.in
    A test/data/pipeline/programmable-hag.json.in
    A test/data/pipeline/programmable-update-y-dims.json.in
    A test/data/pipeline/qfit2las.json.in
    A test/data/pipeline/range_classification.json.in
    A test/data/pipeline/range_z.json.in
    A test/data/pipeline/range_z_classification.json.in
    A test/data/pipeline/reproject.json.in
    A test/data/pipeline/sbet2txt.json.in
    A test/data/pipeline/sort.json.in
    A test/data/pipeline/splitter.json.in
    A test/data/pipeline/stats.json.in
    R test/data/plang/predicate-keep-ground-and-unclass.json.in
    R test/data/plang/predicate-keep-last-return.json.in
    R test/data/plang/predicate-keep-specified-returns.json.in
    M test/unit/CMakeLists.txt
    M test/unit/apps/pcpipelineTest.cpp
    A test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Merge remote-tracking branch 'origin/json-pipeline' into json-pipeline
Compare: https://github.com/PDAL/PDAL/compare/feb0d181fd06...74e182c1e007
More information about the pdal-commits mailing list
