[pdal-commits] [PDAL/PDAL] a38875: Enable testing prior to adding plugins directory (...
GitHub noreply at github.com
Thu Mar 3 08:34:51 PST 2016
  Branch: refs/heads/issue/1169-nitf-tests
  Home:   https://github.com/PDAL/PDAL
  Commit: a38875467ecd9275f6dc73996cad089e9fca90f2
      https://github.com/PDAL/PDAL/commit/a38875467ecd9275f6dc73996cad089e9fca90f2
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-03-01 (Tue, 01 Mar 2016)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Enable testing prior to adding plugins directory (which includes tests)
  Commit: 72599f65e976c0b38da044f7cd9bf56279e53275
      https://github.com/PDAL/PDAL/commit/72599f65e976c0b38da044f7cd9bf56279e53275
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Only enable testing before adding plugins
  Commit: 4ebbbb8b993ea17236bbb25b54658612fb42e52b
      https://github.com/PDAL/PDAL/commit/4ebbbb8b993ea17236bbb25b54658612fb42e52b
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/test/CpdKernelTest.cpp
    M plugins/oci/test/OCITest.cpp
  Log Message:
  Fix compilation issues.
  Commit: 2a106a3bd80c0f5781fe95f366694b1743e1c869
      https://github.com/PDAL/PDAL/commit/2a106a3bd80c0f5781fe95f366694b1743e1c869
  Changed paths:
    M plugins/python/test/PLangTest.cpp
  Log Message:
  Delete StageFactory (and hence stage) to force log output to be written.
  Commit: 1e3bb0cbfc679de4159dd4da728f4e8ab828b906
      https://github.com/PDAL/PDAL/commit/1e3bb0cbfc679de4159dd4da728f4e8ab828b906
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #1170 from PDAL/enable-testing-before-adding-plugins
Enable testing before adding plugins
  Commit: 357a283db6f1a340e214afeca74c672607aa9c26
      https://github.com/PDAL/PDAL/commit/357a283db6f1a340e214afeca74c672607aa9c26
  Changed paths:
    M include/pdal/plang/Redirector.hpp
    M src/plang/Redirector.cpp
  Log Message:
  Have python stream flush actually do something.
Make python log test more robust.
  Commit: 12667f2c6cdbf92890958c25b710b472050210b0
      https://github.com/PDAL/PDAL/commit/12667f2c6cdbf92890958c25b710b472050210b0
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 7b602d309d18575baac6958ed68bf1d5947187cd
      https://github.com/PDAL/PDAL/commit/7b602d309d18575baac6958ed68bf1d5947187cd
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-03-02 (Wed, 02 Mar 2016)
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
  Log Message:
  checkout LASzip to a known sha now that master is being refactored
  Commit: 86b9b5d24934fc2b887aa94241878ecd28054161
      https://github.com/PDAL/PDAL/commit/86b9b5d24934fc2b887aa94241878ecd28054161
  Date:   2016-03-03 (Thu, 03 Mar 2016)
  Changed paths:
    M filters/colorization/ColorizationFilter.cpp
    M include/pdal/Dimension.hpp
    M include/pdal/PointLayout.hpp
    M src/PointLayout.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
  Log Message:
  Handle dimension names names flexibly in colorization filter.
Provide better error message for bad dimension info.
  Commit: 204593c32bf3b8c026b07028b40ec6836c4b1ae9
      https://github.com/PDAL/PDAL/commit/204593c32bf3b8c026b07028b40ec6836c4b1ae9
  Changed paths:
  Log Message:
  Commit: dbadec23cdbaf6550151059ebc8d26ca6883b43c
      https://github.com/PDAL/PDAL/commit/dbadec23cdbaf6550151059ebc8d26ca6883b43c
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge remote-tracking branch 'origin/master' into nitf
  Commit: b5cf132eff020251f64d43ceb89024897ecbeaa0
      https://github.com/PDAL/PDAL/commit/b5cf132eff020251f64d43ceb89024897ecbeaa0
  Changed paths:
    M include/pdal/Options.hpp
    M plugins/nitf/io/MetadataReader.cpp
    M plugins/nitf/io/NitfWriter.cpp
    M test/data/bpf/bpf2nitf.xml.in
    M test/data/nitf/las2nitf.xml.in
    M test/data/nitf/write_laz.xml.in
  Log Message:
  Fix population of AIMIDB and ACFTB fields in NITF writer.
Fix various options in pipeline files.
Improve error message on failed option conversions.
Compare: https://github.com/PDAL/PDAL/compare/9ef96de9affe...b5cf132eff02
More information about the pdal-commits mailing list
