[pdal-commits] [PDAL/PDAL] fcd903: With GDAL and GEOS being hard dependencies for PDA...
GitHub noreply at github.com
Thu Mar 3 09:43:31 PST 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: fcd903c40f3c9aa65faa085c6511c7673096ea82
      https://github.com/PDAL/PDAL/commit/fcd903c40f3c9aa65faa085c6511c7673096ea82
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-03-03 (Thu, 03 Mar 2016)
  Changed paths:
    M CMakeLists.txt
    M filters/CMakeLists.txt
    A filters/attribute/AttributeFilter.cpp
    A filters/attribute/AttributeFilter.hpp
    A filters/attribute/CMakeLists.txt
    M plugins/CMakeLists.txt
    R plugins/attribute/CMakeLists.txt
    R plugins/attribute/filters/AttributeFilter.cpp
    R plugins/attribute/filters/AttributeFilter.hpp
    R plugins/attribute/test/AttributeFilterTest.cpp
    M src/StageFactory.cpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/AttributeFilterTest.cpp
  Log Message:
  With GDAL and GEOS being hard dependencies for PDAL, move the attribute filter out of the "plugins" category
  Commit: 6fb051ec3d7b2e334d1c629824c0d2a028f6e5c9
      https://github.com/PDAL/PDAL/commit/6fb051ec3d7b2e334d1c629824c0d2a028f6e5c9
  Changed paths:
    M scripts/appveyor/config.cmd
    M scripts/ci/script.sh
    M scripts/docker/Dockerfile
    M scripts/linux-install-scripts/pdal.sh
  Log Message:
  BUILD_PLUGIN_ATTRIBUTE is no longer relevant
  Commit: f1d793b9dda5a3c530562203d9ca6fe4c0ae9a67
      https://github.com/PDAL/PDAL/commit/f1d793b9dda5a3c530562203d9ca6fe4c0ae9a67
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #1171 from PDAL/attributes-no-longer-a-plugin
Attribute filter is no longer a (shared) plugin
Compare: https://github.com/PDAL/PDAL/compare/204593c32bf3...f1d793b9dda5
More information about the pdal-commits mailing list
