[pdal-commits] [PDAL/PDAL] f03d9f: tindex option can't be optional
GitHub noreply at github.com
Sun Mar 13 22:05:51 PDT 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: f03d9f4ec06c48f7fcc436016edcd6a70aff0d81
      https://github.com/PDAL/PDAL/commit/f03d9f4ec06c48f7fcc436016edcd6a70aff0d81
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-03-11 (Fri, 11 Mar 2016)
  Changed paths:
    M kernels/tindex/TIndexKernel.cpp
  Log Message:
  Commit: 7ae638b28691ae8bf55196ba2dbc422e29c329f6
      https://github.com/PDAL/PDAL/commit/7ae638b28691ae8bf55196ba2dbc422e29c329f6
  Date:   2016-03-13 (Sun, 13 Mar 2016)
  Changed paths:
    M cmake/examples/hobu-config.sh
    M kernels/CMakeLists.txt
    A kernels/density/CMakeLists.txt
    A kernels/density/DensityKernel.cpp
    A kernels/density/DensityKernel.hpp
    A kernels/density/OGR.cpp
    A kernels/density/OGR.hpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/hexbin/filters/HexBin.hpp
    M test/data/autzen/hag.py
  Log Message:
  add density kernel (in the wrong place)
  Commit: db198f4741f77cb142c415f5dded56f73830661a
      https://github.com/PDAL/PDAL/commit/db198f4741f77cb142c415f5dded56f73830661a
  Changed paths:
    M src/PluginManager.cpp
  Log Message:
  slightly improve error message when a plugin doesn't load
  Commit: 987e5502b342f0f276c946f05472ca5f3e1912bc
      https://github.com/PDAL/PDAL/commit/987e5502b342f0f276c946f05472ca5f3e1912bc
  Changed paths:
    M src/Kernel.cpp
  Log Message:
  s/XML/JSON
  Commit: f0ba634d82cdab66eb448ddb12fcd78ccffc90ef
      https://github.com/PDAL/PDAL/commit/f0ba634d82cdab66eb448ddb12fcd78ccffc90ef
  Changed paths:
    M .gitignore
    M doc/apps.rst
    R kernels/density/CMakeLists.txt
    R kernels/density/DensityKernel.cpp
    R kernels/density/DensityKernel.hpp
    R kernels/density/OGR.cpp
    R kernels/density/OGR.hpp
    M plugins/hexbin/CMakeLists.txt
    A plugins/hexbin/kernel/DensityKernel.cpp
    A plugins/hexbin/kernel/DensityKernel.hpp
    A plugins/hexbin/kernel/OGR.cpp
    A plugins/hexbin/kernel/OGR.hpp
    M scripts/docker/dependencies/Dockerfile
  Log Message:
  add 'pdal density' command to generate OGR hexbin surfaces of point clouds
  Commit: 874e5f2e1a5ede852cd2ac0c097f050d64e29c36
      https://github.com/PDAL/PDAL/commit/874e5f2e1a5ede852cd2ac0c097f050d64e29c36
  Date:   2016-03-14 (Mon, 14 Mar 2016)
  Changed paths:
    M .gitignore
    M doc/apps.rst
    M src/Kernel.cpp
  Log Message:
  Merge pull request #1179 from PDAL/density-kernel
Density kernel
Compare: https://github.com/PDAL/PDAL/compare/40df4b6bbf70...874e5f2e1a5e
More information about the pdal-commits mailing list
