[pdal-commits] [PDAL/PDAL] 5ee228: XML->JSON for all stage documentation
GitHub noreply at github.com
Fri Mar 25 09:36:46 PDT 2016
  Branch: refs/heads/issues/1188
  Home:   https://github.com/PDAL/PDAL
  Commit: 5ee2288a849f18de286c6391e2cc6aff706bfbdb
      https://github.com/PDAL/PDAL/commit/5ee2288a849f18de286c6391e2cc6aff706bfbdb
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-03-24 (Thu, 24 Mar 2016)
  Changed paths:
    M doc/pipeline.rst
    M doc/stages/filters.attribute.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.divider.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.greedyprojection.rst
    M doc/stages/filters.gridprojection.rst
    M doc/stages/filters.ground.rst
    M doc/stages/filters.height.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    M doc/stages/filters.movingleastsquares.rst
    M doc/stages/filters.poisson.rst
    M doc/stages/filters.predicate.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.randomize.rst
    M doc/stages/filters.range.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.splitter.rst
    M doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/filters.voxelgrid.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.oci.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tindex.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.derivative.rst
    M doc/stages/writers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.matlab.rst
    M doc/stages/writers.nitf.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.oci.rst
    M doc/stages/writers.p2g.rst
    M doc/stages/writers.pcd.rst
    M doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.rialto.rst
    M doc/stages/writers.sqlite.rst
    M doc/stages/writers.text.rst
    M examples/writing-kernel/MyKernel.cpp
  Log Message:
  Commit: 96a6cef11df42abb036bd53ea58179180cf16ac1
      https://github.com/PDAL/PDAL/commit/96a6cef11df42abb036bd53ea58179180cf16ac1
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M src/GlobalEnvironment.cpp
  Log Message:
  Fix typo.
  Commit: b4627117dd61e623c491e1ad418d63b602ecc9cd
      https://github.com/PDAL/PDAL/commit/b4627117dd61e623c491e1ad418d63b602ecc9cd
  Changed paths:
    M doc/pipeline.rst
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 1111137bb17abb250082112e3eb72e1ce6778dc3
      https://github.com/PDAL/PDAL/commit/1111137bb17abb250082112e3eb72e1ce6778dc3
  Changed paths:
  Log Message:
  typo
  Commit: 080e614bd975aa3784a463a8a0b50885bc65c726
      https://github.com/PDAL/PDAL/commit/080e614bd975aa3784a463a8a0b50885bc65c726
  Author: Raphael Kubo da Costa <rakuco at FreeBSD.org>
  Date:   2016-03-25 (Fri, 25 Mar 2016)
  Changed paths:
    M src/util/CMakeLists.txt
  Log Message:
  Link against ${CMAKE_DL_LIBS} instead of libdl.
-dl only exists on Linux, so linking fails on other OSes like FreeBSD.
Use the portable CMAKE_DL_LIBS variable instead.
  Commit: ee1ba13d6323370c06d26e726eb534b6b9624035
      https://github.com/PDAL/PDAL/commit/ee1ba13d6323370c06d26e726eb534b6b9624035
  Changed paths:
  Log Message:
  Merge pull request #1195 from rakuco/cmake-dl
  Commit: 5443d3aacadd4a11301ef31e0be424b038d88007
      https://github.com/PDAL/PDAL/commit/5443d3aacadd4a11301ef31e0be424b038d88007
  Changed paths:
    M src/Polygon.cpp
  Log Message:
  use GEOS' envelope for computing Polygon::bounds
  Commit: 51e04198eb4cc450bf8fb48ef2d3eb420f92fdc9
      https://github.com/PDAL/PDAL/commit/51e04198eb4cc450bf8fb48ef2d3eb420f92fdc9
  Changed paths:
    M plugins/hexbin/filters/HexBin.cpp
  Log Message:
  codger up a UTM-based density computation if the SRS is geographic
  Commit: fc9cb3cae6035a3a3b203b5bc6b159aa8d5f49f6
      https://github.com/PDAL/PDAL/commit/fc9cb3cae6035a3a3b203b5bc6b159aa8d5f49f6
  Changed paths:
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 38b0aa91665f34f79d090251a3f76210c28af91a
      https://github.com/PDAL/PDAL/commit/38b0aa91665f34f79d090251a3f76210c28af91a
  Changed paths:
    M src/Polygon.cpp
  Log Message:
  better handle Multi* geometry in Polygon::bounds() computation
  Commit: 7b9e6794c76c08858fd2966b0a12bcbac309c11a
      https://github.com/PDAL/PDAL/commit/7b9e6794c76c08858fd2966b0a12bcbac309c11a
  Changed paths:
    M doc/pipeline.rst
  Log Message:
  no more dolls (dammit). note aboute JSON being preferred over XML
  Commit: 4a8a59d0ad661f91b7d1b6a376a34c7af77e1984
      https://github.com/PDAL/PDAL/commit/4a8a59d0ad661f91b7d1b6a376a34c7af77e1984
  Changed paths:
    M io/las/LasHeader.cpp
  Log Message:
  both WKT and GeoTIFF VLRs is now a debug message instead of Error
  Commit: b7bbee0decbdff3b8e887be3b66fa3ebd6916b13
      https://github.com/PDAL/PDAL/commit/b7bbee0decbdff3b8e887be3b66fa3ebd6916b13
  Author: Connor Manning <connor at hobu.co>
  Changed paths:
    M doc/pipeline.rst
    M src/Polygon.cpp
  Log Message:
  Merge branch 'master' into issues/1188
Compare: https://github.com/PDAL/PDAL/compare/bce8c299d9a6...b7bbee0decbd
More information about the pdal-commits mailing list
