[pdal-commits] [PDAL/PDAL] d9c270: Use proper function to determine dimension existen...
GitHub noreply at github.com
Fri Nov 11 06:30:03 PST 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: d9c270003372317cbd4a39e1930224467db5cf86
      https://github.com/PDAL/PDAL/commit/d9c270003372317cbd4a39e1930224467db5cf86
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-11-11 (Fri, 11 Nov 2016)
  Changed paths:
    M io/gdal/GDALWriter.cpp
    M io/gdal/GDALWriter.hpp
    M test/unit/io/gdal/GDALWriterTest.cpp
  Log Message:
  Use proper function to determine dimension existence.
Close #1379
  Commit: 2f57c0cf1703af51498f9dae71c9a70128c4c93a
      https://github.com/PDAL/PDAL/commit/2f57c0cf1703af51498f9dae71c9a70128c4c93a
  Changed paths:
    A doc/stages/filters.kdistance.rst
    A doc/stages/filters.radialdensity.rst
    M filters/CMakeLists.txt
    A filters/kdistance/CMakeLists.txt
    A filters/kdistance/KDistanceFilter.cpp
    A filters/kdistance/KDistanceFilter.hpp
    A filters/radialdensity/CMakeLists.txt
    A filters/radialdensity/RadialDensityFilter.cpp
    A filters/radialdensity/RadialDensityFilter.hpp
    M include/pdal/KDIndex.hpp
    M src/StageFactory.cpp
    M test/unit/KDIndexTest.cpp
    M test/unit/apps/TranslateTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/035ebef17e43...2f57c0cf1703
More information about the pdal-commits mailing list
