[pdal-commits] [PDAL/PDAL] 4d43c6: Windows 2015 warnings rollup (#1383)
GitHub noreply at github.com
Sun Nov 13 06:24:31 PST 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 4d43c6598ab807f02d506a4583a46e83f3e5cecb
      https://github.com/PDAL/PDAL/commit/4d43c6598ab807f02d506a4583a46e83f3e5cecb
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-11-13 (Sun, 13 Nov 2016)
  Changed paths:
    M cmake/examples/hobu-windows.bat
    M cmake/modules/FindJSONCPP.cmake
    M filters/chipper/ChipperFilter.cpp
    M filters/transformation/TransformationFilter.cpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/PointLayout.hpp
    M include/pdal/pdal_macros.hpp
    M include/pdal/plang/Redirector.hpp
    M io/ilvis2/Ilvis2MetadataReader.cpp
    M io/las/SummaryData.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/nitf/io/tre_plugins.hpp
    M plugins/oci/io/OciCommon.hpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/GDALUtils.cpp
    M src/PipelineReaderXML.cpp
    M src/Polygon.cpp
    M src/SpatialReference.cpp
    M src/plang/Invocation.cpp
    M src/plang/Redirector.cpp
    M test/unit/BoundsTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/io/optech/OptechReaderTest.cpp
  Log Message:
* STL exporting
Only export functions, not entire class to shut up MSVC about exporting
STL containers
* windows warnings
* cmake warning
* my current configuration
* more windows warnings
* missing PDAL_DLL decl
* Make sure to initialize Everything union
* Only filters.chipper uses lround. Move it into that filter instead of globally
* hobu's current cmake configu that works
* windows warning patrol
* Refactor pg_query_once to return string instead of char* which we end up leaking
* warnings about DLL import redefinition
* unused var
* mismatched types warning
* comparison warnings
* I build project files now
* silence PyTuple_GetItem argument warning
* conversion to doubles warnings
* inconsistent dll linkage w/ python
* more accurate test output
* don't explicitly initialize Everything
* truncation warning in OCI driver
More information about the pdal-commits mailing list
