[pdal-commits] [PDAL/PDAL] f0edd5: Add a filter to compute the range from the sensor ...
GitHub noreply at github.com
Tue Nov 15 09:43:25 PST 2016
  Branch: refs/heads/adding-dimensions-in-test
  Home:   https://github.com/PDAL/PDAL
  Commit: f0edd52c3d0b4eea845236f579d7e4459beafce8
      https://github.com/PDAL/PDAL/commit/f0edd52c3d0b4eea845236f579d7e4459beafce8
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-11-14 (Mon, 14 Nov 2016)
  Changed paths:
    A doc/stages/filters.computerange.rst
    M filters/CMakeLists.txt
    A filters/computerange/CMakeLists.txt
    A filters/computerange/ComputeRangeFilter.cpp
    A filters/computerange/ComputeRangeFilter.hpp
    M src/StageFactory.cpp
  Log Message:
  Add a filter to compute the range from the sensor to each return
This only applies to data having frame and pixel numbers, and sensor coords
marked by pixel number equal to -5.
  Commit: 84e2b9bb7147792206b7529691ffc3752f24a511
      https://github.com/PDAL/PDAL/commit/84e2b9bb7147792206b7529691ffc3752f24a511
  Changed paths:
    M filters/computerange/ComputeRangeFilter.cpp
  Log Message:
  Minor change, a little more to the point when checking for required dims
  Commit: abf7fde86e731fc8ffb3c1f077a40faa88e59ec2
      https://github.com/PDAL/PDAL/commit/abf7fde86e731fc8ffb3c1f077a40faa88e59ec2
  Changed paths:
  Log Message:
  No need to registerOrAssign when grabbing reference to frame and pixel number dims
  Commit: f29dbb396c4fde9d5a89d7b95ad9ced040c94e86
      https://github.com/PDAL/PDAL/commit/f29dbb396c4fde9d5a89d7b95ad9ced040c94e86
  Changed paths:
    M test/unit/CMakeLists.txt
    A test/unit/filters/ComputeRangeFilterTest.cpp
  Log Message:
  Tests WIP
  Commit: 3394e634f8d3e2ae1596ab9f58c3a7f31d79c12e
      https://github.com/PDAL/PDAL/commit/3394e634f8d3e2ae1596ab9f58c3a7f31d79c12e
  Date:   2016-11-15 (Tue, 15 Nov 2016)
  Changed paths:
    M test/unit/filters/ComputeRangeFilterTest.cpp
  Log Message:
  minor refactor, troubleshooting tests
  Commit: 931589e73779161f66d0402e20333f191bc4270e
      https://github.com/PDAL/PDAL/commit/931589e73779161f66d0402e20333f191bc4270e
  Changed paths:
    M filters/computerange/ComputeRangeFilter.hpp
  Log Message:
  simplify example to illustrate my issue
Compare: https://github.com/PDAL/PDAL/compare/f0edd52c3d0b^...931589e73779
More information about the pdal-commits mailing list
