[pdal-commits] [PDAL/PDAL] 42acc9: doc typo
GitHub noreply at github.com
Tue Aug 29 16:30:38 PDT 2017
  Branch: refs/heads/gdalwriter
  Home:   https://github.com/PDAL/PDAL
  Commit: 42acc975d9e39fc51f9323d87cd2ceeb82b2f48f
      https://github.com/PDAL/PDAL/commit/42acc975d9e39fc51f9323d87cd2ceeb82b2f48f
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-08-22 (Tue, 22 Aug 2017)
  Changed paths:
    M doc/stages/writers.las.rst
  Log Message:
  doc typo
  Commit: 2d3e2c8eb077773d584a8e850339ae58ab04e801
      https://github.com/PDAL/PDAL/commit/2d3e2c8eb077773d584a8e850339ae58ab04e801
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-08-23 (Wed, 23 Aug 2017)
  Changed paths:
    M plugins/cpd/filters/CpdFilter.cpp
  Log Message:
  Fix type mismatch in CPD filter.
  Commit: 386093ea08ffb230f181cbae063a185aed994428
      https://github.com/PDAL/PDAL/commit/386093ea08ffb230f181cbae063a185aed994428
  Changed paths:
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Don't run test that requires LAS compression without it being compiled in.
  Commit: b56b699696c111186f5514ef0654720b1a190146
      https://github.com/PDAL/PDAL/commit/b56b699696c111186f5514ef0654720b1a190146
  Date:   2017-08-24 (Thu, 24 Aug 2017)
  Changed paths:
    M doc/faq.rst
  Log Message:
  Add an FAQ about missing plugins.
  Commit: 9636f052b0682e46cb72bdb726d9b4164613de1c
      https://github.com/PDAL/PDAL/commit/9636f052b0682e46cb72bdb726d9b4164613de1c
  Changed paths:
    M doc/faq.rst
  Log Message:
  Fix a typo.
  Commit: ce970a5da0966f43269f76448b0a584d0e21580c
      https://github.com/PDAL/PDAL/commit/ce970a5da0966f43269f76448b0a584d0e21580c
  Author: Adam Steer <adamsteer at users.noreply.github.com>
  Changed paths:
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.mbio.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.pts.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.sbet.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tindex.rst
  Log Message:
  #1591: add --count to html docs (#1649)
* add --count option
* does readers.buffer have a --count option? not listed in --options
* add a needed comma to the LAS pipeline
* actually not sure if readers.mrsid has --count, not available in my docker instance
* removed duplicate spatialreference option heading
* add --count option (#1591)
  Commit: 3d1cf9b6d41d3c02101e49abe459957ada1aa6a0
      https://github.com/PDAL/PDAL/commit/3d1cf9b6d41d3c02101e49abe459957ada1aa6a0
  Date:   2017-08-25 (Fri, 25 Aug 2017)
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  don't attempt to write a pdal_metadata VLR if > LasVLR::MAX_DATA_SIZE and minor_version < 4
  Commit: 5ffbe16cce461a4c23d46b48dd99e2862014c404
      https://github.com/PDAL/PDAL/commit/5ffbe16cce461a4c23d46b48dd99e2862014c404
  Date:   2017-08-28 (Mon, 28 Aug 2017)
  Changed paths:
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M pdal/DimUtil.hpp
  Log Message:
  Add support for string to/from dimension type conversion.
  Commit: fba770e8ab7fb76f356b6fef1114d5f997253f50
      https://github.com/PDAL/PDAL/commit/fba770e8ab7fb76f356b6fef1114d5f997253f50
  Changed paths:
    M doc/faq.rst
    M io/LasWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into gdalwriter
  Commit: 4f25afc7baba8f1931f3273a2dbe28bf61387f4d
      https://github.com/PDAL/PDAL/commit/4f25afc7baba8f1931f3273a2dbe28bf61387f4d
  Changed paths:
  Log Message:
  Fix LASZIP in pipeline test.
  Commit: 31683bcba4d4e9fa2b94b00d501758dfb264e641
      https://github.com/PDAL/PDAL/commit/31683bcba4d4e9fa2b94b00d501758dfb264e641
  Changed paths:
    M io/LasReader.cpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Put encoded LAS VLR in its own node.
Close #1648
  Commit: 2efa431487cc9629594ecbed0b5938b820643029
      https://github.com/PDAL/PDAL/commit/2efa431487cc9629594ecbed0b5938b820643029
  Changed paths:
    M io/LasReader.cpp
  Log Message:
  Merge branch 'master' into gdalwriter
  Commit: 02e7cbaadb4f0b62726805806d22c94db428fe86
      https://github.com/PDAL/PDAL/commit/02e7cbaadb4f0b62726805806d22c94db428fe86
  Date:   2017-08-29 (Tue, 29 Aug 2017)
  Changed paths:
    M io/GDALWriter.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
  Log Message:
  Use various data types for gdal output.
Compare: https://github.com/PDAL/PDAL/compare/6ffcca08e005...02e7cbaadb4f
More information about the pdal-commits mailing list
