[pdal-commits] [PDAL/PDAL] 79bc47: Transform bounding boxes for change in SRS.
GitHub noreply at github.com
Wed Jan 4 11:37:28 PST 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 79bc4732ca71c48d56148b808bdb174f79c888ff
      https://github.com/PDAL/PDAL/commit/79bc4732ca71c48d56148b808bdb174f79c888ff
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-12-23 (Fri, 23 Dec 2016)
  Changed paths:
    M filters/CropFilter.cpp
    M filters/CropFilter.hpp
    M pdal/Stage.cpp
  Log Message:
  Commit: 379e122915e688a47e23f4aa03a2bba3966955e0
      https://github.com/PDAL/PDAL/commit/379e122915e688a47e23f4aa03a2bba3966955e0
  Changed paths:
    A doc/stages/filters.cluster.rst
    A doc/stages/filters.groupby.rst
    A doc/stages/filters.locate.rst
    A filters/ClusterFilter.cpp
    A filters/ClusterFilter.hpp
    A filters/GroupByFilter.cpp
    A filters/GroupByFilter.hpp
    A filters/LocateFilter.cpp
    A filters/LocateFilter.hpp
    M io/GeotiffSupport.cpp
    M io/GeotiffSupport.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M kernels/PipelineKernel.cpp
    M kernels/PipelineKernel.hpp
    M pdal/FlexWriter.hpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    M pdal/PointTable.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageFactory.cpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/GroupByFilterTest.cpp
    A test/unit/filters/LocateFilterTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Merge branch 'master' into geometry
  Commit: ce622672e26bdc306cb84c8b6db4cc7bbd3a4e29
      https://github.com/PDAL/PDAL/commit/ce622672e26bdc306cb84c8b6db4cc7bbd3a4e29
  Date:   2017-01-03 (Tue, 03 Jan 2017)
  Changed paths:
    M HOWTORELEASE.txt
    R Vagrantfile
    M cmake/examples/hobu-config.sh
    M doc/development/compilation/dependencies.rst
    A doc/images/foss4g-2017.png
    M doc/index.rst
    M doc/pipeline.rst
    M doc/stages/filters.reprojection.rst
    R doc/stages/writers.p2g.rst
    R doc/stages/writers.rialto.rst
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    A doc/workshop/exercises/analysis/dtm/gdal.json
    R doc/workshop/exercises/analysis/dtm/p2g.json
    M doc/workshop/slides/source/dtm.rst
    M java/README.md
    M java/build.sbt
    A java/project/Commands.scala
    M java/project/Environment.scala
    M java/scripts/publish-212.sh
    M java/scripts/publish-all.sh
    M java/scripts/publish-javastyle.sh
    A java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M plugins/CMakeLists.txt
    R plugins/p2g/CMakeLists.txt
    R plugins/p2g/io/P2gWriter.cpp
    R plugins/p2g/io/P2gWriter.hpp
    M scripts/appveyor/config.cmd
    M scripts/ci/script.sh
    M scripts/docker/Dockerfile
    M scripts/docker/dependencies/Dockerfile
    M scripts/linux-install-scripts/pdal.sh
  Log Message:
  Merge remote-tracking branch 'origin/master' into geometry
  Commit: 2045f640f5a6cd336e9c8ba86116a0e1dcb8956b
      https://github.com/PDAL/PDAL/commit/2045f640f5a6cd336e9c8ba86116a0e1dcb8956b
  Changed paths:
    M doc/stages/readers.faux.rst
    M io/FauxReader.cpp
    M io/FauxReader.hpp
    M test/unit/io/FauxReaderTest.cpp
  Log Message:
  Add grid mode to faux reader.
  Commit: 4099c0813fc11972caf259a2f186c82a0453538f
      https://github.com/PDAL/PDAL/commit/4099c0813fc11972caf259a2f186c82a0453538f
  Changed paths:
    M cmake/options.cmake
  Log Message:
  Commit: ceffe7e8b79506ab52c17809e642a6a57f437ac4
      https://github.com/PDAL/PDAL/commit/ceffe7e8b79506ab52c17809e642a6a57f437ac4
  Date:   2017-01-04 (Wed, 04 Jan 2017)
  Log Message:
  Commit: fcd6062e08cd9e70e035637f9397b9f543bb01ac
      https://github.com/PDAL/PDAL/commit/fcd6062e08cd9e70e035637f9397b9f543bb01ac
  Changed paths:
    M filters/private/crop/Point.cpp
    M filters/private/crop/Point.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/util/ProgramArgs.hpp
    M test/unit/filters/CropFilterTest.cpp
  Log Message:
  Fix circle/sphere cropping.
Remove use of KDIndex (slow, slow, slow).
Don't allow transformation of any geometry type to polygon.
Compare: https://github.com/PDAL/PDAL/compare/a65aefacb291...fcd6062e08cd
More information about the pdal-commits mailing list
