[pdal-commits] [PDAL/PDAL] e45666: Update EigenUtils
GitHub noreply at github.com
Thu Jan 12 13:17:47 PST 2017
  Branch: refs/heads/python-embed-metadata
  Home:   https://github.com/PDAL/PDAL
  Commit: e45666396d9cbdd20c5e41009639067f953419af
      https://github.com/PDAL/PDAL/commit/e45666396d9cbdd20c5e41009639067f953419af
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-01-05 (Thu, 05 Jan 2017)
  Changed paths:
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M test/unit/EigenTest.cpp
  Log Message:
  Update EigenUtils
* Add dilate and erode functions to EigenUtils
* Make padMatrix a templated function
  Commit: 19fbd083e90e3dec24e725879ad49f83553420c3
      https://github.com/PDAL/PDAL/commit/19fbd083e90e3dec24e725879ad49f83553420c3
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2017-01-09 (Mon, 09 Jan 2017)
  Changed paths:
  Log Message:
  Merge pull request #1464 from PDAL/eigen-dilate-and-erode
Update EigenUtils
  Commit: 29cad43066a0ac66685f1449df5bbc996e8aaaa1
      https://github.com/PDAL/PDAL/commit/29cad43066a0ac66685f1449df5bbc996e8aaaa1
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-01-10 (Tue, 10 Jan 2017)
  Changed paths:
    M filters/CropFilter.cpp
    M filters/OverlayFilter.cpp
    M filters/OverlayFilter.hpp
    M filters/ReprojectionFilter.cpp
    M pdal/Polygon.cpp
    M pdal/Stage.cpp
    M test/unit/filters/OverlayFilterTest.cpp
  Log Message:
  Make OverlayFilter streamable.
Make sure done() gets called ASAP on streaming.
Fix stage on which spatialReferenceChanged() is called.
Simplify error handling for CropFilter::transform.
Simplify spatial reference creation in reprojection filter.
Don't do anything if we try to reproject a polygon with empty SRSes.
  Commit: eccd3f4192db989242035cf7cc7c548cfcb55e6a
      https://github.com/PDAL/PDAL/commit/eccd3f4192db989242035cf7cc7c548cfcb55e6a
  Changed paths:
    M filters/ColorinterpFilter.cpp
    M filters/ColorizationFilter.cpp
    M filters/ComputeRangeFilter.cpp
    M filters/HAGFilter.cpp
    M filters/IQRFilter.cpp
    M filters/MADFilter.cpp
    M filters/MongusFilter.cpp
    M filters/MortonOrderFilter.cpp
    M filters/NormalFilter.cpp
    M filters/OutlierFilter.cpp
    M filters/PMFFilter.cpp
    M filters/SMRFilter.cpp
    M filters/SampleFilter.cpp
    M filters/StatsFilter.cpp
  Log Message:
  Formatting updates.
  Commit: d0ff5b9ecf22af5c402ec1e9c84c9d5964df6759
      https://github.com/PDAL/PDAL/commit/d0ff5b9ecf22af5c402ec1e9c84c9d5964df6759
  Author: Connor Manning <connor at hobu.co>
  Date:   2017-01-11 (Wed, 11 Jan 2017)
  Changed paths:
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/greyhound/test/GreyhoundReaderTest.cpp
  Log Message:
  Remove scale/offset considerations from the Greyhound reader due to server-side simplifications.
  Commit: 74ca75a206f7f18f887ce8a348af6e67ce560a45
      https://github.com/PDAL/PDAL/commit/74ca75a206f7f18f887ce8a348af6e67ce560a45
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-01-12 (Thu, 12 Jan 2017)
  Changed paths:
    M pdal/Polygon.cpp
    M pdal/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into python-embed-metadata
  Commit: 6aabf437153bcd5d4362d2cc7f05b6a347c1b4d0
      https://github.com/PDAL/PDAL/commit/6aabf437153bcd5d4362d2cc7f05b6a347c1b4d0
  Changed paths:
    M pdal/KDIndex.hpp
    M vendor/nanoflann/nanoflann.hpp
  Log Message:
  Update decrepit nanoflann code.
  Commit: 5e612ce3f3cdb4a2161d239644e22002854824e1
      https://github.com/PDAL/PDAL/commit/5e612ce3f3cdb4a2161d239644e22002854824e1
  Changed paths:
    M doc/stages/filters.predicate.rst
    M doc/stages/filters.programmable.rst
  Log Message:
  docs for python filters updates
  Commit: f5736b101f6bc5359019c32a9a3384dd86a7067e
      https://github.com/PDAL/PDAL/commit/f5736b101f6bc5359019c32a9a3384dd86a7067e
  Changed paths:
    M pdal/KDIndex.hpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/58e3231ee702...f5736b101f6b
More information about the pdal-commits mailing list
