[pdal-commits] [PDAL/PDAL] 2abc99: Initial check-in for safety.
GitHub noreply at github.com
Mon Jun 19 09:26:31 PDT 2017
  Branch: refs/heads/matlab-updates
  Home:   https://github.com/PDAL/PDAL
  Commit: 2abc9955f690d781c3b1face9d30f5373d0464c1
      https://github.com/PDAL/PDAL/commit/2abc9955f690d781c3b1face9d30f5373d0464c1
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-04-12 (Wed, 12 Apr 2017)
  Changed paths:
    A filters/GreedyProjection.cpp
    A filters/GreedyProjection.hpp
    M pdal/Dimension.json
  Log Message:
  Commit: 48761cd7b5d2e8b647738b43ea8c602949558c02
      https://github.com/PDAL/PDAL/commit/48761cd7b5d2e8b647738b43ea8c602949558c02
  Changed paths:
    M filters/GreedyProjection.cpp
  Log Message:
  Fix more errors.
  Commit: 727f94f3f7e00dbd9f053c9bca4ee1be6d2faca1
      https://github.com/PDAL/PDAL/commit/727f94f3f7e00dbd9f053c9bca4ee1be6d2faca1
  Date:   2017-04-13 (Thu, 13 Apr 2017)
  Changed paths:
    M filters/GreedyProjection.hpp
  Log Message:
  It compiles.
  Commit: 2cd676f777101186e5088f0da93c2fdcb96460c2
      https://github.com/PDAL/PDAL/commit/2cd676f777101186e5088f0da93c2fdcb96460c2
  Date:   2017-04-17 (Mon, 17 Apr 2017)
  Changed paths:
    A pdal/Mesh.hpp
    M pdal/PointView.hpp
    M pdal/StageFactory.cpp
  Log Message:
  Hook greedy triangulation into filters.
  Commit: 99f8359cd892b220815cfdc7d68ac380b1bd6e57
      https://github.com/PDAL/PDAL/commit/99f8359cd892b220815cfdc7d68ac380b1bd6e57
  Date:   2017-04-18 (Tue, 18 Apr 2017)
  Changed paths:
    M pdal/Mesh.hpp
    M pdal/PointView.cpp
  Log Message:
  Hooks for multiple meshes.
  Commit: 84b03f6139886f15561ffb2dadd6d7d99bbf1114
      https://github.com/PDAL/PDAL/commit/84b03f6139886f15561ffb2dadd6d7d99bbf1114
  Date:   2017-04-19 (Wed, 19 Apr 2017)
  Changed paths:
    M doc/apps/translate.rst
    M doc/development/testing.rst
    M doc/pipeline.rst
    M doc/stages/filters.outlier.rst
    M doc/stages/filters.pmf.rst
    M doc/stages/writers.gdal.rst
    M doc/workshop/exercises/analysis/denoising/denoise.json
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
    M filters/MergeFilter.hpp
    M io/GDALGrid.cpp
    M pdal/Filter.hpp
    M pdal/Kernel.cpp
    M pdal/PipelineReaderJSON.cpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/util/ProgramArgs.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M test/data/pipeline/options.json.in
    M test/unit/ProgramArgsTest.cpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into greedy
  Commit: b1fed0114a81596fd49ae6f734ec04183a3fe84a
      https://github.com/PDAL/PDAL/commit/b1fed0114a81596fd49ae6f734ec04183a3fe84a
  Changed paths:
    M filters/NormalFilter.cpp
    M filters/NormalFilter.hpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M pdal/Mesh.hpp
    M test/unit/PointViewTest.cpp
  Log Message:
  Working greedy projection filter.
  Commit: 7f18283191373c0f939d5c41459a6de4c25aa619
      https://github.com/PDAL/PDAL/commit/7f18283191373c0f939d5c41459a6de4c25aa619
  Changed paths:
    M doc/stages/filters.splitter.rst
    M filters/SplitterFilter.cpp
    M filters/SplitterFilter.hpp
    M io/PlyWriter.cpp
    M test/unit/filters/SplitterTest.cpp
  Log Message:
  Commit: 7bd14e6b48dc7fd0174154f1b5939331c7174ca0
      https://github.com/PDAL/PDAL/commit/7bd14e6b48dc7fd0174154f1b5939331c7174ca0
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-06-08 (Thu, 08 Jun 2017)
  Changed paths:
    M filters/ColorinterpFilter.cpp
    M filters/ColorinterpFilter.hpp
  Log Message:
  ColorInterp can search for the requested dimension instead of relying on only standard dims
  Commit: 8ab0c9fc7ee6977166d6d55e9ea8e18eb62202bb
      https://github.com/PDAL/PDAL/commit/8ab0c9fc7ee6977166d6d55e9ea8e18eb62202bb
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2017-06-09 (Fri, 09 Jun 2017)
  Changed paths:
  Log Message:
  Merge pull request #1594 from PDAL/issue/1593-colorinterp-dims
ColorInterp can search for the requested dimension instead of relying…
  Commit: c7d70efdd4c86ee8cba36c6348b216b07d2e9264
      https://github.com/PDAL/PDAL/commit/c7d70efdd4c86ee8cba36c6348b216b07d2e9264
  Changed paths:
  Log Message:
  Add RandomizeFilter to StageFactory
  Commit: 9dbe88f13cbe3d477e930e21af93efc0a3eb93ce
      https://github.com/PDAL/PDAL/commit/9dbe88f13cbe3d477e930e21af93efc0a3eb93ce
  Changed paths:
  Log Message:
  Merge pull request #1599 from PDAL/issue/1598-randomize-stagefactory
Closes #1598
  Commit: 294552bc686ceacb1d4b62ed5a6fd089f029d2c4
      https://github.com/PDAL/PDAL/commit/294552bc686ceacb1d4b62ed5a6fd089f029d2c4
  Changed paths:
  Log Message:
  Add doc describing raster type limitation for writers.gdal.
  Commit: 609726f96e375c2f00a61411eb68becfd3dc52f4
      https://github.com/PDAL/PDAL/commit/609726f96e375c2f00a61411eb68becfd3dc52f4
  Changed paths:
    M pdal/SpatialReference.cpp
  Log Message:
  Commit: 3487af85ea7180a386d58d9185360f503ab3a6c9
      https://github.com/PDAL/PDAL/commit/3487af85ea7180a386d58d9185360f503ab3a6c9
  Date:   2017-06-12 (Mon, 12 Jun 2017)
  Changed paths:
    M doc/stages/filters.sort.rst
    M doc/stages/readers.sbet.rst
  Log Message:
  Convert filters.sort and readers.sbet example pipelines from XML to JSON (#1604)
  Commit: 8c14efdc80f9932ad6bbc52ec3a4f4b300593c96
      https://github.com/PDAL/PDAL/commit/8c14efdc80f9932ad6bbc52ec3a4f4b300593c96
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    A pdal/EmbedEnvironment.cpp
    A pdal/EmbedEnvironment.hpp
    A pdal/EmbedScript.cpp
    A pdal/EmbedScript.hpp
    M pdal/mlang/Environment.cpp
    M pdal/mlang/Environment.hpp
    A pdal/mlang/Script.cpp
    A pdal/mlang/Script.hpp
    M pdal/plang/Environment.cpp
    M pdal/plang/Environment.hpp
    M pdal/plang/Script.cpp
    M pdal/plang/Script.hpp
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/ProgrammableFilter.cpp
    M plugins/python/filters/ProgrammableFilter.hpp
  Log Message:
  WIP
  Commit: 743cfbd2f10f5f6836b3ab0ec01976c4ec0fdeb0
      https://github.com/PDAL/PDAL/commit/743cfbd2f10f5f6836b3ab0ec01976c4ec0fdeb0
  Date:   2017-06-13 (Tue, 13 Jun 2017)
  Changed paths:
    M plugins/python/CMakeLists.txt
    M plugins/python/filters/CMakeLists.txt
    R plugins/python/filters/PredicateFilter.cpp
    R plugins/python/filters/PredicateFilter.hpp
    R plugins/python/filters/ProgrammableFilter.cpp
    R plugins/python/filters/ProgrammableFilter.hpp
    A plugins/python/filters/PythonFilter.cpp
    A plugins/python/filters/PythonFilter.hpp
    R plugins/python/test/PLangTest.cpp
    R plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    R plugins/python/test/PythonPipelineTest.cpp
    M test/data/plang/from-module.json.in
    M test/data/plang/predicate-embed.json.in
    M test/data/plang/programmable-update-y-dims.json.in
  Log Message:
  collapse filters.predicate and filters.programmable into filters.python. Push all tests into a single file
  Commit: 4701108f019a23bdb9fc68c70f4c5b9807183b86
      https://github.com/PDAL/PDAL/commit/4701108f019a23bdb9fc68c70f4c5b9807183b86
  Changed paths:
    R plugins/python/test/ProgrammableFilterTest.cpp
    A plugins/python/test/PythonFilterTest.cpp
  Log Message:
  rename test executable
  Commit: 62627f8bfe006c4252941586bfdd13681a8cc3c0
      https://github.com/PDAL/PDAL/commit/62627f8bfe006c4252941586bfdd13681a8cc3c0
  Changed paths:
    M .gitignore
    M CMakeLists.txt
    R pdal/plang/Array.cpp
    R pdal/plang/Array.hpp
    R pdal/plang/CMakeLists.txt
    R pdal/plang/Environment.cpp
    R pdal/plang/Environment.hpp
    R pdal/plang/Invocation.cpp
    R pdal/plang/Invocation.hpp
    R pdal/plang/Redirector.cpp
    R pdal/plang/Redirector.hpp
    R pdal/plang/Script.cpp
    R pdal/plang/Script.hpp
    M plugins/python/filters/PythonFilter.hpp
    A plugins/python/plang/Array.cpp
    A plugins/python/plang/Array.hpp
    A plugins/python/plang/CMakeLists.txt
    A plugins/python/plang/Environment.cpp
    A plugins/python/plang/Environment.hpp
    A plugins/python/plang/Invocation.cpp
    A plugins/python/plang/Invocation.hpp
    A plugins/python/plang/Redirector.cpp
    A plugins/python/plang/Redirector.hpp
    A plugins/python/plang/Script.cpp
    A plugins/python/plang/Script.hpp
    M plugins/python/test/PythonFilterTest.cpp
  Log Message:
  bury plang stuff into filters.python
  Commit: 7afe1f4f820a9d8593d9b73988f161006fb1a4ad
      https://github.com/PDAL/PDAL/commit/7afe1f4f820a9d8593d9b73988f161006fb1a4ad
  Date:   2017-06-14 (Wed, 14 Jun 2017)
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into matlab-updates
  Commit: 1c4a112da71388132a98dae654560086dc6d6036
      https://github.com/PDAL/PDAL/commit/1c4a112da71388132a98dae654560086dc6d6036
  Date:   2017-06-15 (Thu, 15 Jun 2017)
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M appveyor.yml
    M cmake/examples/hobu-windows.bat
    M cmake/modules/FindNumPy.cmake
    R cmake/rply.cmake
    M doc/download.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/filters.smrf.rst
    M doc/tutorial/index.rst
    M doc/tutorial/las.rst
    A doc/tutorial/python-filtering.rst
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    A doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/near.rst
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression-command-verify.txt
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/density-command-run.png
    M doc/workshop/images/dtm-add-raster-layer.png
    M doc/workshop/images/dtm-add-raster-mean.png
    M doc/workshop/images/dtm-qgis-added.png
    M doc/workshop/images/dtm-qgis-classify.png
    M doc/workshop/images/dtm-qgis-colorize-dtm.png
    M doc/workshop/images/dtm-qgis-hillshade-done.png
    M doc/workshop/images/dtm-qgis-select-hillshade.png
    M doc/workshop/images/dtm-run-command.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-classified-included-side.png
    M doc/workshop/images/ground-classified-included.png
    M doc/workshop/images/ground-filtered.png
    M doc/workshop/images/ground-ground-only-view.png
    M doc/workshop/images/ground-run-command.png
    A doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/osgeo4w-advanced-selection.png
    A doc/workshop/images/osgeo4w-pdal-selection.png
    A doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
    M doc/workshop/includes/substitutions.rst
    A doc/workshop/osgeo4w.rst
    M doc/workshop/qgis.rst
    M doc/workshop/software.rst
    M filters/ClusterFilter.cpp
    M io/LasWriter.cpp
    M io/PlyReader.cpp
    M io/PlyReader.hpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M io/TextReader.cpp
    M pdal/Mesh.hpp
    M pdal/PDALUtils.hpp
    M pdal/PointRef.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/plang/Redirector.hpp
    M pdal/util/IStream.hpp
    M pdal/util/NullOStream.hpp
    M pdal/util/OStream.hpp
    M pdal/util/Utils.hpp
    M plugins/geowave/io/GeoWaveReader.cpp
    M plugins/geowave/io/GeoWaveWriter.cpp
    M plugins/greyhound/CMakeLists.txt
    M plugins/greyhound/io/bounds.hpp
    M plugins/greyhound/io/point.hpp
    M plugins/hexbin/kernel/OGR.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M scripts/appveyor/config.cmd
    M scripts/appveyor/install.cmd
    M scripts/docker/Dockerfile
    M scripts/docker/dependencies/Dockerfile
    A scripts/osgeo4w/config.cmd
    A test/data/ply/mesh.ply
    M test/unit/io/LasWriterTest.cpp
    M test/unit/io/PlyReaderTest.cpp
    M test/unit/io/PlyWriterTest.cpp
    M vendor/arbiter/CMakeLists.txt
    R vendor/rply/LICENSE
    R vendor/rply/etc/convert.c
    R vendor/rply/etc/dump.c
    R vendor/rply/etc/input.ply
    R vendor/rply/etc/sconvert.c
    R vendor/rply/manual/manual.html
    R vendor/rply/manual/reference.css
    R vendor/rply/manual/rply.png
    R vendor/rply/rply.c
    R vendor/rply/rply.h
    R vendor/rply/rplyfile.h
  Log Message:
  Commit: 09ffb68b658225e53d099322427ba210bfa97700
      https://github.com/PDAL/PDAL/commit/09ffb68b658225e53d099322427ba210bfa97700
  Date:   2017-06-19 (Mon, 19 Jun 2017)
  Changed paths:
    M plugins/python/plang/Array.cpp
    M plugins/python/plang/Array.hpp
    M python/pdal/PyPipeline.hpp
  Log Message:
  refactor pdal::plang::Array
  Commit: 8d8d2943416d11f77cea00209660f549b6564d79
      https://github.com/PDAL/PDAL/commit/8d8d2943416d11f77cea00209660f549b6564d79
  Changed paths:
  Log Message:
  Commit: 1f233eb76168022a12ef14e174470652293a6bd7
      https://github.com/PDAL/PDAL/commit/1f233eb76168022a12ef14e174470652293a6bd7
  Changed paths:
    M CMakeLists.txt
    M cmake/python.cmake
    M pdal_defines.h.in
  Log Message:
  Python Array.hpp build refactoring
  Commit: 1608bae6b30bdb52131193ca29e04d64bc25c2c7
      https://github.com/PDAL/PDAL/commit/1608bae6b30bdb52131193ca29e04d64bc25c2c7
  Changed paths:
    A pdal/PyArray.hpp
    R plugins/python/plang/Array.cpp
    R plugins/python/plang/Array.hpp
    M plugins/python/plang/CMakeLists.txt
    M python/pdal/PyPipeline.cpp
    M python/pdal/libpdalpython.pyx
    M python/setup.py
  Log Message:
  refactor Python extension to use new PyArray.hpp header
  Commit: b3a4da95765d40cd507fe0cd64fbfc51f70a88d7
      https://github.com/PDAL/PDAL/commit/b3a4da95765d40cd507fe0cd64fbfc51f70a88d7
  Changed paths:
    M pdal/PyArray.hpp
  Log Message:
  attempt to be graceful when we don't have Python
Compare: https://github.com/PDAL/PDAL/compare/8e7561210d58...b3a4da95765d
More information about the pdal-commits mailing list
