[pdal-commits] [PDAL/PDAL] 201174: Move standard kernel option doc.
GitHub noreply at github.com
Wed Mar 15 15:06:52 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 201174b405f9940cb201641f2fce8704e3389466
      https://github.com/PDAL/PDAL/commit/201174b405f9940cb201641f2fce8704e3389466
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-03-15 (Wed, 15 Mar 2017)
  Changed paths:
    M doc/apps/density.rst
    M doc/apps/ground.rst
    M doc/apps/index.rst
    M doc/apps/pipeline.rst
  Log Message:
  Commit: b2bf6aed78934ce357e523712cb86080f9656387
      https://github.com/PDAL/PDAL/commit/b2bf6aed78934ce357e523712cb86080f9656387
  Changed paths:
    M HOWTORELEASE.txt
    M doc/community.rst
    M doc/development/metadata.rst
    R doc/stages/writers.derivative.rst
    M doc/stages/writers.las.rst
    M doc/tutorial/pcl_ground.rst
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    R io/DerivativeWriter.cpp
    R io/DerivativeWriter.hpp
    M io/GDALGrid.hpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M kernels/GroundKernel.cpp
    M kernels/RandomKernel.cpp
    M kernels/SortKernel.cpp
    M pdal/Kernel.cpp
    M pdal/Kernel.hpp
    M pdal/StageFactory.cpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M test/unit/io/LasWriterTest.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 32459c8a3d449ff55622c00db1f3ba3b9b682ada
      https://github.com/PDAL/PDAL/commit/32459c8a3d449ff55622c00db1f3ba3b9b682ada
  Changed paths:
    M doc/apps/delta.rst
    M doc/apps/diff.rst
    M doc/apps/info.rst
    M doc/apps/merge.rst
    M doc/apps/pcl.rst
    M doc/apps/random.rst
    M doc/apps/sort.rst
    M doc/apps/split.rst
    M doc/apps/tindex.rst
    M doc/apps/translate.rst
    M kernels/InfoKernel.cpp
    M kernels/TIndexKernel.cpp
    M kernels/TranslateKernel.cpp
  Log Message:
  Update options/doc pass for kernels.
  Commit: 21d9a5869b4650bf0511dce33efe5a247b2234b2
      https://github.com/PDAL/PDAL/commit/21d9a5869b4650bf0511dce33efe5a247b2234b2
  Changed paths:
    M CMakeLists.txt
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/fb15a3a120e6...21d9a5869b46
More information about the pdal-commits mailing list
