[pdal-commits] [PDAL/PDAL] 49d888: Refactor SMRF code
GitHub noreply at github.com
Fri Mar 17 08:50:48 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 49d88890ea288aa9fad1eada86fb6cde0fc68cf0
      https://github.com/PDAL/PDAL/commit/49d88890ea288aa9fad1eada86fb6cde0fc68cf0
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-03-17 (Fri, 17 Mar 2017)
  Changed paths:
    M doc/stages/filters.smrf.rst
    M filters/SMRFilter.cpp
    M filters/SMRFilter.hpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
  Log Message:
  Refactor SMRF code
* only write intermediate rasters for debugging when optional output directory is provided
* make program args more consistent with the paper
* revert from TPS interpolation back to average of 8 nearest neighbors
* use iterative morphological operations and diamond structuring element for speedup
* remove the classify/extract args, always classify, and extract with range filter if desired
  Commit: ca6c17001cc0328253f48c0483b58aa0e283b856
      https://github.com/PDAL/PDAL/commit/ca6c17001cc0328253f48c0483b58aa0e283b856
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #1531 from PDAL/smrf-refactor
Refactor SMRF code
Close #1314
Compare: https://github.com/PDAL/PDAL/compare/b094fd5ad222...ca6c17001cc0
More information about the pdal-commits mailing list
