[pdal-commits] [PDAL/PDAL] 6ff1df: start refactoring workshop for windows
GitHub noreply at github.com
Fri May 19 09:14:47 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 6ff1df1725010943fb5a7b9d86b097850c56c35a
      https://github.com/PDAL/PDAL/commit/6ff1df1725010943fb5a7b9d86b097850c56c35a
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-05-16 (Tue, 16 May 2017)
  Changed paths:
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression-command-verify.txt
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    A doc/workshop/images/osgeo4w-advanced-selection.png
    A doc/workshop/images/osgeo4w-pdal-selection.png
    M doc/workshop/includes/substitutions.rst
    A doc/workshop/osgeo4w.rst
    M doc/workshop/qgis.rst
    M doc/workshop/software.rst
  Log Message:
  Commit: e1667b291e1577c7ff65f2631b24bebaf1241963
      https://github.com/PDAL/PDAL/commit/e1667b291e1577c7ff65f2631b24bebaf1241963
  Date:   2017-05-18 (Thu, 18 May 2017)
  Changed paths:
    M doc/stages/filters.smrf.rst
    M doc/tutorial/las.rst
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoise.json
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    A doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/near.rst
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/dtm-add-raster-layer.png
    M doc/workshop/images/dtm-add-raster-mean.png
    M doc/workshop/images/dtm-qgis-added.png
    M doc/workshop/images/dtm-qgis-classify.png
    M doc/workshop/images/dtm-qgis-colorize-dtm.png
    M doc/workshop/images/dtm-qgis-hillshade-done.png
    M doc/workshop/images/dtm-qgis-select-hillshade.png
    M doc/workshop/images/dtm-run-command.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-classified-included-side.png
    M doc/workshop/images/ground-classified-included.png
    M doc/workshop/images/ground-filtered.png
    M doc/workshop/images/ground-ground-only-view.png
    M doc/workshop/images/ground-run-command.png
    A doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
  Log Message:
  refactor workshop for OSGeo4W
  Commit: 89aec27fe4d839d2c0f51e2f47574e136b6dcd71
      https://github.com/PDAL/PDAL/commit/89aec27fe4d839d2c0f51e2f47574e136b6dcd71
  Date:   2017-05-19 (Fri, 19 May 2017)
  Changed paths:
  Log Message:
  doc bug
  Commit: a07afe405a095b1aa6d4768057736f9186595b0e
      https://github.com/PDAL/PDAL/commit/a07afe405a095b1aa6d4768057736f9186595b0e
  Changed paths:
    M CMakeLists.txt
  Log Message:
  allow PDAL_PLUGIN_INSTALL_PATH override at configure time
  Commit: fde63789ded8fc43fb753dba3f28d86e7c9e3558
      https://github.com/PDAL/PDAL/commit/fde63789ded8fc43fb753dba3f28d86e7c9e3558
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'plugin-install-path-override' into workshop-windows
  Commit: 3f4b50b092e211f548c509765a0b4c5c3291f74d
      https://github.com/PDAL/PDAL/commit/3f4b50b092e211f548c509765a0b4c5c3291f74d
  Changed paths:
    M doc/download.rst
  Log Message:
  point to osgeo4w for windows download
Compare: https://github.com/PDAL/PDAL/compare/d4624f1de628...3f4b50b092e2
More information about the pdal-commits mailing list
