[pdal-commits] [PDAL/PDAL] 022bcc: Merge remote-tracking branch 'origin/master' into ...
GitHub noreply at github.com
Sun May 21 20:53:29 PDT 2017
  Branch: refs/heads/windows-packaging
  Home:   https://github.com/PDAL/PDAL
  Commit: 022bcc8d2bad528426f7eeee70e4249952784759
      https://github.com/PDAL/PDAL/commit/022bcc8d2bad528426f7eeee70e4249952784759
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-05-15 (Mon, 15 May 2017)
  Changed paths:
    M CMakeLists.txt
    R cmake/rply.cmake
    M doc/stages/filters.programmable.rst
    M doc/tutorial/index.rst
    A doc/tutorial/python-filtering.rst
    M doc/workshop/includes/substitutions.rst
    M io/PlyReader.cpp
    M io/PlyReader.hpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M io/TextReader.cpp
    M pdal/PDALUtils.hpp
    M pdal/PointRef.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageFactory.cpp
    M pdal/util/IStream.hpp
    M pdal/util/OStream.hpp
    M pdal/util/Utils.hpp
    M scripts/docker/Dockerfile
    M test/unit/io/PlyReaderTest.cpp
    R vendor/rply/LICENSE
    R vendor/rply/etc/convert.c
    R vendor/rply/etc/dump.c
    R vendor/rply/etc/input.ply
    R vendor/rply/etc/sconvert.c
    R vendor/rply/manual/manual.html
    R vendor/rply/manual/reference.css
    R vendor/rply/manual/rply.png
    R vendor/rply/rply.c
    R vendor/rply/rply.h
    R vendor/rply/rplyfile.h
  Log Message:
  Merge remote-tracking branch 'origin/master' into windows-packaging
  Commit: 15fe7d18fc42462df776eeb82f21369e6f2be034
      https://github.com/PDAL/PDAL/commit/15fe7d18fc42462df776eeb82f21369e6f2be034
  Date:   2017-05-16 (Tue, 16 May 2017)
  Changed paths:
    M cmake/examples/hobu-windows.bat
    M cmake/modules/FindNumPy.cmake
  Log Message:
  Merge branch 'windows-packaging' of https://github.com/PDAL/PDAL into windows-packaging
  Commit: 6ff1df1725010943fb5a7b9d86b097850c56c35a
      https://github.com/PDAL/PDAL/commit/6ff1df1725010943fb5a7b9d86b097850c56c35a
  Changed paths:
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression-command-verify.txt
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    A doc/workshop/images/osgeo4w-advanced-selection.png
    A doc/workshop/images/osgeo4w-pdal-selection.png
    A doc/workshop/osgeo4w.rst
    M doc/workshop/qgis.rst
    M doc/workshop/software.rst
  Log Message:
  start refactoring workshop for windows
  Commit: e1667b291e1577c7ff65f2631b24bebaf1241963
      https://github.com/PDAL/PDAL/commit/e1667b291e1577c7ff65f2631b24bebaf1241963
  Date:   2017-05-18 (Thu, 18 May 2017)
  Changed paths:
    M doc/stages/filters.smrf.rst
    M doc/tutorial/las.rst
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoise.json
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    A doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/near.rst
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/dtm-add-raster-layer.png
    M doc/workshop/images/dtm-add-raster-mean.png
    M doc/workshop/images/dtm-qgis-added.png
    M doc/workshop/images/dtm-qgis-classify.png
    M doc/workshop/images/dtm-qgis-colorize-dtm.png
    M doc/workshop/images/dtm-qgis-hillshade-done.png
    M doc/workshop/images/dtm-qgis-select-hillshade.png
    M doc/workshop/images/dtm-run-command.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-classified-included-side.png
    M doc/workshop/images/ground-classified-included.png
    M doc/workshop/images/ground-filtered.png
    M doc/workshop/images/ground-ground-only-view.png
    M doc/workshop/images/ground-run-command.png
    A doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
  Log Message:
  refactor workshop for OSGeo4W
  Commit: 89aec27fe4d839d2c0f51e2f47574e136b6dcd71
      https://github.com/PDAL/PDAL/commit/89aec27fe4d839d2c0f51e2f47574e136b6dcd71
  Date:   2017-05-19 (Fri, 19 May 2017)
  Changed paths:
  Log Message:
  doc bug
  Commit: a07afe405a095b1aa6d4768057736f9186595b0e
      https://github.com/PDAL/PDAL/commit/a07afe405a095b1aa6d4768057736f9186595b0e
  Changed paths:
    M CMakeLists.txt
  Log Message:
  allow PDAL_PLUGIN_INSTALL_PATH override at configure time
  Commit: fde63789ded8fc43fb753dba3f28d86e7c9e3558
      https://github.com/PDAL/PDAL/commit/fde63789ded8fc43fb753dba3f28d86e7c9e3558
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'plugin-install-path-override' into workshop-windows
  Commit: 5da57e9321d544adfe5c8109a964ee9ee6658830
      https://github.com/PDAL/PDAL/commit/5da57e9321d544adfe5c8109a964ee9ee6658830
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge remote-tracking branch 'origin/plugin-install-path-override' into windows-packaging
  Commit: 3f4b50b092e211f548c509765a0b4c5c3291f74d
      https://github.com/PDAL/PDAL/commit/3f4b50b092e211f548c509765a0b4c5c3291f74d
  Changed paths:
    M doc/download.rst
  Log Message:
  point to osgeo4w for windows download
  Commit: bbc1c5bdbb9a6881f28807ab9ca65cfd383732bb
      https://github.com/PDAL/PDAL/commit/bbc1c5bdbb9a6881f28807ab9ca65cfd383732bb
  Changed paths:
    M plugins/hexbin/kernel/OGR.cpp
  Log Message:
  OGR layer owns feature, don't destroy
  Commit: b5e913388d9c7f4857ff79a5fcbac155c39343da
      https://github.com/PDAL/PDAL/commit/b5e913388d9c7f4857ff79a5fcbac155c39343da
  Changed paths:
    M doc/download.rst
  Log Message:
  Commit: 01ed07d166dc80193a59a6f23dbde138d6e73572
      https://github.com/PDAL/PDAL/commit/01ed07d166dc80193a59a6f23dbde138d6e73572
  Date:   2017-05-21 (Sun, 21 May 2017)
  Changed paths:
    M doc/workshop/images/density-command-run.png
  Log Message:
  workshop image
  Commit: b7ba8f2b9fb387f87573310afa79865c356d5243
      https://github.com/PDAL/PDAL/commit/b7ba8f2b9fb387f87573310afa79865c356d5243
  Changed paths:
    A scripts/osgeo4w/config.cmd
  Log Message:
  OSGeo4W64 build script
  Commit: 5ba3214ee7ee4c883651c87dc2a4f12986fa9213
      https://github.com/PDAL/PDAL/commit/5ba3214ee7ee4c883651c87dc2a4f12986fa9213
  Changed paths:
    M appveyor.yml
    M scripts/appveyor/config.cmd
  Log Message:
  lazperf and windows build tweaks
  Commit: d86548388b1f5252a347c602ec6a8c5873a9cbcb
      https://github.com/PDAL/PDAL/commit/d86548388b1f5252a347c602ec6a8c5873a9cbcb
  Changed paths:
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/19c7928930fc...d86548388b1f
More information about the pdal-commits mailing list
