[pdal-commits] [PDAL/PDAL] 389be3: Remove '..' in configured temp path for unit tests
GitHub noreply at github.com
Thu Nov 2 12:18:50 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 389be3d92dffd1905f97508ef01fc80437866aa8
      https://github.com/PDAL/PDAL/commit/389be3d92dffd1905f97508ef01fc80437866aa8
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-10-12 (Thu, 12 Oct 2017)
  Changed paths:
    M test/unit/Support.cpp
    M test/unit/TestConfig.hpp.in
  Log Message:
musl has changed it's handling of '.' and '..' when globbing [1]. These only
recently made their way into the alpine:edge image that we use in Travis and
for Docker automated builds [2]. For now, we simply configure the temp path
directly, rather than relying on '..'.
[1] https://github.com/alpinelinux/aports/blob/afdba0ba0b8c0e92c376e7f1bfb151c07bf654b6/main/musl/0068-fix-glob-descent-into-.-and-.-with-GLOB_PERIOD.patch
[2] http://www.openwall.com/lists/musl/2017/01/12/5
  Commit: 58b586fb392085a0ea32dcdedc488f78d7ea2c00
      https://github.com/PDAL/PDAL/commit/58b586fb392085a0ea32dcdedc488f78d7ea2c00
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-10-13 (Fri, 13 Oct 2017)
  Changed paths:
  Log Message:
  Merge pull request #1703 from PDAL/alpine-edge-issues
  Commit: e0816a5c682f36b760b4c0f9d31f017fe35dae81
      https://github.com/PDAL/PDAL/commit/e0816a5c682f36b760b4c0f9d31f017fe35dae81
  Date:   2017-10-31 (Tue, 31 Oct 2017)
  Changed paths:
    M doc/faq.rst
  Log Message:
  trigger a doc refresh
  Commit: 17427274f6e232f39015b733d92d3799093d032a
      https://github.com/PDAL/PDAL/commit/17427274f6e232f39015b733d92d3799093d032a
  Changed paths:
    M doc/faq.rst
  Log Message:
  force another doc regen
  Commit: 834c5167b0e40edecebceaf289357c050d067477
      https://github.com/PDAL/PDAL/commit/834c5167b0e40edecebceaf289357c050d067477
  Date:   2017-11-02 (Thu, 02 Nov 2017)
  Changed paths:
    R doc/development/compilation/media/OSGeo4WInstallAdvanced.png
    R doc/development/compilation/media/OSGeo4WInstallFromInternet.png
    R doc/development/compilation/media/OSGeo4WInstallGDALDev.png
    R doc/development/compilation/media/OSGeo4WInstallIConv.png
    R doc/development/compilation/media/OSGeo4WInstallLASZip.png
    R doc/development/compilation/media/OSGeo4WInstallLibXML2.png
    R doc/development/compilation/media/OSGeo4WInstallOCI.png
    R doc/development/compilation/media/OSGeo4WInstallRootDirectory.png
    M doc/development/compilation/windows.rst
  Log Message:
  refresh the Windows compilation document
  Commit: 9d09af32da4c58462144c9e5a1145f85042dca6e
      https://github.com/PDAL/PDAL/commit/9d09af32da4c58462144c9e5a1145f85042dca6e
  Changed paths:
    M examples/writing-filter/CMakeLists.txt
    M examples/writing-kernel/CMakeLists.txt
    M examples/writing-reader/CMakeLists.txt
    M examples/writing-writer/CMakeLists.txt
    M examples/writing/CMakeLists.txt
  Log Message:
  get example CMakeLists.txt working with windows
  Commit: e84e7feaa00a34b3d8d93616bef9839f2475670a
      https://github.com/PDAL/PDAL/commit/e84e7feaa00a34b3d8d93616bef9839f2475670a
  Changed paths:
    A doc/development/cmake.rst
    R doc/development/contributors.rst
    R doc/development/conventions.rst
    R doc/development/docker.rst
    R doc/development/docs.rst
    R doc/development/goals.rst
    M doc/development/index.rst
    R doc/development/integration.rst
    R doc/development/testing.rst
    R doc/development/using.rst
    A doc/project/contributors.rst
    A doc/project/conventions.rst
    A doc/project/docker.rst
    A doc/project/docs.rst
    A doc/project/integration.rst
    A doc/project/testing.rst
  Log Message:
  rearrange development section a bit
  Commit: e6cd5fe4abf59cd3cc588d87f081f93180249213
      https://github.com/PDAL/PDAL/commit/e6cd5fe4abf59cd3cc588d87f081f93180249213
  Changed paths:
    M doc/faq.rst
  Log Message:
  rearrange development section docs
Compare: https://github.com/PDAL/PDAL/compare/7a85cb276a83...e6cd5fe4abf5
More information about the pdal-commits mailing list
