[pdal-commits] [PDAL/PDAL] d6550d: Compression (#1722)
GitHub noreply at github.com
Thu Nov 9 09:54:51 PST 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: d6550d3107e21e4211611e0c0f61e1829ebc119f
      https://github.com/PDAL/PDAL/commit/d6550d3107e21e4211611e0c0f61e1829ebc119f
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-11-09 (Thu, 09 Nov 2017)
  Changed paths:
    M CMakeLists.txt
    M appveyor.yml
    A cmake/lzma.cmake
    A cmake/modules/FindZSTD.cmake
    A cmake/zstd.cmake
    M pdal/Compression.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M scripts/ci/script.sh
    M scripts/docker/dependencies/Dockerfile
    M scripts/docker/master/alpine/Dockerfile
    M scripts/docker/master/ubuntu/Dockerfile
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
  Log Message:
  Compression (#1722)
* Add general deflate/LZMA support.
* Add lzma cmake file
* Add xz to dockerfile.
* Try xz-dev.
* Put xz in the right list.
* Modify travis build script for xz(lzma) compression.
* Update Dockerfile for xz(lzma)
* Use proper casting to avoid warnings on Linux.
* Make interface consistent for compressors.
* Update SQLite for new compression API.
* Update osgeo4w install to grab xz-devel.
* Add support for zstd compression.
* Add zstd to alpine build.
* Add zstd.
* Add zstd-dev pkg.
* Update docker/build files for zstd.
* Convert LazPerfDecompressor to new interface.
* Update Dockerfile(s) for lzma(xz) and zstd.
* Update compression for GreyhoundReader.
More information about the pdal-commits mailing list
