[pdal-commits] [PDAL/PDAL] 166351: Add example for PowerShell.
GitHub noreply at github.com
Thu Nov 30 09:03:16 PST 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 16635110fcc14a57638c78ee343277c5e7aa3e56
      https://github.com/PDAL/PDAL/commit/16635110fcc14a57638c78ee343277c5e7aa3e56
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-11-20 (Mon, 20 Nov 2017)
  Changed paths:
    M doc/tutorial/reading.rst
  Log Message:
  Commit: 172a92810aaec895a133496e9d303ac3e8a36fce
      https://github.com/PDAL/PDAL/commit/172a92810aaec895a133496e9d303ac3e8a36fce
  Date:   2017-11-21 (Tue, 21 Nov 2017)
  Changed paths:
    M doc/apps/translate.rst
  Log Message:
  Fix a couple of typos.
  Commit: 348eb7b74da02fb43ab64062fd4d8a83679d247d
      https://github.com/PDAL/PDAL/commit/348eb7b74da02fb43ab64062fd4d8a83679d247d
  Changed paths:
    M doc/conf.py
    M doc/download.rst
    M doc/rtd_theme/footer.html
    M doc/workshop/osgeo4w.rst
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/Kernel.hpp
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    A test/data/apps/bad_cmd_opt
    A test/data/apps/bad_json_opt
    A test/data/apps/good_cmd_opt
    A test/data/apps/good_json_opt
    M test/unit/apps/AppTest.cpp
    M test/unit/apps/TranslateTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: a36bc1e281f9d776ea85b0187e19a68ef3ffb00b
      https://github.com/PDAL/PDAL/commit/a36bc1e281f9d776ea85b0187e19a68ef3ffb00b
  Date:   2017-11-30 (Thu, 30 Nov 2017)
  Changed paths:
    M cmake/examples/hobu-windows.bat
    M cmake/modules/FindZSTD.cmake
    M doc/stages/writers.pcd.rst
    M python/setup.py
    M scripts/appveyor/config.cmd
  Log Message:
  Commit: 88b102eaeb8f774c37b1eb8071bc9ac1bdd4d55e
      https://github.com/PDAL/PDAL/commit/88b102eaeb8f774c37b1eb8071bc9ac1bdd4d55e
  Changed paths:
    M filters/ColorizationFilter.cpp
    M io/BpfReader.cpp
    M io/LasReader.cpp
    M io/OGRWriterV1.cpp
    M io/PlyReader.cpp
  Log Message:
  Misc. formatting/doc fixes.
Compare: https://github.com/PDAL/PDAL/compare/a61011d3ffd3...88b102eaeb8f
More information about the pdal-commits mailing list
