[pdal-commits] [PDAL/PDAL] eca8bd: PDAL scala (#1492)
GitHub noreply at github.com
Thu Sep 7 15:31:06 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: eca8bd1c5272b9cc4270372e4d182fe4acb5836d
      https://github.com/PDAL/PDAL/commit/eca8bd1c5272b9cc4270372e4d182fe4acb5836d
  Author: Grisha <gr.pomadchin at gmail.com>
  Date:   2017-09-07 (Thu, 07 Sep 2017)
  Changed paths:
    M HOWTORELEASE.txt
    M java/README.md
    M java/build.sbt
    A java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
    A java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
    M java/project/Commands.scala
    A java/project/Dependencies.scala
    A java/project/Version.scala
    M java/project/build.properties
    M java/project/plugins.sbt
    M java/sbt
    M java/scripts/publish-212.sh
    M java/scripts/publish-javastyle.sh
    M java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
    M scripts/ci/script.sh
  Log Message:
  PDAL scala (#1492)
* init
* more implicits to make library more scala like; jts dep
* add specs and ci tests
* RM a scala folder
* Move to SBT 1.0.0
* Updated README.md and HOWTORELEASE, published 1.4.1-SNAPSHOT
* Update Scala API up to PDAL 1.5
* Fix publishJavastyle command
* Bump versions up to 1.5.0
* Change licence headers
* Change core-scala license, updated README.md
* Update sbt and plugins up to stable
More information about the pdal-commits mailing list
