[pdal-commits] [PDAL/PDAL] 6c3802: Don't repeat test.
GitHub noreply at github.com
Fri Sep 8 09:20:41 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 6c3802b0e96f559dc30fe274f1bc56c7a72f1256
      https://github.com/PDAL/PDAL/commit/6c3802b0e96f559dc30fe274f1bc56c7a72f1256
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-08-31 (Thu, 31 Aug 2017)
  Changed paths:
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Don't repeat test.
  Commit: d181fc123f6026eea5008f6dd21d86f94f458695
      https://github.com/PDAL/PDAL/commit/d181fc123f6026eea5008f6dd21d86f94f458695
  Changed paths:
    M PDALConfig.cmake.in
    M filters/GreedyProjection.hpp
    M filters/private/DimRange.cpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M pdal/DimUtil.hpp
    M pdal/PointLayout.cpp
    A test/data/text/numeric_dim.txt
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: c00af3ebbdea56c485396996721f58cbcd04b8e3
      https://github.com/PDAL/PDAL/commit/c00af3ebbdea56c485396996721f58cbcd04b8e3
  Date:   2017-09-08 (Fri, 08 Sep 2017)
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M apps/pdal.cpp
    A cmake/arbiter.cmake
    M cmake/curl.cmake
    M cmake/json.cmake
    M doc/stages/writers.gdal.rst
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
    M java/README.md
    M java/build.sbt
    A java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
    A java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
    M java/project/Commands.scala
    A java/project/Dependencies.scala
    A java/project/Version.scala
    M java/project/build.properties
    M java/project/plugins.sbt
    M java/sbt
    M java/scripts/publish-212.sh
    M java/scripts/publish-javastyle.sh
    M java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
    M pdal/DimUtil.hpp
    M pdal/EigenUtils.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/PDALUtils.cpp
    M pdal/PipelineManager.cpp
    R pdal/PipelineReaderXML.cpp
    M pdal/StageFactory.cpp
    R pdal/private/PipelineReaderXML.hpp
    M pdal/util/Utils.cpp
    M pdal_defines.h.in
    M plugins/matlab/filters/MatlabFilter.cpp
    M plugins/matlab/filters/MatlabFilter.hpp
    M plugins/matlab/filters/Script.cpp
    M plugins/matlab/filters/Script.hpp
    M plugins/matlab/io/MatlabReader.cpp
    M plugins/matlab/io/MatlabReader.hpp
    M plugins/matlab/io/MatlabWriter.cpp
    M plugins/matlab/io/MatlabWriter.hpp
    M plugins/matlab/test/MatlabReaderTest.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M scripts/ci/script.sh
    M test/data/gdal/grid.txt
    M test/data/matlab/autzen.mat
    R test/unit/apps/pcinfoTest.cpp
    M test/unit/io/GDALWriterTest.cpp
    M vendor/arbiter/CMakeLists.txt
  Log Message:
  Commit: 181f6999696a73b86a83066dcf72bc2bfef6298a
      https://github.com/PDAL/PDAL/commit/181f6999696a73b86a83066dcf72bc2bfef6298a
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Roll back 23963719ae107176bb076628ca467fdf4c4d3b59
Compare: https://github.com/PDAL/PDAL/compare/07f8bfcd488e...181f6999696a
More information about the pdal-commits mailing list
