[pdal-commits] [PDAL/PDAL] e0c4d9: Use functions/constants and simplify code.
GitHub noreply at github.com
Mon Sep 11 05:30:34 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: e0c4d980dc8decbde52f590a3e96f9c508d1a380
      https://github.com/PDAL/PDAL/commit/e0c4d980dc8decbde52f590a3e96f9c508d1a380
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-09-11 (Mon, 11 Sep 2017)
  Changed paths:
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
  Log Message:
  Commit: a9eb3d2202bf862c57567f0e5d60535b9f7c4c3c
      https://github.com/PDAL/PDAL/commit/a9eb3d2202bf862c57567f0e5d60535b9f7c4c3c
  Changed paths:
    R test/data/hole/autzen-dd.las
    R test/data/hole/hole.dbf
    R test/data/hole/hole.las
    R test/data/hole/hole.prj
    R test/data/hole/hole.qpj
    R test/data/hole/hole.shp
    R test/data/hole/hole.shx
    R test/data/hole/make-spurious.py
    R test/data/hole/spurious.las
    A test/data/las/spurious.las
    M test/data/pipeline/crop-hole.json.in
  Log Message:
  Remove unused data.
  Commit: 298ea371b8228eb221384db6570edf6dc370a920
      https://github.com/PDAL/PDAL/commit/298ea371b8228eb221384db6570edf6dc370a920
  Changed paths:
    M CMakeLists.txt
    M io/LasHeader.cpp
    M java/scripts/publish-212.sh
    M java/scripts/publish-javastyle.sh
    M java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/b01978409826...298ea371b822
More information about the pdal-commits mailing list
