[pdal-commits] [PDAL/PDAL] 11d55b: Enable streaming for filters.colorinterp where pos...
GitHub noreply at github.com
Thu Sep 21 09:09:23 PDT 2017
  Branch: refs/heads/lasreader-warning
  Home:   https://github.com/PDAL/PDAL
  Commit: 11d55bec978089a79b41435312ffcad1cf37ecb0
      https://github.com/PDAL/PDAL/commit/11d55bec978089a79b41435312ffcad1cf37ecb0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-09-15 (Fri, 15 Sep 2017)
  Changed paths:
    M filters/ColorinterpFilter.cpp
    M filters/ColorinterpFilter.hpp
    M pdal/Stage.hpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/ColorinterpFilterTest.cpp
  Log Message:
  Enable streaming for filters.colorinterp where possible.
Add tests for filters.colorinterp
Close #1609
  Commit: 73676be924a1a63ef57537d47c8860092a0d21ef
      https://github.com/PDAL/PDAL/commit/73676be924a1a63ef57537d47c8860092a0d21ef
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-09-19 (Tue, 19 Sep 2017)
  Changed paths:
    M pdal/Stage.hpp
  Log Message:
  Merge branch 'post1.6' of github.com:PDAL/PDAL
  Commit: b6e613820477a6077d8713e30bcfb3747ccf328b
      https://github.com/PDAL/PDAL/commit/b6e613820477a6077d8713e30bcfb3747ccf328b
  Date:   2017-09-20 (Wed, 20 Sep 2017)
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 43d3c540d5ca2a1169e31a2da00535f7cda17fef
      https://github.com/PDAL/PDAL/commit/43d3c540d5ca2a1169e31a2da00535f7cda17fef
  Date:   2017-09-21 (Thu, 21 Sep 2017)
  Changed paths:
    M apps/pdal.cpp
    M doc/apps/delta.rst
    M kernels/DeltaKernel.cpp
    M kernels/DeltaKernel.hpp
    M kernels/GroundKernel.cpp
    M kernels/GroundKernel.hpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M kernels/TranslateKernel.cpp
    R pdal/KernelFactory.cpp
    R pdal/KernelFactory.hpp
    M pdal/StageFactory.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
  Log Message:
  Commit: da4576e005383ef3e2cb6c17c835c375fa5051f1
      https://github.com/PDAL/PDAL/commit/da4576e005383ef3e2cb6c17c835c375fa5051f1
  Changed paths:
    M io/LasReader.cpp
    M io/LasWriter.cpp
  Log Message:
  No longer complain about out-of-range ReturnNumber and NumberOfReturns for LAS
Compare: https://github.com/PDAL/PDAL/compare/11d55bec9780^...da4576e00538
More information about the pdal-commits mailing list
