[pdal-commits] [PDAL/PDAL] 4b31d5: Use ; for path separator on Windows.
GitHub noreply at github.com
Wed Apr 18 12:42:46 PDT 2018
  Branch: refs/heads/issue-1939
  Home:   https://github.com/PDAL/PDAL
  Commit: 4b31d56cf9626958500af9586799d75fa5fef471
      https://github.com/PDAL/PDAL/commit/4b31d56cf9626958500af9586799d75fa5fef471
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-04-03 (Tue, 03 Apr 2018)
  Changed paths:
    M pdal/PluginDirectory.cpp
  Log Message:
  Commit: b6d8558bf0d16f4cc4d4a8d02d588fc402c676f8
      https://github.com/PDAL/PDAL/commit/b6d8558bf0d16f4cc4d4a8d02d588fc402c676f8
  Changed paths:
    M test/unit/PluginManagerTest.cpp
  Log Message:
  Update tests to match code.
  Commit: 4becf518b6d682b2f8b95eb057ef220010882048
      https://github.com/PDAL/PDAL/commit/4becf518b6d682b2f8b95eb057ef220010882048
  Date:   2018-04-18 (Wed, 18 Apr 2018)
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M ChangeLog
    M HOWTORELEASE.txt
    M RELEASENOTES.txt
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/options.cmake
    M cmake/policies.cmake
    M cmake/unix_compiler_options.cmake
    M doc/apps/info.rst
    M doc/apps/pipeline.rst
    M doc/apps/translate.rst
    M doc/development/compilation/windows.rst
    A doc/development/release-notes/1.7.0.md
    M doc/download.rst
    M doc/faq.rst
    M doc/index.rst
    M doc/pipeline.rst
    M doc/project/integration.rst
    M doc/quickstart.rst
    A doc/stages/filters.delaunay.rst
    M doc/stages/filters.rst
    A doc/stages/readers.rdb.rst
    M doc/stages/readers.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/writers.rst
    M doc/tutorial/las.rst
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/slides/source/lidar_intro.rst
    M filters/ReprojectionFilter.cpp
    M filters/VoxelCenterNearestNeighborFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
    M io/GeotiffSupport.cpp
    M io/GeotiffSupport.hpp
    M io/HeaderVal.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
    R io/SbetCommon.cpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M kernels/PipelineKernel.cpp
    M kernels/PipelineKernel.hpp
    M kernels/TranslateKernel.cpp
    M kernels/TranslateKernel.hpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M pdal/PointView.hpp
    M pdal/Stage.cpp
    M pdal/StageExtensions.cpp
    M pdal/Streamable.cpp
    M pdal/Streamable.hpp
    M pdal/util/ProgramArgs.hpp
    M plugins/CMakeLists.txt
    A plugins/delaunay/CMakeLists.txt
    A plugins/delaunay/filters/DelaunayFilter.cpp
    A plugins/delaunay/filters/DelaunayFilter.hpp
    A plugins/delaunay/filters/Delaunay_psm.cpp
    A plugins/delaunay/filters/Delaunay_psm.h
    M plugins/pcl/CMakeLists.txt
    R plugins/pcl/io/PcdCommon.cpp
    M plugins/pcl/io/PcdCommon.hpp
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/io/CMakeLists.txt
    M plugins/python/plang/Environment.cpp
    A plugins/rdb/CMakeLists.txt
    A plugins/rdb/io/RdbPointcloud.cpp
    A plugins/rdb/io/RdbPointcloud.hpp
    A plugins/rdb/io/RdbReader.cpp
    A plugins/rdb/io/RdbReader.hpp
    A plugins/rdb/test/Config.hpp.in
    A plugins/rdb/test/RdbReaderTest.cpp
    A plugins/rdb/test/data/autzen-thin-srs.rdbx
    A plugins/rdb/test/data/autzen-thin-srs.txt
    M plugins/rxp/CMakeLists.txt
    M scripts/appveyor/config.cmd
    M scripts/appveyor/install.cmd
    M scripts/docker/Dockerfile
    M test/unit/apps/pcpipelineTestJSON.cpp
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-1889
  Commit: 020406003cc483c15b772efd3d87f8331283f757
      https://github.com/PDAL/PDAL/commit/020406003cc483c15b772efd3d87f8331283f757
  Changed paths:
    M io/TextReader.cpp
    M io/TextReader.hpp
  Log Message:
  Use text mode for reading files.
  Commit: e61dd238ba1cf3fa43d41cfaabe944af7bcb6e1c
      https://github.com/PDAL/PDAL/commit/e61dd238ba1cf3fa43d41cfaabe944af7bcb6e1c
  Changed paths:
    M test/data/text/.gitattributes
    A test/data/text/crlf_test2.txt
    M test/unit/io/TextReaderTest.cpp
  Log Message:
  Read files with text mode to fix separator issue on windows.
Close #1939
Compare: https://github.com/PDAL/PDAL/compare/4b31d56cf962^...e61dd238ba1c
More information about the pdal-commits mailing list
