[pdal-commits] [PDAL/PDAL] 0e4263: Handle cr/lf endings on Windows in readers.text (#...
GitHub noreply at github.com
Mon Apr 23 14:49:23 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 0e4263d57c2844e7efb4b47c37cdb2b4443b93fa
      https://github.com/PDAL/PDAL/commit/0e4263d57c2844e7efb4b47c37cdb2b4443b93fa
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-04-23 (Mon, 23 Apr 2018)
  Changed paths:
    M io/TextReader.cpp
    M io/TextReader.hpp
    M test/data/text/.gitattributes
    A test/data/text/crlf_test2.txt
    M test/unit/io/TextReaderTest.cpp
  Log Message:
  Handle cr/lf endings on Windows in readers.text (#1963)
* Use ; for path separator on Windows.
* Update tests to match code.
* Use text mode for reading files.
* Read files with text mode to fix separator issue on windows.
Close #1939
* Fix reversed logic.
* Revert change WRT spaces.
More information about the pdal-commits mailing list
