[pdal-commits] [PDAL/PDAL] b76cf5: Use CMAKE_DL_LIBS (#1946)
GitHub noreply at github.com
Mon Apr 23 19:07:01 PDT 2018
  Branch: refs/heads/1.7-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: b76cf5081f852c4cc5b55cdfb00dadc0e7601070
      https://github.com/PDAL/PDAL/commit/b76cf5081f852c4cc5b55cdfb00dadc0e7601070
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2018-04-23 (Mon, 23 Apr 2018)
  Changed paths:
    M dimbuilder/CMakeLists.txt
    M pdal/util/CMakeLists.txt
  Log Message:
* Use CMAKE_DL_LIBS
* Remove guards from CMAKE_DL_LIBS
  Commit: 96d5f7a5fb2f02cac22160cf648f3a03b7627a18
      https://github.com/PDAL/PDAL/commit/96d5f7a5fb2f02cac22160cf648f3a03b7627a18
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M io/BpfCompressor.hpp
    M io/BpfReader.cpp
    M kernels/InfoKernel.cpp
    M kernels/PipelineKernel.cpp
    M pdal/PDALUtils.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M test/unit/CMakeLists.txt
    M test/unit/apps/pc2pcTest.cpp
    R test/unit/io/BPFTest.cpp
    A test/unit/io/BpfSupport.hpp
    A test/unit/io/BpfTestBase.cpp
    A test/unit/io/BpfTestZlib.cpp
    M tools/lasdump/Dumper.cpp
    M tools/lasdump/Dumper.hpp
  Log Message:
  Build BPF with ZLIB when requested (#1960)
* Make sure features header is included.
* Make sure that we include pdal_features where necessary.
Change tests for BPF to detect an error WRT zlib being properly included.
  Commit: ebe027d58ad1a0d509714ab178a32db46c9133a9
      https://github.com/PDAL/PDAL/commit/ebe027d58ad1a0d509714ab178a32db46c9133a9
  Changed paths:
    M filters/FerryFilter.cpp
    M test/unit/filters/FerryFilterTest.cpp
  Log Message:
  Issue 1930 (#1931)
* Test updates.
* Add missing '.
* Make sure that a new dimension is created with a valid type.
Close #1930
  Commit: dfc60f5391eadf31ff6f94631d639e7ea070117f
      https://github.com/PDAL/PDAL/commit/dfc60f5391eadf31ff6f94631d639e7ea070117f
  Changed paths:
    M io/PlyReader.hpp
    M pdal/PointLayout.cpp
    M pdal/util/ProgramArgs.hpp
    M plugins/oci/io/OciCommon.hpp
    M vendor/eigen/Eigen/src/LU/arch/Inverse_SSE.h
    M vendor/kazhdan/Octree.h
    M vendor/kazhdan/PPolynomial.inl
  Log Message:
  Handle warnings generated by Clang v. 6. (#1961)
Compare: https://github.com/PDAL/PDAL/compare/7b13887fa00e...dfc60f5391ea
More information about the pdal-commits mailing list
