[pdal-commits] [PDAL/PDAL] 99835f: Add bare FBX writer (#2127)
GitHub noreply at github.com
Fri Aug 10 07:39:34 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 99835f8d433c26f2848a6a4b518762284e08cb23
      https://github.com/PDAL/PDAL/commit/99835f8d433c26f2848a6a4b518762284e08cb23
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-08-10 (Fri, 10 Aug 2018)
  Changed paths:
    M cmake/options.cmake
    M pdal/StageExtensions.cpp
    M plugins/CMakeLists.txt
    A plugins/fbx/CMakeLists.txt
    A plugins/fbx/io/FbxWriter.cpp
    A plugins/fbx/io/FbxWriter.hpp
    A plugins/fbx/test/FbxWriterTest.cpp
  Log Message:
* Temp check-in.
* Temp check-in.
* FBX writer creates a real file.
* Working FBX writer.
* Add test for FBX writer.
* Suppress cast warning.
* Remove some warning suppression.
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
