[pdal-commits] [PDAL/PDAL] a3499c: Add tile command (#2125)
GitHub noreply at github.com
Mon Aug 13 13:54:08 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: a3499cd22d9c7609dfc162a8d7f32e17dedab102
      https://github.com/PDAL/PDAL/commit/a3499cd22d9c7609dfc162a8d7f32e17dedab102
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-08-13 (Mon, 13 Aug 2018)
  Changed paths:
    A doc/apps/tile.rst
    M filters/SplitterFilter.cpp
    M filters/SplitterFilter.hpp
    M io/TextWriter.cpp
    A kernels/TileKernel.cpp
    A kernels/TileKernel.hpp
    M pdal/FlexWriter.hpp
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageWrapper.hpp
    M pdal/Streamable.cpp
    M pdal/Streamable.hpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    M pdal/util/FileUtils.cpp
    A test/data/las/tile/file1.las
    A test/data/las/tile/file2.las
    A test/data/las/tile/file3.las
    A test/data/text/file1.txt
    A test/data/text/file2.txt
    A test/data/text/file3.txt
    M test/unit/CMakeLists.txt
    A test/unit/apps/TileTest.cpp
  Log Message:
* Add public entry points to allow filters.splitter use outside of pipelines.
* Initial check-in for kernels.tile.
* Rearrangement prior to streaming support.
* Add streaming support for text writer.
* Working tiler.
* Add skip support.
Add SRS support.
Fill point table when possible.
Improve logic.
* Improve argument text.
* Add SRS support for readers.text.
* First test for tile kernel.
* Add tile test.
Close #2065
* Notify reprojection filter about SRS changes.
* Add a test that includes a reprojection.
Close #2065
* Documentation.
* Debug.
* Ignore files that start with '.'
* Remove debug. Add comment.
* There were tabs instead of spaces. Huh.
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
