[pdal-commits] [PDAL/PDAL] 50b5b7: wip
GitHub noreply at github.com
Wed Aug 22 11:26:50 PDT 2018
  Branch: refs/heads/python-numpy-array-direct
  Home:   https://github.com/PDAL/PDAL
  Commit: 50b5b72f03f300a001aa88fe4d8712338c5f7c1c
      https://github.com/PDAL/PDAL/commit/50b5b72f03f300a001aa88fe4d8712338c5f7c1c
  Author: Howard Butler <howard at hobu.co>
  Date:   2018-08-09 (Thu, 09 Aug 2018)
  Changed paths:
    M cmake/examples/hobu-config.sh
    M plugins/python/io/NumpyReader.cpp
    M plugins/python/io/NumpyReader.hpp
  Log Message:
  wip
  Commit: a222c87b574cdf1ba5534da14071d2795df88134
      https://github.com/PDAL/PDAL/commit/a222c87b574cdf1ba5534da14071d2795df88134
  Date:   2018-08-15 (Wed, 15 Aug 2018)
  Changed paths:
    M .gitignore
    M cmake/options.cmake
    M cmake/unix_compiler_options.cmake
    A doc/apps/tile.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.text.rst
    M filters/ClusterFilter.cpp
    M filters/PMFFilter.cpp
    M filters/ReturnsFilter.cpp
    M filters/SMRFilter.cpp
    M filters/SplitterFilter.cpp
    M filters/SplitterFilter.hpp
    A filters/private/Segmentation.cpp
    A filters/private/Segmentation.hpp
    M io/FauxReader.cpp
    M io/TextReader.cpp
    M io/TextWriter.cpp
    A kernels/TileKernel.cpp
    A kernels/TileKernel.hpp
    M pdal/FlexWriter.hpp
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/PointView.hpp
    R pdal/Segmentation.cpp
    R pdal/Segmentation.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageExtensions.cpp
    M pdal/StageWrapper.hpp
    M pdal/Streamable.cpp
    M pdal/Streamable.hpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    M pdal/util/FileUtils.cpp
    M plugins/CMakeLists.txt
    A plugins/fbx/CMakeLists.txt
    A plugins/fbx/io/FbxWriter.cpp
    A plugins/fbx/io/FbxWriter.hpp
    A plugins/fbx/test/FbxWriterTest.cpp
    M plugins/python/filters/PythonFilter.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/plang/Invocation.hpp
    M plugins/python/test/PythonFilterTest.cpp
    A test/data/japanese.txt
    A test/data/las/tile/file1.las
    A test/data/las/tile/file2.las
    A test/data/las/tile/file3.las
    A test/data/text/file1.txt
    A test/data/text/file2.txt
    A test/data/text/file3.txt
    M test/unit/CMakeLists.txt
    M test/unit/FileUtilsTest.cpp
    M test/unit/SegmentationTest.cpp
    A test/unit/apps/TileTest.cpp
    A test/unit/filters/ReturnsFilterTest.cpp
    A test/unit/filters/VoxelTest.cpp
    M vendor/gtest/cmake/internal_utils.cmake
  Log Message:
  Merge remote-tracking branch 'origin/master' into python-numpy-array-direct
  Commit: 3e83709c4fbbcd3cc11714c95c74e611e3ec06f1
      https://github.com/PDAL/PDAL/commit/3e83709c4fbbcd3cc11714c95c74e611e3ec06f1
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Commit: e3b9aa716b72eba1a2dce019284f1f714f752d2f
      https://github.com/PDAL/PDAL/commit/e3b9aa716b72eba1a2dce019284f1f714f752d2f
  Date:   2018-08-22 (Wed, 22 Aug 2018)
  Changed paths:
    M CMakeLists.txt
    M cmake/libxml2.cmake
    M doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.ply.rst
    M filters/ApproximateCoplanarFilter.cpp
    M filters/EigenvaluesFilter.cpp
    M filters/EstimateRankFilter.cpp
    M filters/GreedyProjection.cpp
    M filters/HAGFilter.cpp
    M filters/KDistanceFilter.cpp
    M filters/LOFFilter.cpp
    M filters/NNDistanceFilter.cpp
    M filters/NeighborClassifierFilter.cpp
    M filters/RadialDensityFilter.cpp
    M filters/SampleFilter.cpp
    M filters/VoxelCenterNearestNeighborFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M pdal/PointTable.cpp
    M pdal/PointTable.hpp
    M pdal/PointView.cpp
    M pdal/compression/Compression.hpp
    M plugins/delaunay/filters/Delaunay_psm.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    A test/data/pipeline/las2csv-with-unicode-paths.json.in
    A test/data/ply/mesh_fixed.ply
    M test/unit/PointTableTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    M test/unit/filters/VoxelTest.cpp
    M test/unit/io/PlyWriterTest.cpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/50b5b72f03f3^...e3b9aa716b72
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
