[pdal-commits] [PDAL/PDAL] cf09fb: install osx plugins to @rpath, not @loader_path/.....
GitHub
noreply at github.com
Wed Aug 29 13:00:32 PDT 2018
Branch: refs/heads/issue-2155
Home: https://github.com/PDAL/PDAL
Commit: cf09fbd4adf11ca43d565035687a09feb243cad7
https://github.com/PDAL/PDAL/commit/cf09fbd4adf11ca43d565035687a09feb243cad7
Author: Howard Butler <howard at hobu.co>
Date: 2018-08-27 (Mon, 27 Aug 2018)
Changed paths:
M cmake/macros.cmake
Log Message:
install osx plugins to @rpath, not @loader_path/../lib (#2150)
Commit: e3d383ac827deb6c79089604337759ddc6f23a58
https://github.com/PDAL/PDAL/commit/e3d383ac827deb6c79089604337759ddc6f23a58
Changed paths:
M scripts/ci/script.sh
Log Message:
pin Python bindings to 2.0.0 for Travis (#2151)
* pin Python bindings to 2.0.0 for Travis
* checkout, not co
* checkout branch in correct directory
Commit: e45483e85a499493c375f955c86c1302044c4df3
https://github.com/PDAL/PDAL/commit/e45483e85a499493c375f955c86c1302044c4df3
Changed paths:
M pdal/PipelineManager.hpp
Log Message:
PipelineManager::getStage() should return the first leaf, not the first stage added to the manager (#2149)
* PipelineManager::getStage() should return the first leaf, not the first stage added to the manager
* modify getStage() method to be slightly more efficient
Commit: 390cf954c32b096beb56b725cb333e7c26cb698b
https://github.com/PDAL/PDAL/commit/390cf954c32b096beb56b725cb333e7c26cb698b
Changed paths:
M plugins/python/io/NumpyReader.cpp
M plugins/python/io/NumpyReader.hpp
Log Message:
readers.numpy support of a directly set numpy array (#2152)
Commit: 9ec20ea292203c3d2099ed9dd48797d1d079f79a
https://github.com/PDAL/PDAL/commit/9ec20ea292203c3d2099ed9dd48797d1d079f79a
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
pdal/ubuntu:master should use master branch
Commit: 13718db5c68124d708ed8ec40dc7ab1774b6b99b
https://github.com/PDAL/PDAL/commit/13718db5c68124d708ed8ec40dc7ab1774b6b99b
Date: 2018-08-28 (Tue, 28 Aug 2018)
Changed paths:
M filters/AssignFilter.cpp
M filters/AssignFilter.hpp
M test/unit/filters/AssignFilterTest.cpp
Log Message:
Add condition option to assign filter (#2154)
* Add condition option to assign filter
Values will only be assigned when the condition (specified as a DimRange) is
met.
Closes #1956
* handle 'condition' in filters.assign when there is no condition set
* test condition setting in filters.assign
Commit: b244ba098d2d3870414f7ba7e6b68409074039c6
https://github.com/PDAL/PDAL/commit/b244ba098d2d3870414f7ba7e6b68409074039c6
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M pdal/Options.cpp
M pdal/Stage.cpp
M test/unit/apps/TranslateTest.cpp
Log Message:
Handle repeated command-line options. (#2145)
* Make sure all options with a given key are populated when we add a conditional
option.
* Add test for issue 2114.
Use "children" instead of "parents" to make Stage execution code clearer.
Commit: 19b0fe697b307d897ae4e1a5e80655c6b82b2fa6
https://github.com/PDAL/PDAL/commit/19b0fe697b307d897ae4e1a5e80655c6b82b2fa6
Date: 2018-08-29 (Wed, 29 Aug 2018)
Changed paths:
M pdal/Options.cpp
M pdal/Stage.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2155
Compare: https://github.com/PDAL/PDAL/compare/8d98b58affd9...19b0fe697b30
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
