[pdal-commits] [PDAL/PDAL] 6dd4bb: Remove PDAL_HAVE dependencies from compression cod...
GitHub noreply at github.com
Thu Jan 25 06:47:24 PST 2018
  Branch: refs/heads/config
  Home:   https://github.com/PDAL/PDAL
  Commit: 6dd4bb251d3852383ccbc400ae3107e908490009
      https://github.com/PDAL/PDAL/commit/6dd4bb251d3852383ccbc400ae3107e908490009
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-01-25 (Thu, 25 Jan 2018)
  Changed paths:
    M CMakeLists.txt
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    A pdal/compression/DeflateCompression.cpp
    M pdal/compression/DeflateCompression.hpp
    A pdal/compression/LazPerfCompression.cpp
    M pdal/compression/LazPerfCompression.hpp
    A pdal/compression/LazPerfVlrCompression.cpp
    A pdal/compression/LazPerfVlrCompression.hpp
    A pdal/compression/LzmaCompression.cpp
    M pdal/compression/LzmaCompression.hpp
    A pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M pdal/pdal_config.cpp
    M pdal/pdal_config.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
    M test/unit/ConfigTest.cpp
    A test/unit/DeflateTest.cpp
    A test/unit/LazPerfTest.cpp
    A test/unit/LzmaTest.cpp
    A test/unit/ZstdTest.cpp
  Log Message:
  Remove PDAL_HAVE dependencies from compression code.
More information about the pdal-commits mailing list
