[pdal-commits] [PDAL/PDAL] 060f78: Allow dimension names to contain slashes for the a...
GitHub noreply at github.com
Fri Jan 26 06:17:14 PST 2018
  Branch: refs/heads/config
  Home:   https://github.com/PDAL/PDAL
  Commit: 060f7832abc0f738601823f6bd2cd20b1f1e5c9d
      https://github.com/PDAL/PDAL/commit/060f7832abc0f738601823f6bd2cd20b1f1e5c9d
  Author: Connor Manning <connor at hobu.co>
  Date:   2018-01-23 (Tue, 23 Jan 2018)
  Changed paths:
    M pdal/DimUtil.hpp
  Log Message:
  Allow dimension names to contain slashes for the assign/range filters.
  Commit: 37edaa3f0676754a35df45067fd15564d9c5c30b
      https://github.com/PDAL/PDAL/commit/37edaa3f0676754a35df45067fd15564d9c5c30b
  Changed paths:
    M pdal/DimUtil.hpp
  Log Message:
  Merge pull request #1784 from PDAL/dimensions-with-slashes
  Commit: f71e19607e9fc010cf387e81699aeb9185d7b360
      https://github.com/PDAL/PDAL/commit/f71e19607e9fc010cf387e81699aeb9185d7b360
  Author: Howard Butler <howard at hobu.co>
  Date:   2018-01-24 (Wed, 24 Jan 2018)
  Changed paths:
    M scripts/ci/script.sh
  Log Message:
  Re-enable Python Extension building on AppVeyor (#1787)
* turn Python extension testing back on
* need pip
* need cython
  Commit: 5e7c3985e8f6ccd1ed1c84d8cfb1b9517ead34a1
      https://github.com/PDAL/PDAL/commit/5e7c3985e8f6ccd1ed1c84d8cfb1b9517ead34a1
  Author: Blottiere Paul <blottiere.paul at gmail.com>
  Date:   2018-01-25 (Thu, 25 Jan 2018)
  Changed paths:
    A doc/stages/filters.mortonorder.img1.png
    M doc/stages/filters.mortonorder.rst
    M filters/MortonOrderFilter.cpp
    M filters/MortonOrderFilter.hpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/MortonOrderTest.cpp
  Log Message:
  [filter] Reverse Morton (#1786)
* Add revert Morton algorithm
* Add test
* Rename option from revert to reverse
* Update documentation
* Some minor changes
  Commit: 59feb3997a413dab105c66dabf0684558f262fc6
      https://github.com/PDAL/PDAL/commit/59feb3997a413dab105c66dabf0684558f262fc6
  Changed paths:
    M doc/stages/filters.python.rst
    M doc/tutorial/pcl_spec.rst
  Log Message:
  fix up filters.ground references that are now out of date
  Commit: 4d9dfe8f48ee860c59d159e190a4f441cc26d78f
      https://github.com/PDAL/PDAL/commit/4d9dfe8f48ee860c59d159e190a4f441cc26d78f
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  Use master branch for Dockerfile.
  Commit: e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
      https://github.com/PDAL/PDAL/commit/e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M pdal/DimUtil.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into config
  Commit: f223102ade3879d885fb54e0e193943b7ae7c413
      https://github.com/PDAL/PDAL/commit/f223102ade3879d885fb54e0e193943b7ae7c413
  Date:   2018-01-26 (Fri, 26 Jan 2018)
  Changed paths:
    M plugins/greyhound/CMakeLists.txt
  Log Message:
  Remove arbiter lib.
Compare: https://github.com/PDAL/PDAL/compare/71953e7b9402...f223102ade38
More information about the pdal-commits mailing list
