[pdal-commits] [PDAL/PDAL] a3135d: Use correct order to traversing stages when stream...
GitHub noreply at github.com
Wed Jun 27 13:21:39 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: a3135db87664265ad6ded32c3b285875929ad375
      https://github.com/PDAL/PDAL/commit/a3135db87664265ad6ded32c3b285875929ad375
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-06-27 (Wed, 27 Jun 2018)
  Changed paths:
    M pdal/StageExtensions.cpp
    M pdal/StageExtensions.hpp
    M pdal/Streamable.cpp
    M test/unit/StreamingTest.cpp
  Log Message:
  Use correct order to traversing stages when streaming (#2067)
* Process points from left to right when streaming.
Close #2023
* PDAL_DLL StageExtensions::set
* Make sure output string is assigned.
      **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
