[pdal-commits] [PDAL/PDAL] 2214bd: Workshop improvements and fixes (#2008)
GitHub
noreply at github.com
Thu May 10 08:47:29 PDT 2018
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 2214bddc9cd7ff5b993a970ea5ac7fcf7721a97c
https://github.com/PDAL/PDAL/commit/2214bddc9cd7ff5b993a970ea5ac7fcf7721a97c
Author: Ryan Pals <ryan at hobu.co>
Date: 2018-05-10 (Thu, 10 May 2018)
Changed paths:
M doc/workshop/exercises/analysis/boundary/boundary.rst
M doc/workshop/exercises/analysis/clipping/attributes.vrt
M doc/workshop/exercises/analysis/clipping/clipping.rst
M doc/workshop/exercises/analysis/colorization/colorization.rst
A doc/workshop/exercises/translation/greyhound-cd-command.txt
M doc/workshop/exercises/translation/greyhound-info-command.txt
M doc/workshop/exercises/translation/greyhound.rst
M doc/workshop/exercises/translation/reprojection-command-1.txt
A doc/workshop/images/osgeo4w-dep-selection.png
A doc/workshop/images/osgeo4w-license-selection.png
A doc/workshop/images/osgeo4w-qgis-selection.png
M doc/workshop/includes/substitutions.rst
M doc/workshop/osgeo4w.rst
Log Message:
* Clarify that user must make greyhound.json file if it does not exist
* Fix typos
* Fix typo
* Fix inlined attributes.vrt for new GDAL behavior, change relative to absolute path
* Fix typo
* Actually fix inline VRT
* Fix formatting issue
* Clarify that user must edit files to change references to C:\Users\hobu\
* Instruct user to install QGIS during installation of OSGeo4W
* Describe the last few steps of OSGeo4W installation
* Explicitly tell user to cd into translation folder
* Remove caret so command matches picture
Remove line continuation so that the command text
matches the picture. The command will not work as
written, because the whitespace causes 'jq' to be
interpretted as ' jq', which causes the entire
command to fail
* Fix typo
* Remind user to edit JSON with correct path
Remind user to open JSON file and replace all
occurances of 'c:\Users\hobu\' with their own
path
* Fix typo
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
