[pdal-commits] [PDAL/PDAL] d09bdc: fix #2246 where image describing merge operation w...
Howard Butler noreply at github.com
Thu Apr 4 08:36:24 PDT 2019
  Branch: refs/heads/sslwin
  Home:   https://github.com/PDAL/PDAL
  Commit: d09bdc581b855baaf002ec0b6381b4ab5b4ee811
      https://github.com/PDAL/PDAL/commit/d09bdc581b855baaf002ec0b6381b4ab5b4ee811
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-03-21 (Thu, 21 Mar 2019)
  Changed paths:
    M doc/images/reproject-merge-pipeline.png
  Log Message:
  fix #2246 where image describing merge operation was backwards (#2420)
  Commit: be7c13c1902788c35f75c01cb51783be4aa5bf9a
      https://github.com/PDAL/PDAL/commit/be7c13c1902788c35f75c01cb51783be4aa5bf9a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M doc/stages/readers.ept.rst
  Log Message:
  EPT doesn't do count.
  Commit: 3fefd14ad4075b5c0eddae462a35e5cd0fe79a7c
      https://github.com/PDAL/PDAL/commit/3fefd14ad4075b5c0eddae462a35e5cd0fe79a7c
  Changed paths:
    M doc/development/compilation/dependencies.rst
    M doc/development/compilation/unix.rst
    M doc/development/compilation/windows.rst
    M doc/download.rst
    M doc/project/integration.rst
    M doc/stages/readers.rst
    M doc/stages/writers.rst
    M doc/stages/writers.tiledb.rst
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/density/density.rst
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/rasterize/classification.json
    M doc/workshop/exercises/analysis/rasterize/rasterize.rst
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/includes/substitutions.rst
    R doc/workshop/osgeo4w.rst
    M doc/workshop/slides/source/software.rst
    M doc/workshop/software.rst
  Log Message:
  remove OSGeo4W mentions from docs and workshop (#2419)
  Commit: 2be8a6e6fcb1870e1d07ba9de1b7056a773ba2d1
      https://github.com/PDAL/PDAL/commit/2be8a6e6fcb1870e1d07ba9de1b7056a773ba2d1
  Changed paths:
    M scripts/docker/ubuntu/Dockerfile
  Log Message:
  fetch released datumgrid files for ubuntu docker build
  Commit: 7143d99bb741fdd1a7b7978ae8c4b93cb1457a6a
      https://github.com/PDAL/PDAL/commit/7143d99bb741fdd1a7b7978ae8c4b93cb1457a6a
  Changed paths:
  Log Message:
  add missing NA grid to ubuntu Dockerfile
  Commit: 4d0df7b5ce18fa78aac8b99fcc46a46110612104
      https://github.com/PDAL/PDAL/commit/4d0df7b5ce18fa78aac8b99fcc46a46110612104
  Date:   2019-03-22 (Fri, 22 Mar 2019)
  Changed paths:
    M doc/pipeline.rst
    M doc/quickstart.rst
    M doc/stages/reader_opts.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.i3s.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.matlab.rst
    M doc/stages/readers.mbio.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.numpy.rst
    M doc/stages/readers.oci.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.pts.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.rdb.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    M doc/stages/readers.slpk.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.terrasolid.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tiledb.rst
    M doc/stages/readers.tindex.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.ept_addon.rst
  Log Message:
  Doc updates.
  Commit: cded9216ac4d4c50e6bfba75a88f0558397f519e
      https://github.com/PDAL/PDAL/commit/cded9216ac4d4c50e6bfba75a88f0558397f519e
  Changed paths:
    M io/EptAddonWriter.cpp
  Log Message:
  Require addons argument for writers.ept_addon.
  Commit: c9d1a4d6cc44418857ed70e21ea38c00e7e0a54b
      https://github.com/PDAL/PDAL/commit/c9d1a4d6cc44418857ed70e21ea38c00e7e0a54b
  Date:   2019-03-28 (Thu, 28 Mar 2019)
  Changed paths:
    M io/PlyWriter.cpp
    A test/data/ply/issue_2421.ply
    M test/unit/io/PlyWriterTest.cpp
  Log Message:
  Change readers.ply output for integers with precision set (#2422)
* Don't write ints using fixed precision.
* Test for issue 2421.
Close #2421
  Commit: d29e234cacf7838cda89b13703b1eb9c7cc770e2
      https://github.com/PDAL/PDAL/commit/d29e234cacf7838cda89b13703b1eb9c7cc770e2
  Changed paths:
    M scripts/conda/osx.sh
  Log Message:
  fix up my conda build script
  Commit: 1a6cc695f2b56ea30282d0d66a684162a54f06f9
      https://github.com/PDAL/PDAL/commit/1a6cc695f2b56ea30282d0d66a684162a54f06f9
  Changed paths:
    A scripts/conda/osx-setup.sh
  Log Message:
  add osx conda setup script
  Commit: cd989707786243bc67d975eb7b4969cd354ddf68
      https://github.com/PDAL/PDAL/commit/cd989707786243bc67d975eb7b4969cd354ddf68
  Date:   2019-03-29 (Fri, 29 Mar 2019)
  Changed paths:
    M cmake/modules/FindOracle.cmake
    M pdal/Metadata.hpp
    M plugins/i3s/lepcc/CMakeLists.txt
    M plugins/sqlite/io/SQLiteWriter.cpp
    M vendor/kazhdan/MultiGridOctreeData.System.inl
  Log Message:
  Updates for the latest gcc/clang compilers.
  Commit: 896fcc075a142ed64528c832680b13802a4badd5
      https://github.com/PDAL/PDAL/commit/896fcc075a142ed64528c832680b13802a4badd5
  Changed paths:
    R doc/apps/diff.rst
    R kernels/DiffKernel.cpp
    R kernels/DiffKernel.hpp
  Log Message:
  remove 'diff' kernel #2302 (#2423)
  Commit: 888aadfae35dbce5e80badfea98f96ab1c527262
      https://github.com/PDAL/PDAL/commit/888aadfae35dbce5e80badfea98f96ab1c527262
  Changed paths:
    M pdal/util/FileUtils.hpp
  Log Message:
  Include <vector> for FileUtils.
  Commit: 5309eeb9152194a0fc94b124d30904a36486a498
      https://github.com/PDAL/PDAL/commit/5309eeb9152194a0fc94b124d30904a36486a498
  Changed paths:
    M io/PlyWriter.cpp
  Log Message:
Close #2421
  Commit: 0a4e3ab8e2e1c671ec507212eb4d51d799e097d7
      https://github.com/PDAL/PDAL/commit/0a4e3ab8e2e1c671ec507212eb4d51d799e097d7
  Changed paths:
    M filters/AssignFilter.cpp
  Log Message:
  Require assignment in filters.assign.
  Commit: eec46c7d8a5e94df10a321322996f390258f4b7f
      https://github.com/PDAL/PDAL/commit/eec46c7d8a5e94df10a321322996f390258f4b7f
  Changed paths:
    M doc/development/overview.rst
    M doc/python.rst
    M doc/stages/filters.approximatecoplanar.rst
    M doc/stages/filters.assign.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.cluster.rst
    M doc/stages/filters.colorinterp.rst
    M doc/stages/filters.colorization.rst
    M doc/stages/filters.cpd.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.delaunay.rst
    M doc/stages/filters.dem.rst
    M doc/stages/filters.divider.rst
    M doc/stages/filters.eigenvalues.rst
    M doc/stages/filters.elm.rst
    M doc/stages/filters.estimaterank.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.greedyprojection.rst
    M doc/stages/filters.gridprojection.rst
    M doc/stages/filters.groupby.rst
    M doc/stages/filters.hag.rst
    M doc/stages/filters.head.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.icp.rst
    M doc/stages/filters.info.rst
    M doc/stages/filters.iqr.rst
    M doc/stages/filters.kdistance.rst
    M doc/stages/filters.locate.rst
    M doc/stages/filters.lof.rst
    M doc/stages/filters.mad.rst
    M doc/stages/filters.matlab.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mongoexpression.rst
    M doc/stages/filters.mongus.rst
    M doc/stages/filters.mortonorder.rst
    M doc/stages/filters.movingleastsquares.rst
    M doc/stages/filters.neighborclassifier.rst
    M doc/stages/filters.nndistance.rst
    M doc/stages/filters.normal.rst
    M doc/stages/filters.outlier.rst
    M doc/stages/filters.overlay.rst
    M doc/stages/filters.pclblock.rst
    M doc/stages/filters.pmf.rst
    M doc/stages/filters.poisson.rst
    M doc/stages/filters.python.rst
    M doc/stages/filters.radialdensity.rst
    M doc/stages/filters.randomize.rst
    M doc/stages/filters.range.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.returns.rst
    M doc/stages/filters.sample.rst
    M doc/stages/filters.smrf.rst
    M doc/stages/filters.sort.rst
    M doc/stages/filters.splitter.rst
    M doc/stages/filters.stats.rst
    M doc/stages/filters.streamcallback.rst
    M doc/stages/filters.tail.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/filters.voxelcenternearestneighbor.rst
    M doc/stages/filters.voxelcentroidnearestneighbor.rst
    M doc/stages/filters.voxelgrid.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.geowave.rst
    M doc/stages/writers.greyhound.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.matlab.rst
    M doc/stages/writers.nitf.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.oci.rst
    M doc/stages/writers.ogr.rst
    M doc/stages/writers.pcd.rst
    M doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.sbet.rst
    M doc/stages/writers.sqlite.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/clipping/index.rst
    M doc/tutorial/las.rst
    M doc/tutorial/reading.rst
    M filters/MongusFilter.cpp
    M filters/MongusFilter.hpp
    M plugins/python/filters/PythonFilter.cpp
  Log Message:
  Stage updates.
  Commit: 404e3c86be8004b532c9f28f5746cfdce0437fb9
      https://github.com/PDAL/PDAL/commit/404e3c86be8004b532c9f28f5746cfdce0437fb9
  Changed paths:
    M doc/pipeline.rst
    M doc/python.rst
  Log Message:
  Merge branch 'doc'
  Commit: 4042630ed9a0bf04eaca0d538f85411c566f68a5
      https://github.com/PDAL/PDAL/commit/4042630ed9a0bf04eaca0d538f85411c566f68a5
  Changed paths:
  Log Message:
  Fix typos.
  Commit: 7b4bcf51b6558917baaba32601ce06b91070339a
      https://github.com/PDAL/PDAL/commit/7b4bcf51b6558917baaba32601ce06b91070339a
  Changed paths:
    M doc/python.rst
  Log Message:
  Stage updates.
  Commit: dad7e0beb5a496b223963419d687f165a3855b95
      https://github.com/PDAL/PDAL/commit/dad7e0beb5a496b223963419d687f165a3855b95
  Changed paths:
  Log Message:
  Fix typos.
  Commit: 1ead1449bcbf7f2d398d7f153355b9f1e637a057
      https://github.com/PDAL/PDAL/commit/1ead1449bcbf7f2d398d7f153355b9f1e637a057
  Changed paths:
    M CMakeLists.txt
  Log Message:
  New version.
  Commit: 3012607d41ca9327a75d70c79d9e008acbedab47
      https://github.com/PDAL/PDAL/commit/3012607d41ca9327a75d70c79d9e008acbedab47
  Changed paths:
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M doc/apps/tindex.rst
    M doc/download.rst
    M filters/HeadFilter.hpp
    M filters/TailFilter.hpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M pdal/Kernel.cpp
    M pdal/Kernel.hpp
    M pdal/Metadata.hpp
    A pdal/SubcommandKernel.cpp
    A pdal/SubcommandKernel.hpp
    M scripts/appveyor/conda/build.cmd
    M scripts/appveyor/config.cmd
    M scripts/appveyor/test/build.cmd
    M test/unit/CMakeLists.txt
    M test/unit/apps/TIndexTest.cpp
    A test/unit/filters/HeadTailFilterTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/1.9-maintenance' into 1.9-maintenance
  Commit: f8fc8b32085c3b4446d4bef91e17c37c6635e107
      https://github.com/PDAL/PDAL/commit/f8fc8b32085c3b4446d4bef91e17c37c6635e107
  Changed paths:
    M RELEASENOTES.txt
    A doc/development/release-notes/1.9.0.md
    M package.sh
  Log Message:
  1.9 Release details.
  Commit: b749a6b2d71cfa6136b2a564164e928b0d3636e2
      https://github.com/PDAL/PDAL/commit/b749a6b2d71cfa6136b2a564164e928b0d3636e2
  Changed paths:
    M CMakeLists.txt
  Log Message:
  New version.
  Commit: 64237a07f9ef2a95365c0f4f6de8b3cbca620413
      https://github.com/PDAL/PDAL/commit/64237a07f9ef2a95365c0f4f6de8b3cbca620413
  Changed paths:
    M RELEASENOTES.txt
    M package.sh
  Log Message:
  Commit: 4ab8c0a56752e58ffae4cb041d8e0b0d80cb4014
      https://github.com/PDAL/PDAL/commit/4ab8c0a56752e58ffae4cb041d8e0b0d80cb4014
  Changed paths:
    M .travis.yml
  Log Message:
  Use 1.9-maintenance for docs.
  Commit: e406e7ec36f915c988b119a73480051f7e12e24b
      https://github.com/PDAL/PDAL/commit/e406e7ec36f915c988b119a73480051f7e12e24b
  Date:   2019-04-01 (Mon, 01 Apr 2019)
  Changed paths:
    M pdal/Metadata.hpp
  Log Message:
  Merge branch '1.9-maintenance'
  Commit: 6ace07100187057c908abb28cdaa5906ea5ae388
      https://github.com/PDAL/PDAL/commit/6ace07100187057c908abb28cdaa5906ea5ae388
  Date:   2019-04-02 (Tue, 02 Apr 2019)
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M RELEASENOTES.txt
    M doc/pipeline.rst
    M doc/python.rst
    M io/PlyWriter.cpp
    M package.sh
    M pdal/Metadata.hpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: ceceb52c421dfc6c22d673432c34277a3aa73771
      https://github.com/PDAL/PDAL/commit/ceceb52c421dfc6c22d673432c34277a3aa73771
  Changed paths:
    M cmake/macros.cmake
    M cmake/modules/FindNumPy.cmake
    M cmake/python.cmake
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/io/CMakeLists.txt
    R plugins/python/plang/CMakeLists.txt
    M scripts/appveyor/conda/recipe/bld.bat
  Log Message:
  1.9rc1 python (#2435)
* Better handle mixed python 2 and 3 packaging.
Close #2431
* Numpy update.
* More fixes for NumPy.
* More numpy.
* Python3 with new cmake fixes.
* fixups for conda python3
  Commit: bc250ff0a029739e3f6dd76841af0f72a3cd36b6
      https://github.com/PDAL/PDAL/commit/bc250ff0a029739e3f6dd76841af0f72a3cd36b6
  Changed paths:
  Log Message:
  Commit: bb453d3f0058dcc32a1ae5fd328d9b1a413064d0
      https://github.com/PDAL/PDAL/commit/bb453d3f0058dcc32a1ae5fd328d9b1a413064d0
  Author: Norman Barker <norman at tiledb.io>
  Date:   2019-04-04 (Thu, 04 Apr 2019)
  Changed paths:
    A test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/OffsetTime.tdb
    A test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__coords.tdb
    A test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__fragment_metadata.tdb
    R test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
    R test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
    R test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
    M test/data/tiledb/array/__array_schema.tdb
    A test/data/tiledb/array/pdal.json
  Log Message:
  changed test array compression to gzip (#2441)
  Commit: 29a8c8aab5040d0e6e9c2c079725fb3e85c529b8
      https://github.com/PDAL/PDAL/commit/29a8c8aab5040d0e6e9c2c079725fb3e85c529b8
  Changed paths:
  Log Message:
  Commit: 37a69f1bea23b55e0e457848d162daa1907070d7
      https://github.com/PDAL/PDAL/commit/37a69f1bea23b55e0e457848d162daa1907070d7
  Changed paths:
  Log Message:
  conda build for osx
  Commit: f0c8fa62cd741e9ee276d1cc85979f0070131fd1
      https://github.com/PDAL/PDAL/commit/f0c8fa62cd741e9ee276d1cc85979f0070131fd1
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M RELEASENOTES.txt
    M doc/pipeline.rst
    M doc/python.rst
    M io/PlyWriter.cpp
    M package.sh
    M pdal/Metadata.hpp
  Log Message:
  Merge branch 'master' into sslwin
Compare: https://github.com/PDAL/PDAL/compare/cb0fb7f8c83d...f0c8fa62cd74
More information about the pdal-commits mailing list
