[pdal-commits] [PDAL/PDAL] 9aae09: Separate BOX and Bounds.
Andrew Bell noreply at github.com
Wed Apr 24 07:27:14 PDT 2019
  Branch: refs/heads/issue-2295
  Home:   https://github.com/PDAL/PDAL
  Commit: 9aae090f75fc53ef70bd72a35dd5f9beeeb317da
      https://github.com/PDAL/PDAL/commit/9aae090f75fc53ef70bd72a35dd5f9beeeb317da
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-04-23 (Tue, 23 Apr 2019)
  Changed paths:
    M filters/CropFilter.cpp
    M filters/InfoFilter.hpp
    M io/EptReader.hpp
    M io/GDALWriter.hpp
    M io/LasHeader.hpp
    M io/private/EptSupport.hpp
    A pdal/Bounds.cpp
    A pdal/Bounds.hpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.hpp
    M pdal/Metadata.cpp
    M pdal/Metadata.hpp
    M pdal/PDALUtils.hpp
    M pdal/PointView.hpp
    M pdal/Polygon.hpp
    M pdal/QuadIndex.hpp
    M pdal/QuickInfo.hpp
    R pdal/util/Bounds.cpp
    R pdal/util/Bounds.hpp
    A pdal/util/Box.cpp
    A pdal/util/Box.hpp
    M pdal/util/CMakeLists.txt
    M plugins/greyhound/io/GreyhoundCommon.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/nitf/io/NitfFileWriter.hpp
    M test/unit/BoundsTest.cpp
    M test/unit/Support.hpp
    M tools/lasdump/Header.hpp
  Log Message:
  Commit: 136732f411015421796342cb455abc631e410bd4
      https://github.com/PDAL/PDAL/commit/136732f411015421796342cb455abc631e410bd4
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M cmake/arbiter.cmake
    R cmake/json.cmake
    R cmake/modules/FindJSONCPP.cmake
    A cmake/nlohmann.cmake
    M dimbuilder/CMakeLists.txt
    M dimbuilder/DimBuilder.cpp
    M dimbuilder/DimBuilder.hpp
    M doc/development/compilation/unix.rst
    M doc/development/compilation/windows.rst
    M doc/quickstart.rst
    M doc/references.rst
    A doc/stages/filters.covariancefeatures.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/writers.ply.rst
    A filters/CovarianceFeaturesFilter.cpp
    A filters/CovarianceFeaturesFilter.hpp
    M filters/InfoFilter.cpp
    M filters/MongoExpressionFilter.hpp
    M filters/StatsFilter.cpp
    M filters/private/mongoexpression/Comparison.cpp
    M filters/private/mongoexpression/Comparison.hpp
    M filters/private/mongoexpression/Expression.cpp
    M filters/private/mongoexpression/Expression.hpp
    M filters/private/mongoexpression/Support.hpp
    M io/EptAddonWriter.cpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M kernels/PipelineKernel.cpp
    M kernels/TranslateKernel.cpp
    M kernels/private/density/OGR.cpp
    M kernels/private/density/OGR.hpp
    M pdal/DimUtil.hpp
    M pdal/KDIndex.hpp
    M pdal/Options.cpp
    M pdal/PDALUtils.cpp
    M pdal/PipelineReaderJSON.cpp
    M pdal/PipelineReaderJSON.hpp
    M pdal/PipelineWriter.cpp
    M pdal/StageExtensions.cpp
    M plugins/greyhound/CMakeLists.txt
    M plugins/greyhound/io/GreyhoundCommon.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/greyhound/io/GreyhoundWriter.cpp
    M plugins/greyhound/io/GreyhoundWriter.hpp
    M plugins/greyhound/io/bounds.cpp
    M plugins/greyhound/io/bounds.hpp
    M plugins/greyhound/io/point.hpp
    M plugins/greyhound/test/GreyhoundReaderTest.cpp
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriUtil.hpp
    M plugins/i3s/io/I3SReader.cpp
    M plugins/i3s/io/I3SReader.hpp
    M plugins/i3s/io/SlpkReader.cpp
    M plugins/i3s/io/SlpkReader.hpp
    M plugins/matlab/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
    M plugins/pcl/pipeline/PCLPipeline.h
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/filters/PythonFilter.hpp
    M plugins/rdb/CMakeLists.txt
    M plugins/rdb/io/RdbPointcloud.cpp
    M plugins/rdb/io/RdbReader.cpp
    M scripts/appveyor/conda/recipe/meta.yaml
    M scripts/conda/osx-setup.sh
    M scripts/docker/Dockerfile
    M scripts/docker/centos/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    M scripts/linux-install-scripts/packages.sh
    M scripts/linux-install-scripts/pdal.sh
    M test/data/ply/issue_2421.ply
    A test/data/ply/sized_dims.ply
    A test/data/ply/unsized_dims.ply
    M test/unit/CMakeLists.txt
    M test/unit/OptionsTest.cpp
    A test/unit/PipelineWriterTest.cpp
    M test/unit/ProgramArgsTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    A test/unit/filters/CovarianceFeaturesTest.cpp
    M test/unit/filters/MongoExpressionFilterTest.cpp
    M test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/PlyWriterTest.cpp
    M vendor/arbiter/CMakeLists.txt
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
    R vendor/jsoncpp/dist/CMakeLists.txt
    R vendor/jsoncpp/dist/json/forwards.h
    R vendor/jsoncpp/dist/json/json.h
    R vendor/jsoncpp/dist/jsoncpp.cpp
    A vendor/nlohmann/nlohmann/json.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2295
Compare: https://github.com/PDAL/PDAL/compare/9aae090f75fc%5E...136732f41101
More information about the pdal-commits mailing list
