[pdal-commits] [PDAL/PDAL] 7737b6: Change box parsing to allow for more flexible spec...
Andrew Bell noreply at github.com
Fri Apr 26 09:27:52 PDT 2019
  Branch: refs/heads/issue-2295
  Home:   https://github.com/PDAL/PDAL
  Commit: 7737b603d32d4f81802ffa138250db66380b3dd5
      https://github.com/PDAL/PDAL/commit/7737b603d32d4f81802ffa138250db66380b3dd5
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-04-25 (Thu, 25 Apr 2019)
  Changed paths:
    M pdal/Bounds.cpp
    M pdal/util/Box.cpp
    M pdal/util/Box.hpp
  Log Message:
  Change box parsing to allow for more flexible specifications.
  Commit: 005c458daae588b5a0368d8a319cf3479296a7a4
      https://github.com/PDAL/PDAL/commit/005c458daae588b5a0368d8a319cf3479296a7a4
  Date:   2019-04-26 (Fri, 26 Apr 2019)
  Changed paths:
    M pdal/Bounds.cpp
    M pdal/Bounds.hpp
    M pdal/SpatialReference.cpp
    M pdal/util/Box.cpp
    M plugins/greyhound/io/GreyhoundCommon.cpp
    M test/unit/BoundsTest.cpp
  Log Message:
  Add support for SRS in Bounds.
Compare: https://github.com/PDAL/PDAL/compare/7bdc5d3dbe9d...005c458daae5
More information about the pdal-commits mailing list
