[pdal-commits] [PDAL/PDAL] 3bfb4b: Elaborate difference between ICP and CPD filters.
Jason Sun noreply at github.com
Mon Apr 29 06:10:41 PDT 2019
  Branch: refs/heads/cherry-pick-backport-2472-to-1.9-maintenance-c66e2874-27a5-498b-9a6e-b6a74f566326
  Home:   https://github.com/PDAL/PDAL
  Commit: 3bfb4b713bf64ed8e112e6f5c158516715884cdf
      https://github.com/PDAL/PDAL/commit/3bfb4b713bf64ed8e112e6f5c158516715884cdf
  Author: Jason Sun <sunapi386 at gmail.com>
  Date:   2019-04-26 (Fri, 26 Apr 2019)
  Changed paths:
    M doc/stages/filters.cpd.rst
    M doc/stages/filters.icp.rst
    M doc/stages/references.bib
  Log Message:
  Commit: 30a8070dd430e7605b2f7d928a9afabe50cff6e0
      https://github.com/PDAL/PDAL/commit/30a8070dd430e7605b2f7d928a9afabe50cff6e0
  Date:   2019-04-27 (Sat, 27 Apr 2019)
  Changed paths:
    M CMakeLists.txt
    M RELEASENOTES.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M cmake/arbiter.cmake
    A cmake/json.cmake
    A cmake/modules/FindJSONCPP.cmake
    R cmake/nlohmann.cmake
    R cmake/openssl.cmake
    M cmake/python.cmake
    M dimbuilder/CMakeLists.txt
    M dimbuilder/DimBuilder.cpp
    M dimbuilder/DimBuilder.hpp
    M doc/development/compilation/unix.rst
    M doc/development/compilation/windows.rst
    M doc/development/release-notes/1.9.0.md
    M doc/pipeline.rst
    M doc/quickstart.rst
    M doc/references.rst
    R doc/stages/filters.covariancefeatures.rst
    M doc/stages/reader_opts.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.i3s.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.matlab.rst
    M doc/stages/readers.mbio.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.numpy.rst
    M doc/stages/readers.oci.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.pts.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.rdb.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    M doc/stages/readers.slpk.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.terrasolid.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tiledb.rst
    M doc/stages/readers.tindex.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.ept_addon.rst
    M doc/stages/writers.ply.rst
    M doc/tutorial/iowa-entwine.rst
    R filters/CovarianceFeaturesFilter.cpp
    R filters/CovarianceFeaturesFilter.hpp
    M filters/InfoFilter.cpp
    M filters/MongoExpressionFilter.hpp
    M filters/StatsFilter.cpp
    M filters/private/mongoexpression/Comparison.cpp
    M filters/private/mongoexpression/Comparison.hpp
    M filters/private/mongoexpression/Expression.cpp
    M filters/private/mongoexpression/Expression.hpp
    M filters/private/mongoexpression/Support.hpp
    M io/EptAddonWriter.cpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/PlyWriter.cpp
    M io/PlyWriter.hpp
    M io/private/EptSupport.hpp
    M kernels/PipelineKernel.cpp
    M kernels/TranslateKernel.cpp
    M pdal/DimUtil.hpp
    M pdal/KDIndex.hpp
    M pdal/Options.cpp
    M pdal/PDALUtils.cpp
    M pdal/PipelineReaderJSON.cpp
    M pdal/PipelineReaderJSON.hpp
    M pdal/StageExtensions.cpp
    M plugins/greyhound/CMakeLists.txt
    M plugins/greyhound/io/GreyhoundCommon.cpp
    M plugins/greyhound/io/GreyhoundCommon.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/greyhound/io/GreyhoundWriter.cpp
    M plugins/greyhound/io/GreyhoundWriter.hpp
    M plugins/greyhound/io/bounds.cpp
    M plugins/greyhound/io/bounds.hpp
    M plugins/greyhound/io/point.hpp
    M plugins/greyhound/test/GreyhoundReaderTest.cpp
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/i3s/io/EsriUtil.hpp
    M plugins/i3s/io/I3SReader.cpp
    M plugins/i3s/io/I3SReader.hpp
    M plugins/i3s/io/SlpkReader.cpp
    M plugins/i3s/io/SlpkReader.hpp
    M plugins/matlab/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
    M plugins/pcl/pipeline/PCLPipeline.h
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/filters/PythonFilter.hpp
    M plugins/rdb/CMakeLists.txt
    M plugins/rdb/io/RdbPointcloud.cpp
    M plugins/rdb/io/RdbReader.cpp
    M scripts/appveyor/conda/recipe/meta.yaml
    M scripts/appveyor/test/build.cmd
    R scripts/conda/osx-setup.sh
    M scripts/conda/osx.sh
    R scripts/conda/win64-setup.bat
    R scripts/conda/win64.bat
    A scripts/conda/win64.sh
    M scripts/docker/Dockerfile
    M scripts/docker/centos/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    M scripts/linux-install-scripts/packages.sh
    M scripts/linux-install-scripts/pdal.sh
    M test/data/ply/issue_2421.ply
    R test/data/ply/sized_dims.ply
    R test/data/ply/unsized_dims.ply
    M test/unit/CMakeLists.txt
    M test/unit/OptionsTest.cpp
    M test/unit/ProgramArgsTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    R test/unit/filters/CovarianceFeaturesTest.cpp
    M test/unit/filters/MongoExpressionFilterTest.cpp
    M test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/PlyWriterTest.cpp
    M vendor/arbiter/CMakeLists.txt
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
    A vendor/jsoncpp/dist/CMakeLists.txt
    A vendor/jsoncpp/dist/json/forwards.h
    A vendor/jsoncpp/dist/json/json.h
    A vendor/jsoncpp/dist/jsoncpp.cpp
    R vendor/nlohmann/nlohmann/json.hpp
  Log Message:
  Sibling of 848d0ff5c12f281d5bbdae28b475bdc13d2eb84e
Compare: https://github.com/PDAL/PDAL/compare/04610000b43e...30a8070dd430
More information about the pdal-commits mailing list
