[pdal-commits] [PDAL/PDAL] efa1d8: TileDB plugin (#2363)
Andrew Bell noreply at github.com
Thu Feb 14 07:38:50 PST 2019
  Branch: refs/heads/conda-appveyor
  Home:   https://github.com/PDAL/PDAL
  Commit: efa1d8e0e254a70214793e0cef48e8584006e79b
      https://github.com/PDAL/PDAL/commit/efa1d8e0e254a70214793e0cef48e8584006e79b
  Author: Norman Barker <norman at tiledb.io>
  Date:   2019-02-13 (Wed, 13 Feb 2019)
  Changed paths:
    M appveyor.yml
    A cmake/modules/FindTileDB.cmake
    M cmake/options.cmake
    A cmake/tiledb.cmake
    M doc/development/compilation/dependencies.rst
    M doc/quickstart.rst
    A doc/stages/readers.tiledb.rst
    A doc/stages/writers.tiledb.rst
    M plugins/CMakeLists.txt
    A plugins/tiledb/CMakeLists.txt
    A plugins/tiledb/io/TileDBReader.cpp
    A plugins/tiledb/io/TileDBReader.hpp
    A plugins/tiledb/io/TileDBWriter.cpp
    A plugins/tiledb/io/TileDBWriter.hpp
    A plugins/tiledb/test/TileDBReaderTest.cpp
    A plugins/tiledb/test/TileDBWriterTest.cpp
    M scripts/conda/osx.sh
    M scripts/conda/win64.sh
    M scripts/docker/master/ubuntu/Dockerfile
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
    A test/data/tiledb/array/__array_schema.tdb
    A test/data/tiledb/array/__lock.tdb
  Log Message:
* initial read and write for TileDB
* 2363:pr comments
* removed dependency on pdal-tiledb branch
  Commit: 3872af3641976a4e5ab54bc36d23a4d568709ca3
      https://github.com/PDAL/PDAL/commit/3872af3641976a4e5ab54bc36d23a4d568709ca3
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-02-14 (Thu, 14 Feb 2019)
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge branch 'master' into conda-appveyor
Compare: https://github.com/PDAL/PDAL/compare/f68a9764b9e0...3872af364197
More information about the pdal-commits mailing list
