[pdal-commits] [PDAL/PDAL] c53d33: Fix global symbol export for python (#2598)
Howard Butler noreply at github.com
Wed Jul 17 07:39:44 PDT 2019
  Branch: refs/heads/remove-greyhound
  Home:   https://github.com/PDAL/PDAL
  Commit: c53d332f7d8bf3db832f8c44ddac3292b1b0a568
      https://github.com/PDAL/PDAL/commit/c53d332f7d8bf3db832f8c44ddac3292b1b0a568
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-07-03 (Wed, 03 Jul 2019)
  Changed paths:
    M pdal/util/Utils.hpp
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/io/CMakeLists.txt
    M plugins/python/plang/Environment.cpp
  Log Message:
* Changes for ubuntu python library loading.
* Remove test check.
* Clean-up.
  Commit: 99efbab5d0bbfdbce56da6d537e67eddd69829e7
      https://github.com/PDAL/PDAL/commit/99efbab5d0bbfdbce56da6d537e67eddd69829e7
  Changed paths:
    M plugins/tiledb/io/TileDBWriter.cpp
  Log Message:
  Fix index/coords issues. (#2599)
Close #2596
  Commit: 959fbed9ede183ce4c1e269ccc91bb01dff5eae7
      https://github.com/PDAL/PDAL/commit/959fbed9ede183ce4c1e269ccc91bb01dff5eae7
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  Error on unexpected arguments for raw 'pdal' command. (#2589)
  Commit: 3b8e72355bbaa00ca2e9ec94a73812925026f610
      https://github.com/PDAL/PDAL/commit/3b8e72355bbaa00ca2e9ec94a73812925026f610
  Author: Mathieu <mathieu1 at users.noreply.github.com>
  Date:   2019-07-04 (Thu, 04 Jul 2019)
  Changed paths:
  Log Message:
  Use c++ comments (#2601)
  Commit: 82402cfd1aec436941571ce2beb535493a70b719
      https://github.com/PDAL/PDAL/commit/82402cfd1aec436941571ce2beb535493a70b719
  Date:   2019-07-08 (Mon, 08 Jul 2019)
  Changed paths:
  Log Message:
  Use generic names for plugins.
  Commit: 87d9384da84464526f35ee0a89634dfdfc6ead7b
      https://github.com/PDAL/PDAL/commit/87d9384da84464526f35ee0a89634dfdfc6ead7b
  Date:   2019-07-12 (Fri, 12 Jul 2019)
  Changed paths:
    M io/EptReader.cpp
  Log Message:
  Fix thread-safety issue when writing addon data. (#2611)
Fix point count for addon data initialization.
Close #2610
  Commit: abecd56a177c4e37a791ee27d4f6e7d2c403367a
      https://github.com/PDAL/PDAL/commit/abecd56a177c4e37a791ee27d4f6e7d2c403367a
  Changed paths:
    M plugins/e57/io/E57Reader.cpp
    M plugins/e57/io/E57Reader.hpp
    M plugins/e57/libE57Format/src/CheckedFile.cpp
    M plugins/e57/libE57Format/src/CheckedFile.h
  Log Message:
  Rename open64 to portableOpen. (#2608)
* Rename open64 to portableOpen.
* Make sure off_t is defined.
  Commit: 69282f876476f927b8a81de333647f2f7ed80f2f
      https://github.com/PDAL/PDAL/commit/69282f876476f927b8a81de333647f2f7ed80f2f
  Author: Pravin Shinde <pravin at helix.re>
  Date:   2019-07-15 (Mon, 15 Jul 2019)
  Changed paths:
    M io/EptReader.cpp
    M io/EptReader.hpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Streamable EPT Reader (#2603)
  Commit: 838ec608dd288369687f3e81d6c96446565c417e
      https://github.com/PDAL/PDAL/commit/838ec608dd288369687f3e81d6c96446565c417e
  Changed paths:
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Updated Arbiter with upstream (#2604)
  Commit: 2be74ec122fbaa273e3a3993ab61db6814f0c3f8
      https://github.com/PDAL/PDAL/commit/2be74ec122fbaa273e3a3993ab61db6814f0c3f8
  Author: Nicolas Chaulet <nicolas.chaulet at gmail.com>
  Changed paths:
    M plugins/e57/io/E57Writer.cpp
    M plugins/e57/io/E57Writer.hpp
    M plugins/e57/io/Scan.cpp
    M plugins/e57/io/Scan.hpp
    M plugins/e57/io/Utils.cpp
    M plugins/e57/test/E57ReaderTest.cpp
    M plugins/e57/test/ScanTest.cpp
  Log Message:
  e57 - Save bounding box and implement Preview function (#2595)
* Preview function for e57
* Bounding box support for preview
* Address comments
* Return type fixed for transformPoint
  Commit: 45a497ea5b615a0d56f86667b2491fcd80e23182
      https://github.com/PDAL/PDAL/commit/45a497ea5b615a0d56f86667b2491fcd80e23182
  Changed paths:
    M io/PlyWriter.cpp
  Log Message:
  Fail if we can't open PLY output.
  Commit: a642d6c23622d6e6004436565b9ee493dd297ac5
      https://github.com/PDAL/PDAL/commit/a642d6c23622d6e6004436565b9ee493dd297ac5
  Date:   2019-07-16 (Tue, 16 Jul 2019)
  Changed paths:
    M PDALConfig.cmake.in
  Log Message:
  Use the proper libraries for linking with downstream projects.
  Commit: 7e892a8c4de7cb67d7e8a2f3584710fb9c5aedd0
      https://github.com/PDAL/PDAL/commit/7e892a8c4de7cb67d7e8a2f3584710fb9c5aedd0
  Date:   2019-07-17 (Wed, 17 Jul 2019)
  Changed paths:
  Log Message:
  Fix bug with opening the e57 file in CloudCompare (#2618)
  Commit: 8f827110437a02fbd157f13edf5306add4554a86
      https://github.com/PDAL/PDAL/commit/8f827110437a02fbd157f13edf5306add4554a86
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M apps/pdal.cpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/PlyWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into remove-greyhound
Compare: https://github.com/PDAL/PDAL/compare/25294aa0ed10...8f827110437a
More information about the pdal-commits mailing list
