[pdal-commits] [PDAL/PDAL] 31d500: Write islands as separate polys in WKT (#2549)
Andrew Bell noreply at github.com
Tue Jun 4 11:49:31 PDT 2019
  Branch: refs/heads/issue-2513
  Home:   https://github.com/PDAL/PDAL
  Commit: 31d500339a269045318232e32f488283ec0bbc72
      https://github.com/PDAL/PDAL/commit/31d500339a269045318232e32f488283ec0bbc72
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-06-03 (Mon, 03 Jun 2019)
  Changed paths:
    M filters/private/hexer/HexGrid.cpp
    M filters/private/hexer/HexGrid.hpp
    M filters/private/hexer/Path.cpp
    M filters/private/hexer/Path.hpp
    M test/unit/filters/HexbinFilterTest.cpp
  Log Message:
* Fix WKT generation for polygons with islands.
* Add test.
* Add link to photo of data.
* Export functions for test.
* Add another test function.
* Compiler warning fixes.
* Test fixes.
* Spelling fix.
* Remove werror.
* Fix SRS test, spelling.
* Revert "Compiler warning fixes."
This reverts commit 36b25ad685fe73b4b45afe16bae6788461557007.
* Revert "Fix SRS test, spelling."
This reverts commit 9a32bb6e6a3d92e4d3721def7cc99b04d7d9d5d0.
* Revert "Remove werror."
This reverts commit 1dd063345c673d1fb738d5687a51a15dd31b3761.
* Revert "Test fixes."
This reverts commit 0c62ab0d3c254ecb4ddfe30b7d321c4dbd11ddfb.
* Spelling.
* Remove werror.
* Remove cruft.
* Re-add cassert.
  Commit: 8d492460b483f0b5f3a00318f0793d3d254ab4d0
      https://github.com/PDAL/PDAL/commit/8d492460b483f0b5f3a00318f0793d3d254ab4d0
  Changed paths:
    M apps/pdal.cpp
    M cmake/policies.cmake
    M dimbuilder/DimBuilder.cpp
    M filters/ReprojectionFilter.cpp
    M filters/ReprojectionFilter.hpp
    M filters/private/Point.hpp
    M io/EptReader.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.cpp
    M pdal/SpatialReference.cpp
    M pdal/Stage.hpp
    A pdal/private/SrsTransform.cpp
    A pdal/private/SrsTransform.hpp
    M plugins/e57/io/E57Reader.cpp
    M plugins/e57/libE57Format/src/E57Exception.cpp
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/i3s/test/SlpkReaderTest.cpp
    M plugins/i3s/test/i3sReaderTest.cpp
    M plugins/icebridge/io/Hdf5Handler.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M test/data/ept/ept-star/ept.json
    M test/data/filters/ferry.json.in
    M test/unit/ProgramArgsTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Projfix (#2548)
* Add test.
* Test fixes.
* Compiler error.
* Warning fix.
* SRS fix.
* Add reference.
* Explicit SRS.
* Use nullptr to SRS ctor.
* Test meter spelling.
* Use X, Y and Z in geocentric transform.
Remove dead code.
* More test.
* Lat/Lon for EPSG:4326 with GDAL 3+
* More test.
* Add SrsTransform and eliminate a ton of overly complex code.
Also make tests pass in the process.
* Fix capitalization.
* Spatial ref precision.
* Read data from the metadata child "data" rather than the VLR node's data
for forwarded VLRs.
* Add test LAS file with valid WKT.
* More PROJ 3 fixes.
* Updates for PROJ 6.
* Make SrsTransform private.
* Moved SrsTransform.
* Add doc.
  Commit: 2151aab70f678964984c30d66a28a5642b13e909
      https://github.com/PDAL/PDAL/commit/2151aab70f678964984c30d66a28a5642b13e909
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M test/unit/EigenTest.cpp
  Log Message:
  Begin removing dead Eigen code (#2541)
  Commit: 6e7b5817c097dbd7f125516c4227d091d685e1d7
      https://github.com/PDAL/PDAL/commit/6e7b5817c097dbd7f125516c4227d091d685e1d7
  Changed paths:
    M doc/embed.py
    M doc/index.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.rst
    A doc/type-table.csv
    A doc/types.rst
  Log Message:
  Add page for data types. (#2537)
  Commit: 949880ea9af1d653cb2fc30cd35dcadd421a5465
      https://github.com/PDAL/PDAL/commit/949880ea9af1d653cb2fc30cd35dcadd421a5465
  Author: James McClain <jmcclain at azavea.com>
  Changed paths:
    M filters/HAGFilter.cpp
    M filters/HAGFilter.hpp
    A filters/private/delaunator-decl.hpp
  Log Message:
  [WiP] Add Rudimentary TIN-like Behavior to HAG Filter (#2520)
* Improve the HAG filter with multi-point mode
* Inline Everything in Delaunator
* Add `delaunay_fans` Flag
* Distance from Planes
* Distance Along Z
* Revert Changes to delaunator.hpp
* Re-declare Delaunator Public Interface
* Address Review Comments
* unsigned int -> size_t
  Commit: 0db3817c3946c2798df49ed4b524c4d84560dd22
      https://github.com/PDAL/PDAL/commit/0db3817c3946c2798df49ed4b524c4d84560dd22
  Date:   2019-06-04 (Tue, 04 Jun 2019)
  Changed paths:
    M apps/pdal.cpp
    M doc/embed.py
    M doc/index.rst
    A doc/types.rst
    M io/EptReader.cpp
    M pdal/Geometry.cpp
    M pdal/Stage.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2513
Compare: https://github.com/PDAL/PDAL/compare/cdcb96c8dbe7...0db3817c3946
More information about the pdal-commits mailing list
