[pdal-commits] [PDAL/PDAL] 9cb932: Add filters.shell that allows you to inline shell ...
Howard Butler noreply at github.com
Thu Jun 13 11:33:20 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 9cb932bbd351f35b8e8275a1fbecb642847dd407
      https://github.com/PDAL/PDAL/commit/9cb932bbd351f35b8e8275a1fbecb642847dd407
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-06-13 (Thu, 13 Jun 2019)
  Changed paths:
    A doc/stages/filters.shell.rst
    A filters/ShellFilter.cpp
    A filters/ShellFilter.hpp
    A test/data/pipeline/shell.json.in
    M test/unit/CMakeLists.txt
    A test/unit/filters/ShellFilterTest.cpp
  Log Message:
  Add filters.shell that allows you to inline shell commands as part of pipelines (#2430)
* fix up my conda build script
* add osx conda setup script
* Add filters.shell
* configuredpath instead of datapath
* fix up my windows conda build setup
* only allow filters.shell if PDAL_ALLOW_SHELL environment variable is set
* add filters.shell doc
More information about the pdal-commits mailing list
