[pdal-commits] [PDAL/PDAL] 328bec: centos dockerfile fix
Howard Butler noreply at github.com
Sun Jun 23 13:13:21 PDT 2019
  Branch: refs/heads/azure-pipelines
  Home:   https://github.com/PDAL/PDAL
  Commit: 328bec43ecf9a8ac7a5204d6f685de6ea8b039eb
      https://github.com/PDAL/PDAL/commit/328bec43ecf9a8ac7a5204d6f685de6ea8b039eb
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-06-12 (Wed, 12 Jun 2019)
  Changed paths:
    M scripts/docker/centos/Dockerfile
  Log Message:
  Commit: ac997bfe8df0ae1e0e1c323a69cc5ad1fb0ba0ed
      https://github.com/PDAL/PDAL/commit/ac997bfe8df0ae1e0e1c323a69cc5ad1fb0ba0ed
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-06-13 (Thu, 13 Jun 2019)
  Changed paths:
    M io/PlyWriter.cpp
  Log Message:
  Follow sized_types for faces header.
  Commit: 9cb932bbd351f35b8e8275a1fbecb642847dd407
      https://github.com/PDAL/PDAL/commit/9cb932bbd351f35b8e8275a1fbecb642847dd407
  Changed paths:
    A doc/stages/filters.shell.rst
    A filters/ShellFilter.cpp
    A filters/ShellFilter.hpp
    A test/data/pipeline/shell.json.in
    M test/unit/CMakeLists.txt
    A test/unit/filters/ShellFilterTest.cpp
  Log Message:
  Add filters.shell that allows you to inline shell commands as part of pipelines (#2430)
* fix up my conda build script
* add osx conda setup script
* Add filters.shell
* configuredpath instead of datapath
* fix up my windows conda build setup
* only allow filters.shell if PDAL_ALLOW_SHELL environment variable is set
* add filters.shell doc
  Commit: d68c7e1121fba533bb34c9de5c99fda53edbd6e5
      https://github.com/PDAL/PDAL/commit/d68c7e1121fba533bb34c9de5c99fda53edbd6e5
  Date:   2019-06-14 (Fri, 14 Jun 2019)
  Changed paths:
    M io/PlyWriter.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 105a1a24dd371a6feb41c62a3d1d488040c20056
      https://github.com/PDAL/PDAL/commit/105a1a24dd371a6feb41c62a3d1d488040c20056
  Date:   2019-06-20 (Thu, 20 Jun 2019)
  Changed paths:
    M apps/pdal.cpp
    M pdal/PluginManager.cpp
    M pdal/PluginManager.hpp
    M pdal/StageExtensions.cpp
    M pdal/StageExtensions.hpp
    M pdal/StageFactory.cpp
  Log Message:
  Add extensions to driver output. (#2573)
* Add extensions to driver output.
* Export StageExtensions::extensions()
  Commit: 7d6b57569cd321124eeb379263a94d808643bdfe
      https://github.com/PDAL/PDAL/commit/7d6b57569cd321124eeb379263a94d808643bdfe
  Changed paths:
    M filters/TransformationFilter.cpp
    M filters/TransformationFilter.hpp
    M test/unit/filters/TransformationFilterTest.cpp
  Log Message:
  More flexible handling for transformation matrix (#2569)
* Temp checkin.
* Initial check-in.
* Make TransformationFilter more generic.
* Add doFilter().
* Remove extra "public".
* More PDAL_DLL.
* Remove accidentally added files.
  Commit: 62143d0a7af8970111ede1997103fd0a2a5b604c
      https://github.com/PDAL/PDAL/commit/62143d0a7af8970111ede1997103fd0a2a5b604c
  Author: Norman Barker <norman at tiledb.io>
  Date:   2019-06-21 (Fri, 21 Jun 2019)
  Changed paths:
    M doc/stages/writers.tiledb.rst
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
  Log Message:
  TileDB: Add append option to writer (#2577)
* TileDB: Add append option to writer
* tiledb: add check that attributes exists when appending data
  Commit: dc272f96fafbd9feb2f00523fff91c729dc73fc1
      https://github.com/PDAL/PDAL/commit/dc272f96fafbd9feb2f00523fff91c729dc73fc1
  Changed paths:
    M kernels/PipelineKernel.cpp
    M pdal/PipelineManager.hpp
  Log Message:
  Remove dead code/comment (#2580)
* Remove dead function that nobody should be using.
Fix comment.
Close #2199
* Log warning if stream option is used.
Close #2199
  Commit: d1b6e7a0721245944e43abd0623a95ed09deb55c
      https://github.com/PDAL/PDAL/commit/d1b6e7a0721245944e43abd0623a95ed09deb55c
  Changed paths:
    M filters/PoissonFilter.cpp
  Log Message:
  Apply inverse transform to poisson-generated points (#2579)
* Temp checkin.
* Initial check-in.
* Add doFilter().
* More PDAL_DLL.
* Apply the inverse transform to generated points.
Close #1840
  Commit: 8559c75493624607899ed12131e598cb5851f233
      https://github.com/PDAL/PDAL/commit/8559c75493624607899ed12131e598cb5851f233
  Changed paths:
    M filters/DelaunayFilter.cpp
    M filters/DelaunayFilter.hpp
  Log Message:
  Don't run triangulation if we don't have at least three points. (#2555)
Use filter() instead of run() for cleaner interface.
Close #2513
  Commit: 6e4fa9eba8490a0965e2b047d1556eaaf5673dd2
      https://github.com/PDAL/PDAL/commit/6e4fa9eba8490a0965e2b047d1556eaaf5673dd2
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M doc/references.rst
    M doc/stages/filters.lof.rst
    A doc/stages/filters.miniball.rst
    A doc/stages/filters.planefit.rst
    A doc/stages/filters.reciprocity.rst
    A filters/MiniballFilter.cpp
    A filters/MiniballFilter.hpp
    A filters/PlaneFitFilter.cpp
    A filters/PlaneFitFilter.hpp
    A filters/ReciprocityFilter.cpp
    A filters/ReciprocityFilter.hpp
    A filters/private/miniball/Seb-inl.h
    A filters/private/miniball/Seb.h
    A filters/private/miniball/Seb_configure.h
    A filters/private/miniball/Seb_debug.C
    A filters/private/miniball/Seb_debug.h
    A filters/private/miniball/Seb_point.h
    A filters/private/miniball/Subspan-inl.h
    A filters/private/miniball/Subspan.h
    A test/unit/filters/ReciprocityFilterTest.cpp
  Log Message:
  Add outlier detection criterion and make minor edit to filters.lof documentation (#2504)
* Add outlier detection criterion and make minor edit to filters.lof documentation
This commit adds three filters that are implementations of the outlier
detection criterion specified in Weyrich, T et al. “Post-Processing of Scanned
3D Surface Data.” Proceedings of Eurographics Symposium on Point-Based Graphics
2004 (2004): 85–94. Print.
* Nearest-Neighbor Reciprocity Criterion available as filters.reciprocity
* Miniball Criterion available as filters.miniball
* Plane Fit Criterion available as filters.planefit
* Removing debug header enables us to compile on Windows
* Update Eigen matrix from float to double
  Commit: 8e489feb174c6b0f53a36c5d4683bc231aca07e4
      https://github.com/PDAL/PDAL/commit/8e489feb174c6b0f53a36c5d4683bc231aca07e4
  Changed paths:
    M filters/CovarianceFeaturesFilter.cpp
    M filters/MiniballFilter.cpp
    M filters/PlaneFitFilter.cpp
    M filters/ReciprocityFilter.cpp
  Log Message:
  Update threadLists to drop the unused thread index (#2583)
  Commit: 9b872a6b4c45501f41862a76db1bc5d77e44bd03
      https://github.com/PDAL/PDAL/commit/9b872a6b4c45501f41862a76db1bc5d77e44bd03
  Date:   2019-06-23 (Sun, 23 Jun 2019)
  Changed paths:
    M pdal/PDALUtils.hpp
    M pdal/util/FileUtils.cpp
    M pdal/util/Utils.cpp
    M scripts/docker/alpine/Dockerfile.dependencies
    M test/unit/apps/TIndexTest.cpp
    M test/unit/apps/TranslateTest.cpp
  Log Message:
  Change WIN32 macro to _WIN32 (#2581)
  Commit: d9c5b65ad4cfe08b5c6c4aa67a02831a10a72012
      https://github.com/PDAL/PDAL/commit/d9c5b65ad4cfe08b5c6c4aa67a02831a10a72012
  Changed paths:
    M apps/pdal.cpp
    M io/PlyWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into azure-pipelines
Compare: https://github.com/PDAL/PDAL/compare/84e59102a785...d9c5b65ad4cf
More information about the pdal-commits mailing list
